How to Use Instructables Step by Step Photo Tutorial
Introduction: How to Use Instructables Step by Step Photo Tutorial
In this tutorial I will demonstrate how to use the instructables website's step by step tutorial maker.
Step 1: Getting Started
First, if you haven't allready you have to create an account or log inb to yours, simply go to the top right corner of the website and click on sign up!
Step 2: Signing Up
After that add all your details and insert the captcha verification and you're ready for the next step!
Step 3: Starting Step by Step Tutorial
After you click the sign up button and all your information is correct you will be forwarded to your profile's homepage, in the middle there is a section, the one that's virtually pinned up, on which it says: "Step by Step", click on that and on you go!
Step 4: Using the Step by Step Tutorial Editor
You are now inside the "step by step" editor, at the top of the page you can see a menu with "steps" these are the individual parts of your tutorial, under that you can insert a title and even lower you can type your text. Next to the Edit slab there is a button for preview in which you can inspect your slide the way it is going to be published.
Step 5: Adding Pictures to Your Steps
At the bottom of the site there is a whole area deicated to manage your photos which are an essentiel part of every tutorial. First you have to select images on your PC by clicking on the "select files" button then...  [next step]
Step 6: Selecting and Uploading Pictures
... you see a pop-up of your pc's internal memory from which you can select your pictures. After you have done that you can chose if you want to upload your picture to the current step or just your library which can be accesed by clicking on the appropriate "Library" button. When you are done with that you can upload the selected images by clicking on the "upload images" button. This process might take some time depending on the size of the picture. In addition to this you can tag pictures you hav uploaded with keywords or phrases in order to be able to find them again in your library for reuse.
Step 7: Finalising Step by Step Tutorial
After you are done with adding all of your content you have to click the "save now" button on  the top right corner of the editor.
Step 8: Publishing
When you are ready you can hit the Publish button towards the top left of the editor and you will see a long list of possible categories in which your tutorial could fit, under that you can enter contests and finally also publish your Tutorial, after that you're done!
    • Epilog Challenge 9
      Epilog Challenge 9
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    I found the editor to be extremely clunky. If you want to include more than one photo per step, it tosses them in all together at the top and won't allow placement within the text where it belongs. As an editor, it leaves absolutely no room for individual tutorial style and insists that you learn the "proper procedure" by trial and error.
    Yeah, well this is my first Instructable :D I might go back and add but for now I have loads of other stuff to do! Thanks for the feedback anyways!
    very clear instructable! It would be cool to talk a little bit about the different tools in the editor too- embed media, bold, hyperlinks, etc
