3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to use a corner to mount an Xbox 360 Kinect Sensor
Introduction:
Here is a way to use the corner in a living room to mount the Xbox 360 Kinect Sensor
Step 1Buy a 3M Command Corner Shelf
Buy a 3M Command Corner Shelf usually used in the Bathroom.
6 comments
Dec 30, 2010. 3:43 AMCazzPhoenix says:
Figures, I search the internet for hours and the answer was right here on instructables.... I have a couple questions as I need to do this exact thing or throw out a couch and rearrange the living room... again.
How high is that mounted? I'm understanding the recommended height is 6 feet but that appears to be higher.
Have you had any issues since mounting it this way?
Are you finding yourself much closer to the screen?
How much space is between your tv and the wall?
Dec 30, 2010. 8:17 AMCazzPhoenix says:
Thanks for the response.. I'll probably pick up a shelf today and give it a shot, I have to move a lamp now but that's much better than moving the couch.
Hopefully I can test it before mounting the shelf somehow and try to accurately determine the difference in play area.
Dec 31, 2010. 8:26 PMCazzPhoenix says:
I went to the store today and picked up a couple shelves for this purpose I opted to get wooden ones called "Shelf Made instant shelf". They are 12" x 12" and require no tools.
I mounted the shelf 5 ft 11 inches from the floor. It is 3 feet back from the front of my tv which the kinect previously rested on. I ran the setup again and it works great. It has not completely solved my issue and I still need to get rid of some furniture but it cut the play area distanced from the screen down by appx 3 feet.
Jan 1, 2011. 9:42 AMCazzPhoenix says:
I was trying to find a good picture showing the instructions but none were clear enough. I found that it is actually called KV instant corner shelf or Knape and Vogt instant corner shelf although I didn't see that anywhere on the box.
Basically you get 5 screws(I only used 4) with thick heads to screw in by hand, once you have them placed the shelf slides right over them as it has a groove on the two corners.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:DuelistHKLeong2
