3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to turn a Toothbrush into a Torpedo!
Do you have an electric toothbrush you don't use anymore or are thinking about throwing away? Do you have time on your hands? Why not turn it into a SUPER-AWESOME TORPEDO AND ACHIEVE POOL DOMINATION!!!!!! FIRST THE POOL THEN THE WORLD!!!!!
First, why use a toothbrush? I have found that toothbrushes are great waterproof motors. I have tested them so far to depths greater than 5 feet with no leaks. Most other store bought submarine motors leak at these depths and eventually rust up.
Step 1Obtain Materials
Obtain Materials
Materials(listed from left to right)
1.Duct tape(shiny silver duct tape is better, but it is more expensive)
2.Anything buoyant enough to float your toothbrush, I used a Bawls bottle, but you could use anything else, I have even used a plastic bag.
3.Colgate motion toothbrush
4.Half an easter egg, mine was 3.4 cm(1 1/4 inches) in diameter and fit the toothbrush perfectly
5.Lego propeller
6.Lego axle 3 studs long.
7.Lego axle connector
8.Alignment tool 10 stud long axle and what I like to call an i-piece
9. Cowling, Axle 3 studs long, i piece, and cowling piece.(Optional, cowling piece helps prevent the propeller from undergoing "spontaneous mechanical failure" if it hits a wall)
10.Disposable lithium batteries(optional, but they will make your torpedo go much faster)
11.Hot glue gun with hot glue
31 comments
Sep 15, 2011. 7:01 AMLeviMc says:
You could also use the toothbrush to power more than a sub you can build cars and anything you want to move with it aswell
Oct 3, 2010. 3:28 PMdannystaple says:
Hmm - I like this - perhaps make two of them as nacelles for a foam body, then a simple and well insulated tiny controller rewired where those switches are. Hey presto - smallish water robot. Add servo's to angle those nacelles and it can dive too.
Dec 23, 2009. 10:41 AMjacksteal4 says:
you should totally add a war head and some explosives!.... That would be awesome!
Sep 30, 2010. 5:49 PMspenfisher12 says:
i have the technology and info to do that but im thinking bigger 2 ft bigger
Feb 22, 2010. 7:21 AMDenger says:
I built a couple of these torpedoes.  They work great!    I intend to use them to power a toy submersible.  These instructions are clear and easy to follow.
Kudos, Gene Hacker, for a great Instructable!
Mar 11, 2008. 5:14 PMultimachris says:
someone tell me how i could make these remote control, and i'll make an instructable on a R/C boat launched torpedo that can take out an R/C boat
Aug 20, 2009. 9:53 PMtoogers says:
hack up a foam r/c plane and replace the motor w/ propeller for the toothbrush motor.
May 1, 2009. 4:25 AMthe DEVIL says:
is the easter egg chocolate? or plastic?
Jul 13, 2009. 10:16 PMOrchestrapit says:
Cadbury caramel egg, duh.
Jul 12, 2009. 5:06 PMmrdepo96 says:
Chocolate?
Jun 10, 2009. 11:01 PMMaxattack says:
Is there a submarine on the bottom of your pool? If it is make it fire the torpedo!!!
Mar 11, 2009. 11:23 AMSpeedmite says:
Sorry about double posting but, Couldnt you put a slightly bigger prop on it to make it go faster if your toothbrush could take it?
Mar 9, 2009. 9:46 PMSpeedmite says:
I need to make this. it would be cool to put this thing in our pond. Wonder what the fish will think....
Dec 8, 2007. 12:42 PMcowscankill says:
what is a heat sink? does it absord heat?
Sep 24, 2008. 6:42 PMThe Lord Of Hurt says:
a heat sink is a little device that helps keep temperature in a component (the motor in this case) lower by dissipating it so you don't burn it out.
Aug 31, 2008. 4:40 PMbowmaster says:
Think of this: You are really and truely in need of a drink at the pool and you don't want to get out. What do you do? Have one of of your friends jet you a drink!!
Aug 18, 2008. 7:51 PMtubbychick3n says:
bawls bottle for great justice?
Jul 4, 2008. 2:59 PMcodongolev says:
yeah! bawls!
Aug 23, 2007. 1:40 AMiamthemeatball says:
dadah.......dadah...dadada.. i couldn't resist Poolside drink caddy?
May 17, 2008. 10:44 AMlegionlabs says:
Heh, I like this idea. Shouldn't be hard to implement a microcontroller that controls two of these. You would put them on opposite sides of the device so that you could run them in opposing directions to make it turn, same directions for forward/reverse. Put some bump-sensors (basically a switch that gets pressed when hit) to make sure it changes direction when it hits something like a pool wall. Or make it "light-following" with a photocell or photoresistor array and give everyone an LED flashlight to "call the bartender".
Mar 23, 2008. 1:30 PMdontwealllovebuda92 says:
This is so sweet although I'm not 100% sure my aunt will let me use this in the pool. I have an idea every one should put racing decals on this. Make them look like real torpedoes or something.
Feb 19, 2008. 6:23 PM28282828 says:
ya a shark wud be awsome or a rubber or decoy duck
Oct 4, 2007. 8:53 AMbumsugger says:
Ohhh,an E-L-E-C-T-R-I-C toothbrush,and here was me thinking you all had odd shaped mouths in your part of the world............................????????????
Jul 20, 2007. 11:55 PMjamnoopers says:
sweet! how fast does it go?
Jul 3, 2007. 10:32 AMKentsOkay says:
Rock on man! Pool domination here I come! You could use a foam shark fin to creap people out.
Jul 2, 2007. 9:17 AM!Andrew_Modder! says:
cool!....................BAWLS!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:Gene Hacker
