First, why use a toothbrush? I have found that toothbrushes are great waterproof motors. I have tested them so far to depths greater than 5 feet with no leaks. Most other store bought submarine motors leak at these depths and eventually rust up.
Remove these ads by
Signing UpStep 1Obtain Materials
1.Duct tape(shiny silver duct tape is better, but it is more expensive)
2.Anything buoyant enough to float your toothbrush, I used a Bawls bottle, but you could use anything else, I have even used a plastic bag.
3.Colgate motion toothbrush
4.Half an easter egg, mine was 3.4 cm(1 1/4 inches) in diameter and fit the toothbrush perfectly
5.Lego propeller
6.Lego axle 3 studs long.
7.Lego axle connector
8.Alignment tool 10 stud long axle and what I like to call an i-piece
9. Cowling, Axle 3 studs long, i piece, and cowling piece.(Optional, cowling piece helps prevent the propeller from undergoing "spontaneous mechanical failure" if it hits a wall)
10.Disposable lithium batteries(optional, but they will make your torpedo go much faster)
11.Hot glue gun with hot glue
Kudos, Gene Hacker, for a great Instructable!
