3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to use a slide rule
I was going to enter this into the "Party like it's 1929" contest because slide rules:
- Were used in 1929 (and earlier, but never at parties I'm afraid)
- Are an intrinsically easy to replicate technology; once you know how it works, you can trivially replicate it on any medium, such as soup cans, railway spikes, or discarded bills of hyperinflated currency.
- They work underwater, in a vacuum, in the sun, in the snow, in nuclear winter. Never runs out of batteries, and you can drop it off a building and it will still work. It is the ideal tool for the discerning scientist of the post-collapse-of-western-civilization world.
- Cannot be used to easily calculate compound interest far into the future, which no one should be depending on right now anyway, since real "wealth" gains are unpredictable in the face of uncertain inflation and prime interest rates in the short term.
Unfortunately I am both ineligible for prizes, and published this instructable way too long ago. Curses!
Slide rules are analog mechanical calculators. They were ubiquitous among engineers and scientists from their inception, to the development of cheap transistor calculators.
They allowed you to do quick calculations with an accuracy up to two or three significant figures. You can multiply, divide, perform exponential functions, square/cube roots, inverse functions, trigonometry, and others. You cannot add or subtract. (Actually you can but it's much harder than doing it in your head. Bonus points to whomever posts a method to do so as a comment.)
You do the math essentially by moving sticks around. If you learn how to use this, and actually do, expect to entertain questions from anyone under 40, and nostalgic comments from anyone 40 or over.
Now, all strangeness aside, I've found one situation where I really appreciated the slide rule: as a biologist doing field work.
In that special case, you know that nature is not so kind sometimes. You will freeze and burn, you will fall off things, you may be away from civilization for months. Storms can be pretty bad, and when they aren't, the countless insects scream for a blood meal. You will need to do math in absurd conditions.
So if you're part of that special group of people to whom this applies, this is a useful tool. In fact, you should never leave for the field without a slide rule and dice (for randomizing sampling and selection for treatment groups... "arbitrary" is just not good enough for proper statistics).
This photo is of the slide rule in its "start" position. The center plastic piece slides left and right, the plastic piece to the left (called the cursor) is also mobile. Most functions are accessed in this position... if you move the cursor so that it is centered on "2" on the bottommost scale, you will notice that it lines up with 8 on the X3 scale, and 4 on the X2 scale... which should come as no surprise.
But... it lands on 5 on the 1/X scale! This is our first lesson about slide rules. They do not indicate the decimal places. You need to remember that 1/2 is going to be less than 1, but more than 0.1... and thereby reason that the indicated 5 is actually 0.5. This sounds annoying but rapidly becomes trivial.
To perform the inverse of these functions, just look them up backwards. For instance, in this configuration, 6 on the X2 scale lines up nicely around 2.45 on the middle scale, which of course is the square root.
Next, we shall move to multiplication.
Step 1Multiplication
Multiplication
The middle part of the slide rule is mobile. You move it around mainly when you want to perform multiplication/division. It works because one of the scales is linear, the other logarithmic.... and as I hope we all know:
log(ab)=log(a)+log(b)
log(a/b)=log(a)-log(b)
Note that in this photo, the slide has been moved so that "1" on the center scale is lined up with "2" on the bottom scale.
Now, note that "2" on the bottom scale is lined up with "4" on the middle, 3 with 6, etc. If you had lined up 2.15... you would then get 4.3, and 6.45 lined up.
Division just works by looking at this backwards.
But what if you wanted to perform 2 by 7? It goes off the end of the scale! Just slide the rule the other way.
17 comments
Jul 24, 2008. 12:48 AMRishnai says:
I remember doing math on a slide rule in 7th grade. It's still faster than working it out on a four-function most of the time. I also tend to spend less time wondering what the hell I meant to be figuring.
Feb 26, 2010. 6:16 AMJohenix says:
My first encounter with "Vedic Mathematics" (It gets its name from the Hindu Vedas) was in "The Daring Book for Girls".
