Step 6Buses (subgroups), Main mix, VCA's
One very common use of a bus is to assign all the drum channels (floor tom, kick, hi-lo tom, hi-hat, snare, etc.) to one bus. This way, the engineer can change the volume of the drumset in the total mix without having to change each fader on each channel. Other uses include groups of singers (girls, boys; leads, harmony), instruments (main, backup; brass, woodwind, percussion), etc.
Just remember that changing the fader on a bus is NOT equivalent to changing the faders on all of its assigned channels. It simply changes the volume of that particular mix of channels relative to the entire mix. Channels can be assigned to multiple buses, and changing the volume of one bus with channel 6 in it will not change the volume of channel 6 in any other subgroups.
Each of the subgroups also has a button allowing assignment to the main mix. In most cases, you will want everything combined into the main mix so that you can control the total volume of everything with one setting. Sometimes, however, you may leave one subgroup by itself; independent of the main mix, for whatever reason may apply. Usually each subgroup will have a left and a right fader, allowing for individual adjustment of the left and right aspects of that mini-mix. The main mix will also probably be stereo. There will be two outputs on the back of the board for left and right mix.
However, some mixers have another button to assign the main mix and any and all subgroups to a "mono" fader. This is another output on the back that is a single bridged out between the right and left of the mix out. This allows you to have a huge amount of possibilities of setups depending on where you have channels and busses assigned and what you have plugged in to the back. The mono will "bridge" the left and right channels, causing all sounds in each to be played in both. It will also, however, leave alone any left/right settings set before it.
VCA's are confusingly similar to buses. However, it helps to remember that buses route, and VCAs are simply a control mechanism. Contrary to subgroups, a change in a VCA will be exactly like moving the faders of all its assigned channels. Thus, any post-fader outs will be affected: post-fader auxes, the level of that channel in any subgroups, etc. If post-fader auxes are used for other main speakers like subwoofers, than a VCA will allow change in those too; where a subgroup would not.
VCA's are found only in larger boards.
Andrew
07511 664218
www.zappedelectronics.co.uk
I would like a 3-input stereo line input mixer (simple and cheap as I can get away with) to combine an mp3 player, my laptop, and a white noise machine. Thanks, I appreciate any and all suggestions you may have.
http://www.dv247.com/studio-equipment/behringer-mx400-micromix-compact-line-mixer--34407
http://www.dv247.com/studio-equipment/behringer-xenyx-502-premium-mixer--31558
http://www.dv247.com/studio-equipment/behringer-xenyx-802-premium-mixer--31557
Take care,
Earl
So yeah, that desk should be fine! The only thing is that you'll be recording on just two tracks, so everything you record will have to be balanced correctly on recording to give a good sound output. You can kind of cheat with multitrack recording, my recording each track one at a time, and then layering them all together on the PC. This can also be done on Audacity.
Good luck!
I've never come across a piano with XLR. After reconsidering, yeah, a piano might be able to plug in directly. But we (my soundcrew) always use XLR because we don't have jack-jack cables that are over 50feet.
Only acoustic guitars with an element with XLR can be plugged directly in a mixer without a DI. (not very common, mostly only jack)
The Jack from a guitar gives a different impedance and voltage, and it will sound very crappy.
A DI is small pre amp converting it to XLR, using a 9Volt battery or the 48volt from the phantom.
Also, an electric guitar draws his current from the amplifier, and if you plug it in your mixer you might blow out some fuses.
-Thanks
going to use it for teaching purposes.
But, i wish to ask if there are any guides or tutorials which detail the operation of a digital board, as this guide is focused on a analogue board.
