How to tune a rear derailleur by joe
This instructable will help you to tune up a rear derailleur.
Step 1: Tools
You will need:
Allen Keys
Cleaner( I use Pedros Oranj Peelz)
Rag
Screw Driver
Chain Lube
Grease
spizzak says: May 3, 2013. 10:00 AM
Some labels on the pictures would be helpful in these steps.
bears0 says: Oct 22, 2011. 5:09 PM
my chain seems to click because the derailleur is slightly off and the sprocket is hitting the side of the chain. what should i do?
iloqutiss1 says: Jul 8, 2011. 9:48 PM
White lightning is probably the best chain lube.. for dry weather. If you live in an especially rainy area or ride a lot in winter where it snows a lot you will want a different type of lube. I used to ride year round in Milwaukee, WI and during the summer I used White Lightning.(self cleaning, no greasy residue, great lube) Winter and spring called for something like Tri flow. A little messier but held up to the elements better.
sharlston says: Aug 25, 2009. 10:42 AM
thanks for the ible my derailer cogs are touching each other likethe little metal tab on top of the little cog my chain rubs on it and creates this horrible noise how do i adjust it?
Hycro says: Sep 10, 2009. 5:34 AM
If it's only when you have it on the smallest-sized gears, then it's a simple thing of shortening the chain a little bit, but it's nothing to really worry about, all it does is slowly wear a track on the tab your chain is rubbing against. I had that problem, shortened my chain, and it cleared it up...although, I also had the problem of the chain not being tight enough because the derailleur I was using was smaller than the bike and chain were designed for (I go through a lot of rear derailleurs, either they were of poor construction, I changed something and forgot to re-set the limits, or the stop-pin somehow wears out and the derailleur puts a kink in my chain and I have to push it home since my suspension forks won't work right if there's no oil in them, and if it's laid down, it leaks oil, and we no longer own a minivan and have no bicycle carrying racks for any of our 3 cars...)
sharlston says: Sep 29, 2009. 12:13 AM
thanks ive done it now
Hycro says: Sep 29, 2009. 4:08 AM
Np.
sharlston says: Sep 10, 2009. 11:16 AM
thanks im getting a chaibreaker next week so ill shorten it
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