Apparently the Vedas were non writen text books (from a pre Gutenberg era) locked against errors by poetic rhyme and meter.
Some are mathematical methods, other seem to be 'James Bond science fiction soap opreas' that describe the detonation and effects of two neuclear bombs ('Gurka's Arrow' and 'The Iron Thunderbolt'), and all sorts of aircraft (Amaya) from baloons to rocket craft and even flying saucers.
Oddly enough, Robert Oppenheimer, who was the top scientist at Los Alamos during the Manhatan Project was an expert on the Vedas and recited one of Shiva's quotes after the Trinity test. ("I have become death, The destroyer of worlds.")
Did you ever find a circular slide rule (designed for electronics work) with 24 equally spaced marks on the face? Resistors, capacitors and inductors are seperated by the roots of 10. (20% components are seperated in value by the sixth root of 10, 10% components by the twelfth root of 10 and 5% components by the twenty-fourth root of 10.)
Apr 2, 2009. 5:15 PMleighklotz says:
Slide rules can be used to calculate compound interest, by using the LL scales, which do exponentiation. There were even some slide rules made with LL scales but called "interest" scales, kind of an early version of the HP Business calculators: http://home.clara.net/sliderules/a-to-z/commercial/commercial2.htm
Dec 6, 2008. 2:13 AMMr ross says:
http://www.sciam.com/media/pdf/Slide_rule.pdf
Scientific American ran this in a cool article a few years back "When Slide Rules Ruled" . I scanned then scaled up the page so it would be easier to "read between the lines". Fun and brings back memories of electronics class in High School. With the log function of a scientific calculator generate the numbers, mark them out with a (metric) rule and hey presto..! (Still stumped on how to make trig functions but I'm not a math whiz.) Did this once to make a log-scaled graph for capacitance/R computations- same principle applies for the rule, natch.
Jul 25, 2008. 10:25 AMdavid williams says:
Some slide rules had very long scales which were printed as spirals on disks or as helices on the surfaces of cylinders. Scales several metres long could be put on devices that could fit into a jacket pocket, enabling calculations to be done to 4-digit accuracy or even better. I had such a slide rule at high school. Its main problem was that other kids didn't recognize it, so it didn't have the "nerd-cool" effect that regular slide rules had.
Jul 24, 2008. 12:51 AMRishnai says:
"preferably sobriety" rofl I know some folks who might try and make a slide rule when they got drunk. I'm one of them...
May 12, 2008. 2:25 PMjoejoerowley says:
My Dad has ten foot long slide rule in our basement from a navy ship.
May 12, 2008. 9:58 PMPurplePeople says:
It's called a demonstration slide rule because instructors would teach math calculations on it at the front of a class. It's probably still worth a couple hundred bucks because they are very rare. Last I saw, a yellow 8 foot rule went for around 500 on eBay.
May 13, 2008. 2:24 PMjoejoerowley says:
Cool! Thanks for the tips. I will look into restoration. ;)
May 12, 2008. 6:55 PMjoejoerowley says:
It probably is not worth that much because it is missing the slide itself. A shame but it still looks cool on the wall.
May 11, 2008. 10:03 PMCameronSS says:
This is great! A video would be nice, but you'd need about 720p HD to see the numbers clearly enough to be useful. Maybe a Flash animation.
May 12, 2008. 12:24 PMCameronSS says:
No, no, no...not what I meant. The images are just fine. I meant that it would be nice to have a video to further explain how it worked, but the standard crappiness you get from the average webcam would be far too blurry and compressed to see the numbers. Also, you couldn't put it on YouTube: the compression would kill it unless you cleverly added &fmt=18 to the end of the URL.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:legionlabs
I publish my failures and my successes, as my teachers have done before me. I am a member of Foulab, an independent, nonprofit research and engineering group in Montreal. Check out our webpage at...
more »
