Introduction: How to Turn a Fitted Tshirt Into a Cami
Turn a boring tshirt into a cami with this helpful tutorial (very very very small bit of sewing)
Step 1: First,
Make sure you have a fitted Tshirt, scissors, sharpie, and needle& thread. (cat not required :D)
Turn the shirt inside-out and snip off the sleeves right at the hem.
Step 2: Second,
Cut off the collar by starting at the black line and cutting around. SAVE THE COLLAR!!
Step 3: Third,
Cut a slight V in the front and in back and even it out.
Step 4: Fourthly,
cut the tops of the sleeves to make triangles
Then cut your collar in half
Step 5: Fifthly,
Sew the straps on the front and back very securely and turn right side in(normal)
Then cut a slit about a inch below the V and tie a piece of string around the V and through the slit to make a deeper V
Step 6: Sixthly,
Hem the edges or sew on lace now. I just hemmed mine but it turned out great!!!!
Thanks and check out more of my DIY tutorials!!
