Use an old Xbox PSU to power a car amplifier.
This is my first Instructable so don't be too hard on me. I'm sure it is confusing in a lot of places.
Well, i see tutorials all over the Internet about how to use a PC PSU to power a car amplifier in a house. I wanted to try it but it seems I'm fresh out of PC PSUs... I do have a lot of old xbox's that gather dust. So i improvised. It really wasn't that different than a PC PSU because basically, the old xbox is a PC.
I'm not responsible for any harm you do to yourself, or your xbox or amp. Okay so here we go.
That's not the speaker rattling btw, and it's turned way down but still hits pretty good throughout the house.
And please remember to have the xbox completely unplugged while working on it. Even if it's unplugged the PSU can have power built up it it and it can shock you. I learned that the hard way.
You should be fine as long as you don't pull the PSU out.
Things you need
-Torx T10
-Basic tools for the wiring (cutting, splicing, etc.)
-Xbox (or just the PSU..)
-Amplifier
-Subwoofer
-An extra 4-pin molex cable, if you don't want to cut your xbox cables up.
You can also use a 4-pin male to 2x female if you want your xbox to be fully functional at the same time.
Step 1
Okay, firstly disassemble the xbox. I wont be covering this, as it is very simple. Just remove the 6 torx screws on the bottom of the xbox. Once you have it open, disconnect the 4-pin molex cable from the harddrive.
If you have an extra female 4-pin, i would recommend using that, so you wont have to cut the wires that are on the xbox. You can also used a splitter like in the second picture and have one end go to the amp, and one to the HDD to retain full functionality of the xbox
33 comments
Jun 8, 2010. 9:49 AMw00tness says:
would i be able to run a 1500watt amp or only a 400watt one?
Mar 20, 2010. 9:59 AMAsaBerdahl says:
 Thanks for the inspiration on this one. I'd run out of PC power supplies to use and I didn't realize that there was 12v in an old Xbox. I got really inspired and I even used a Neutrick SpeakOn connection to keep from touching the contact points.
Mar 11, 2010. 7:06 AMst1tch3s says:
is it possible to burn ur psu out with a 1000w amp?
i have a 1000w sony amp with one 1200w 12" sony Xplode
and i tried bridging and my xbox turned off and i cant get it to turn back on
Feb 16, 2010. 7:23 AMkingred777 says:
ok i have 400 watt amp will it have enough power to run it? what watts size did u use?
Jan 15, 2010. 10:49 PMDJNASHA says:
i'm going to find a old car amp and hook it up to a 150watt  7inch sony sub and see if it works as a electronics class project p.s keep cranking out ideas
Aug 2, 2009. 10:52 PMtheone89 says:
xbox psu dosent have enogth power to power up the amp.my turns off every 5 minutes
Aug 15, 2009. 9:00 PMSolderguy says:
Did you plug in the audio/video cable? The Xbox might be programed to automatically turn off if it doesn't detect the audio/ video cables in 5 minutes.
Aug 3, 2009. 8:19 PMtheone89 says:
which cables did u use to connect the switch in the back
Jul 8, 2009. 6:06 PMJakeanator12 says:
Great tut man, i personally dont have an x-box ( more of a sony guy) but i think it is a great find!
Jun 29, 2009. 6:57 PMsuper_kool_dude29 says:
WOW....never thought it would work but i was wrong. its powering a 250 watt sony xplod with two mtx subs. i am very peased at the results and am totally geeked!!! dont worry ill spread the word about this tutiorial. thanks...
Jun 26, 2009. 4:23 PMJinorio says:
Nicely done.. how many watts is your amp and have you found a use for the extra black wire and red wire yet?
Jun 21, 2009. 11:24 AMDJ54 says:
Hey this is great works perfect no problems. Running 21" subwoofer and 7 speakers.
Jun 22, 2009. 8:36 AMDJ54 says:
When i play my music the xbox turns itself off after about 10 minutes does anyone know a way to fix this i would really appreciate it.
Feb 19, 2009. 11:32 AMPhizital1ty says:
Hey this is a really great tutorial but, I think don't quote me but if you look both the black are plugged into the same ground port on the power supply, but i was wondering, i have a broken motherboard and the power flickers when turned on, is there any way to have the power supple turn on while its not connected to the motherboard? i know i normal PC power supplies you can do this by connecting pins on the 20 pin thing that goes to the motherboard. Any help is fantastic Thanks - Phiz
Feb 19, 2009. 2:11 PMPhizital1ty says:
if you use a multimeter you could check the voltage from the blue and white to ground to see how much voltage is running through, then use the http://pinouts.ru/Game/xbox_power_pinout.shtml pinout to see which wire is runnning to it to make it run, i would but my friend across town is using my multimeter at the moment
May 27, 2009. 7:05 PMxiao_haozi says:
Can you clarify what you have done to run this with just the xbox psu itself? I can't get mine to power on unless I use my power switch to hook 5V (standby constant) to the ps_on wire. But things seem odd.
Feb 19, 2009. 8:20 PMPhizital1ty says:
yeah i have aim message Phizital1ty, and heres my setup for some reason my motherboard powers on now, i wont ask questions... http://i40.tinypic.com/15yd55x.jpg i have the amp screwed into the top of and old xbox cover thats why its different than the halo one on the bottom (I didnt want to screw into that one)
Apr 29, 2009. 7:48 AMntrlbrnkllr says:
is there any way to remove the power unit from the xbox completely and still have it function?
Apr 29, 2009. 11:01 AMntrlbrnkllr says:
alright, thanks. btw, i have two of those CVRs in my car, great subs
Apr 4, 2009. 8:23 PMjasonsnyder says:
i was kind of skeptical at first but i wanted to try this and it worked perfect and the steps i followed were very easy. THANKS
Apr 4, 2009. 5:40 PMjasonsnyder says:
i dont plan on using my xbox for anything else except for powering my amp what is that switch on the back of ur xbox
Mar 23, 2009. 4:39 PMKicker2 says:
How do you get the corner screws off? there seems to be a like grippy thing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Br14n
