Step 4What to do when they won't die right away
1) Don't get mad. Don't show them any emotion as your face can tell which points they should press. The inability to read you will be frustrating and their emotions are your allies. "The enemy of my enemy is my friend" applies here because their emotions will distort their logic making it easier to find the weak points. This applies in all one vs one endeavors.
2) Be relentless. Don't pause in the middle of an argument to allow them to collect their thoughts. Continuously press home the ideas you are trying to put across. This opens more holes in their arguments and will allow you to maintain momentum. Allow them to make one and only one point. Then demolish that point as you drive yours into their skull. This is like a shielded charge. The attackers run forward with their shields up to deflect the wave of arrows but drop them and hack through the enemy forces using the momentum of the charge.
3) Use squirmy logic. This doesn't sound like a good thing because it sounds like you are weakening your position by constantly changing your mind. It isn't a bad thing. You can be halfway through an argument and it will completely confuse them if you suddenly switch from verbal idiomatic logic to literal exclusionary logic. This is like the old feint technique. Send a force to attack from the front as the small raiding force slips in over the back wall. The sudden change surprises confuses and sometimes overwhelms the opposition.
4) This is an optional safety measure. Use "lawyer language." This is where you naver use any absolutes. State that most things are one way. This keeps you covered as it leaves you protected if they provide a counterexample. You can always repeat what you said with greater emphasis on the special words and they can't touch you there.
Thats it. Use these strategies to win any argument. These specific strategies are pretty objective so you will have to decide how to use them depending on the subject that you are arguing about.
Apology: Yes, I know there should be better pictures but I don't happen to have many pictures of people looking angry and arguing; they aren't the most photogenic moments. It also is a factor that it is not quite yet possible to take a picture of a concept. Thus I cannot really take a picture of the strategies.
Last note: I am not responsible for how you use this information. For example: if you get fired, suspended, expelled, punished in some way, or get the **** smacked out of you by a more sensitive teacher it won't be my fault. Have fun.
Add Comment
