Remove these ads by
Signing UpStep 1Supplies
Lathe
Skew (the tool that you turn the wood with)
Wood ( i'm using yellow heart one of my favorites)
CA glue or Super Glue (thick and thin if possible)
Mandrel to hold the pen on with 3 bushings
Sand paper
Pen Kit or you could use pieces from a old pen that you don't use anymore
Paper towels
BLO (boiled linseed oil)
Drill press or equivalent
Clamp
Optional:
Micro mesh to get the super shine
Beall buffing system to put on a awesome finish
Pen press
The Crown "Skewchigouge" is sort of a version of a skew, and it's easier to cut with and produces good results. It's very affordable too. I often will use just it to turn out a run of 20 or 30 pens, as it's just easy to use and cuts better than most anything except a true skew.
Also, you may want to try backing the speed down a bit. I find I have good results @ 800-1000rpm when initially rounding the blank, and 1500-1800rpm when shaping.
BTW, good job with the instructable :D
