over the years, I finally discovered the joys of using a wet tile saw.
They are inexpensive, easy to operate and in my opinion, fun to use.
If you are in need of a straight cut on a glass bottle, especially
a wine bottle, this is right up your alley!
No wires, no candles or flame, no torches or shattered glass after
all that work.
As my intention for the cut glass is for a later project, if you seek only
to cut the top from a wine bottle to use as a glass, you'll find step #3 to
be what you need. Be sure to file, torch or otherwise smooth down the
sharp edges before using it as a drinking vessel.
Be sure to check out Fstedie's instructable for making drinking glasses out of wine bottles, too!
Remove these ads by
Signing UpStep 1The basics of a 7" wet tile saw...
tutorial is basically aimed at cutting the tops off.
Hopefully, this Instructable will have you wishing and wanting a tile saw yourself.
Fear not, they are not as scary as you think, are very inexpensive, and may even be
in your garage already.
This tutorial is based on use of a 7" QEP wet tile saw. Many home improvement
stores offer wet tile saws; which are intended for use in cutting tiles for mosaic
and other projects such as backsplashes, counter tops, bathrooms, kitchens, etc.
It is an electrically operated saw which works with water.
While I have used a standard, inexpensive blade intended for tiles, there is a
blade available which is called a diamond blade. Let me reassure you that use of
the word 'blade' is not what it sounds like. In fact, it is nothing like an actual saw
blade with teeth or sharp edges, it is rough to the touch, though. Naturally one would
want to exercise caution with any power tool, so it is always a good idea to keep
your fingers away from the cutting wheel while in operation.
After familiarizing yourself with the initial operation of the saw itself, we'll
bring in the bottles, complete with pictures for each step.
For those who haven't any common sense, allow me to remind you of the
need to be of sound mind with all your senses in check before proceeding. In
other words, consumption of the bottle contents is fine, just not while doing this
project.
Put on some clothing you don't mind getting dirty and wet,
grab your safety glasses, ear plugs and let's have fun!
Few comments about this project and what i have learned.
- The edges, at least for me, of the wine bottle are a little rough. So if your going to grind the edges for drinking or trying to make them perfectly level then put that dremel tool in a vice clamp of some sort. Use the green grinding wheel and keep going until you have it where you want it.
*It's a bit messy so be sure to do the saw out side. Sweep the area of glass and small fragments as much as you can.*Even if the ends are uneven once you grind, sand and polish the edges you can have a nice flower vase for that special someone.
You can buy them Here.
I used a tile saw to cut glass until its stock blade wore out, then I bought the blade linked above.
Since then, I wouldn't ever go back to any other type blade for glass work
Another thing that would help is, if the machine came with a miter gauge, use it to keep the bottle perpendicular to the blade. If that don't work or there's no miter gauge, improvise something that can slide on or alongside the fence.
Since it's difficult to keep the bottle straight when you get toward its top, try cutting the bottle top-first, especially if you're going to leave the bottom with an inch or more of the sides.
