loading
Step 3: Viewer or Designer ?
I had this problem too.
What is the difference, what do I need, how to use pepakura files ?
Pepakura Viewer = view files + print
Pepakura Designer =  design models + view them + export to other formats + print
Very useful info. Thank you!
<p>Glad I was able to help you :)</p>
Thank you! I try to project that did not mention edge ID and I couldn't make it fit together so looking forward to trying edge ID out.
<p>ok so every time i put the file into print it shows up as a whole bunch of letters and symbols.</p><p> what do i do??</p>
<p>Hi, do you have edge ID and all settings set properly?</p>
<p>Is there a way to place the Edge ID's over the flaps? </p><p>So you can still use them to match the edges but not seeing them on the final model.</p>
<p>Just switch the directions of mountain and valley folds and than the edges and numbers would be inside. You just have to pay attention which side of the flaps you glue on.</p>
<p>Hi,</p><p>I do not recall if that is possible. When you think about it, it would have to be done either individually or all at once. Now what would happen with the ones that do not have the flap ? I do not recall I would see any option like this in Pepakura.</p>
<p>how do you take example i want too cosplay zed how to i get a helmet where do i find it?</p>
<p>Hi, I always google it. Using combination of: pepakura + model + NAME_OF_WHAT_I_WANT. For instance: &quot;pepakura stormtrooper helmet&quot;</p>
<p>Every time I try this the colors and lines disappear and it just shows the numbers.</p>
<p>Hi, could you perhaps share a screenshot ? It is hard to tell just by the comment. For example in which step does this happen ? Thanks.</p>
<p>how we can get more pdo images ??? my pepakura is consisting 2 pic only</p>
<p>Hi, could you perhaps share a screenshot ? It is hard to tell just by the comment. Thanks.</p>
<p>Hi, PDF is of course universal, but if Microsoft Office is installed on both PCs, you can simply print from Pepakura Viewer to an .xps file, and later print from the MS Office XPS viewer.</p>
Hi, you are welcome. I will be doing more detailed video on this probably in a week. And also I will have complete tutorial about PEPAKURA DESIGNER soon as well. <br> <br>Once done I will send you PM.
About This Instructable
202,319views
153favorites
License:
Bio: Coding guy: web developer.
More by krsiak:Your first Pepakura project Pepakura Chocolate Chip Cookies
Add instructable to:
