Turn a Can Tab into a Survival Fish Hook
 by McNoodle
Featured
This is very easy and simple.  All the tools needed for this fish hook can be found on most multi tools.  It takes only a few minutes to create.
Step 1: Materials
-can tab
-file
-wire cutters (or anything that can cut through metal)
Step 2: Shaping the hook
Cut an opening in the bottom hole in the tab.  Make sure that you cut in at a slant.  Then start cutting away as much metal as you can around the hook.  File the hook into a sharp point.
Step 3: The back of the hook
Flip the tab around.  The top hole should be untouched.  This is where you will tie the line onto the hook.  File down the sharp edges in the hole.
1-40 of 77Next »
upitaa says: Jun 3, 2011. 3:12 AM
excellent idea. but i wonder what sort of fish i can get with this hook:)
theo67 in reply to upitaaJun 4, 2011. 4:37 PM
Probably canned fish
the doctor who in reply to theo67Nov 3, 2012. 9:23 PM
lol
fatperson1239214 in reply to theo67Oct 5, 2011. 7:58 PM
ha ha ha :D
sdavidson3 in reply to theo67Jun 25, 2011. 12:54 PM
haha
McNoodle (author) in reply to theo67Jun 23, 2011. 4:17 PM
:D
TruorFalse in reply to theo67Jun 10, 2011. 10:12 PM
haha nice...
SGT. Desert says: Aug 18, 2012. 8:16 PM
great idea but see its too small and too short for the fish to catch on to it
breumer says: Apr 18, 2012. 12:12 PM
great idea!
alex codeburn says: Feb 23, 2012. 6:06 AM
it would be much better to make one out of sardine can tab
simongalp says: Dec 18, 2011. 8:14 PM
I used EMT shears and didn't need a file. In case anyone has those on hand and no wire cutters or file.
Hippymike96 says: Dec 8, 2011. 9:38 AM
How big of a fish (pounds) could you catch with this?
Tkdwn says: Oct 4, 2011. 12:56 PM
It`s a nice idea, but i would atleast cut it more in a hook style.
I think that copper wire hooks would be nice to.Something in this style:
yuanyuan9.mli says: Sep 11, 2011. 7:39 AM
this is an awesome idea
vanaka says: Jul 9, 2011. 12:53 PM
umm.... wouldn't the pop tab just float on water.......I don't know
bcarpenter4 in reply to vanakaAug 25, 2011. 11:29 AM
If you had typical fishing gear, you could put a lead sinker on the line, which would take the hook under the water...If the entire getup is survivalist, though, I imagine you could perhaps tie a rock to the sting near the hook, or something else heavy, like if you had/found a metal bolt or screw lying around. Also, the weight of the bait should help it sink.
vanaka in reply to bcarpenter4Aug 31, 2011. 4:17 PM
k thx!
splazem says: Aug 20, 2011. 6:55 AM
Awesome, very creative!
camraguy says: Aug 15, 2011. 7:01 PM
The historical precedent for this type of "hook" is called a gorget. It was commonly used over 12,000 years ago on the California Coast.
saintdoggx says: Jul 30, 2011. 3:09 AM
Creative.
nibbler125 says: Jul 13, 2011. 10:09 PM
ill bet if the fish swallowed the hook you would snag something
nikitzz says: Jul 12, 2011. 3:12 PM
This is too hard for me to make:(
McNoodle (author) in reply to nikitzzJul 13, 2011. 1:25 PM
lol
sunshiine says: Jun 22, 2011. 9:26 PM
This is a great idea.
McNoodle (author) in reply to sunshiineJun 23, 2011. 4:16 PM
Thanks!
sunshiine in reply to McNoodleJun 23, 2011. 5:06 PM
uw
lalexander says: Jun 23, 2011. 10:59 AM
there is also the tried and true "stick" type fish hook. basically a short thick toothpick formed from a hard wood with a skinny area in the middle. bait is formed over it so that the string lays flat tward one tip. the fish swallows the stick longways and the string yanks it from the center, causing the stick to dig its forward most tip in and jam sideways. the points dig in and the stick can not be gotten out or worked deeper to release the first tip. this works better than non snelled jerry rigged hooks. the trick is to not set the hook too hard because a really hard yank of the string can snap the wood. metal works too. as long as you can attach a string to the center the concept works the same.
McNoodle (author) in reply to lalexanderJun 23, 2011. 4:16 PM
Never heard of that before, but it sounds great! I'm going to try it the next time I go fishing.
bleeper says: Jun 22, 2011. 10:00 PM
i make my own fish hooks using the spring out of old wondow shade rollers using wire cutters and a torch and a dramel tool and a hammer. you straighten it out into the fishhook shape and heat the barb end and pound it flat and use the dremel to sharpen and notch the barb using the ruby cutter wheel. works and is cheaper than buying new hooks . i get 25 to 30 hooks out of each spring ...also you have to heat treat it so its not soft anymore after you cut the barb into it.
McNoodle (author) in reply to bleeperJun 23, 2011. 4:16 PM
Nice! You should make an Instructable on that.
tzsch says: Jun 2, 2011. 4:22 PM
Not to be anti-DIY but fish hooks are dirt cheap and this looks like it would be pretty rough on the fish. I'll keep it in mind for the Zombie apocalypse though.
saskew in reply to tzschJun 4, 2011. 8:41 PM
have you found yet a hook that is not rough on the fish?
tzsch in reply to saskewJun 6, 2011. 12:15 PM
Good point.
Still, I'm kind of a sap, I file the barbs off of my fish hooks. You know, you can poke a pin through your own cheek and it doesn't really hurt. The barb can cause some damage if the fish pulls loose and this hook looks a little likely to come loose. Still, I would definitely keep it in mind for real survival situations.
Microbe in reply to tzschJun 3, 2011. 3:48 AM
Yes, I agree. In fact, in Australia my understanding is  that non-rusting fish hooks are not allowed (I am sure someone will correct me if I am wrong) - the idea is that if a line breaks eventually it will rust away, but I shouldn't want to wait that long if I had a hook in my cheek.
But would that hook be strong enough to hold anything?
dummy1977 in reply to tzschJun 2, 2011. 6:09 PM
That's a good point, in case anyone's thinking about using these for fun -- they shouldn't.
But for a survival situation (which is the point of this .able), it's a good technique.
David97 in reply to dummy1977Jun 20, 2011. 3:49 PM
Who cares if it rips the fish up. When you need to fish with one it will problay be survival situations so I don't think you would be to worryed about the fish as long as it got to shore and you got a feed.
stupidninja says: Jun 3, 2011. 10:23 AM
i was thinking that you would want the hook area to be larger so it would go through the fish and to tie the string (assuming you have a pocket knife) you drill a small hole in the larger area at the top. p.s. please respond.
McNoodle (author) in reply to stupidninjaJun 4, 2011. 4:08 PM
sounds like a great idea! I will test it out as soon i get my hands on another poptab
Batryn says: Jun 3, 2011. 3:34 PM
Anyone tried it yet?
woodNfish says: Jun 3, 2011. 3:01 PM
Well this is sort of a McGiver survival thing where you use what you have. I think if you bent the hook 90 degrees from the tab, you'd have a better chance of catching a fish. Nice instructable, and very creative.
1-40 of 77Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
