How to use Polymorph Plastic
I love this stuff. I use it all the time for school projects, USB covers and custom enclosures for my projects. I use Jaycar Electronics as a source for this stuff and it is ~$8 for 500 grams. It can be drilled, painted and re-moulded time and time again. I will show you what i think is the easiest way to make stuff with polymorph. PS i am not assosiated with jaycar in any way.
Step 1Start
Start
This is the hardest part of all. You can use either a wall or a high-walled metal tray. Tray's work well because they keep the plastic warm while making.
Place ~ 5 pellets against the wall and set a hairdryer to it's lowest speed and highest heat. heat the plastic until it goes clear. I haven't used hot water because this works so well for me.
42 comments
1-40 of 42next »
Feb 8, 2011. 6:25 PMData643 says:
I wonder if Polymorph could be used to make molds of tamperproof screws (new iPhone 4 screws).
Apr 28, 2011. 6:54 PMdawsonj says:
nah, its a little bit too flexible for that. try looking for another option, maybe a specialized tool online
May 28, 2011. 2:31 AMdpy says:
It depends on the size of the screw. Thin strands of PCL are very flexible (with nice tensile strength, though), but thicker parts and lumps of PCL do not show any apparent flexing. (So for thicker screws or worn down screw heads you could probably make a working screw driver out of PCL).
Jun 14, 2010. 6:20 PMjpoopdog says:
i am going to buy some polymorph, quick question, would it be appropriate to use polymorph to build a rc 1/12 2kg tank from?, as well as sheet aluminium for the base and structure of the tank also , does it do gear safts well? when i say that im wondering if it grinds away as i need to use it as a gear box
Jul 25, 2008. 2:59 AMvkain says:
how do you keep the polymorph from sticking to everything?! I've made some molds for the polymorph to go into but I ALWAYS have a hard time getting it to release from the mold. Any pointers? Thanks, vkain
Jan 24, 2010. 5:39 PMandy says:
Polymorph bonds more when it is nearly molten (and hotter). I find that a few squirts from a garden variety hand-held mister full of water, such as this www.amazon.com/Delta-Industries-Sprayers-Assorted-Colors/dp/B000HMBJ74 (you can pick these up at just about any garden center) or even a rapid dip in some cold water is enough to cool the outside of a piece of polymorph (pre-molding) to stop it sticking, even to other pieces of polymorph.
Drew
Jan 31, 2009. 11:28 AMnetbuddy says:
I just recently found a site in the US that was selling "Honey Wax" which is a wax used for releasing molds and asl in casting fiber glass shells. If you search for it, you may find a supplier near to you.
Oct 11, 2008. 11:39 AMnetbuddy says:
(removed by author or community request)
Dec 21, 2008. 11:44 AMooda55 says:
I do a little bit of home made injection moulding sometimes I find the best releasing agent is sqwirting some fairy liquid onto my finger and wiping it onto the mould might work for polymorph too (I LOVE polymorph its just so expensive at maplins, ill have to get my next batch online) PS want to make a cradle for my palm pilot I looked at my polymorph but I don't want to make a mould just to make one thing does anybody know a decent way to make a cradle for palm pilot (I want to use my existing cable and charger and build the cradle around them if that makes sense many thanks chris
Jul 16, 2009. 8:23 AMarduinoe says:
youve got to have a messy floor by now , let alone a messy wall , this stuff sticks to fabric when its hot , ie carpet
Jul 9, 2009. 2:05 PMMaXoR says:
Honey wax is also called Bee's wax..... for you canadians
Feb 28, 2009. 12:43 PMBort says:
this is stupid, I thave no idea waht is going on where does this have to do with bulding a laser projector?
Mar 6, 2009. 11:19 PMkoriko88 says:
echo_anomie's reasoning for recommending it was quite clear - as a way to securely hold the lenses. Other methods are possible, as well.
Dec 9, 2008. 6:22 AMsharpstick says:
WARNING! This stuff will become brittle after time. I made a cradle with a 1/4-20 threaded insert in it that strapped on to a binoculars for a tripod mount. After a year or so it became brittle, cracked and literally fell into pieces. This was probably about 15 years ago with the "Friendly Plastic" brand. Maybe they have improved the product by now, but I would be careful using it for permanent uses or anything that would be dangerous if it failed. It's great for ptototypes or jewelry though.
Dec 23, 2008. 3:55 AMnetbuddy says:
1. Friendly Plastic IS NOT PolyMorph it is something completely different. 2. Polymorph required 62 degrees Celsius to become workable and Friendly plastic needs 100 degrees Celsius. These are completely different plastics, please will people take note.
Dec 12, 2008. 6:15 AMsharpstick says:
Try it again after a year or two. Or three. (It might have been even longer for mine, come to think of it. That was a long time ago.) How do you make spheres? Are they accurately shaped, or just rolled by hand?
Nov 21, 2007. 11:59 PMGarth Knight says:
Can this stuff be re-melted? If so, then melt a bunch, use a piece of 1/2 pvc as a mold to make sticks of this Poly plastic. then you can use a hot glue gun to heat and pump out your plastic.
/I must call those fine folks over at cayjar and place a large order at once! Why don't all of us go to their site? >>>Now that would be spamtastic.
All DuckFudge did is let us know a good source. Not really spam.
Nov 22, 2007. 9:56 AMKiteman says:
It's a low-temperature thermoplastic - it softens at about 60C - and can be used over again.
You don't normally melt it, just soften in so you can mould it like clay.
Available in the UK from Maplin.
Oct 11, 2008. 11:44 AMnetbuddy says:
Maplin are expensive, they sell this stuff at about £40 a kilo, that is about 3 times the actual retail price. If you can, your best sourcing another supplier that does better quantities like the one I found that does 4 Kilo tubs for £56 delivered to your door, based on maplins prices, this would be £160...! Sort of says it all, maplins are milking the public, like with most of its products now.
Oct 11, 2008. 12:03 PMKiteman says:
I didn't say that Maplin were the best supplier, just the most accessible to UK buyers.
Could you post a link to your cheaper source? I know a technology teacher who wants to use it in lessons.
Oct 11, 2008. 2:06 PMnetbuddy says:
Open a google search window and stuff in to the search box the following:- intitle:(polymorph plastic) inurl:(uk) -inurl:(maplin|ebay) and you should find it in the top 5 results, I am not talking about any "Sponsored" results either... Your teacher may have to get an order aproval for going to another supplier, usually schools, colleges or LEA buying departments are often tied by contract to an existing supplier, so it may not help to know that this stuff is available from another LEA or LEA supplier. Hope this helps you.
Nov 22, 2007. 12:03 AMGarth Knight says:
Another idea. Single cup coffee warmers can be picked up cheap at thrift stores. this would give you a small heating unit right on your desktop to heat and melt your plastic...
Dec 18, 2007. 11:27 PMGarth Knight says:
update... Scrap the coffee warmer idea. I just tried one out and it only heats to 40C. Not enough for this project. The thrift store did have a bunch of cheap/used hot plates... Those will get the job done. I had focused on the cupwarmer because of it's small size. But screw that, the hot plates are usually under $5US. GK
Apr 18, 2008. 4:45 AMcotton says:
lol and i wana get a ruber stuff and speacail nomn stick spray made for it pour it over a cup the harden to be strong and then do it in thee cup so i can seal the holo case
Mar 17, 2008. 6:13 PMxtank5 says:
You might want to take actual pictures. Then the Instructable would be better.
Feb 28, 2008. 12:09 PMconundrum2142 says:
hey there.. i found a while back that glow powder (strontium aluminate) and Polymorph makes a fairly impressive glowing plastic when the powder is folded into the pre-heated plastic then mixed thoroughly. i use a craft heat gun for this but be careful not to burn your fingers! diy fishing floats (mould it round the float) work well, so do custom glowing signs. -A
Dec 3, 2007. 5:18 PMaricstewart says:
Is this basically the same as Friendly Plastic?
http://www.norcostco.com/index.asp?PageAction=VIEWPROD&ProdID=1603
I have used Friendly Plastic a bit and found it to be great. easily heated, reusable and very durable when finished.
Nov 22, 2007. 4:40 PMPyrowuzzup says:
ive used this stuff befor. it came with some vampire teeth i bought. you mold it into your real teeth so that the fangs would stay in. i used the hot water method but i think yours wouldve worked alittle better.
Nov 22, 2007. 1:34 AMLftndbt says:
This gives me some idea's thanks... Any chance of some pic's, of process and some of your made item's... That would be great!
Nov 21, 2007. 9:07 PMxrobevansx says:
so this is basically a spam post for jaycar? Oh.
Nov 22, 2007. 1:31 AMLftndbt says:
Or maybe he just want's, people to know where to get it... Or then again maybe your right.... ;)
Nov 21, 2007. 8:13 PMi make shooting things says:
do u have a web sight u can order it from?
Nov 21, 2007. 9:08 PMthatkidej says:
He said Jaycar Electronics. www.jaycar.com
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Da_Fudge
I like electronics.
