loading
Step 3: Add Rim Piezo Sensor
The next step is to add a piezo sensor for the rim of the drum which will allow us to play a snare rim if using a snare or cymbals, cowbells, or other percussion sounds, or any other samples that your module or software will allow.
A breakdown on modules that I know:
Alesis DM5  does not allow double zone but does have enough trigger inputs (12) that you could wire a drum a little differently and actually have a double zone drum (Or cymbal).
the DM5 does have MIDI out which allows it to trigger software. a MIDI to USB adapter is needed to connect it to a computer.
Alesis i/O it has 10 inputs all of them double zone (When using a TRS cable)  TRS picture on the following steps. This is not a drum module but instead a Trigger to USB interface, it does NOT produce any sounds but instead allows you to play software like BFD2 , Superior Drummer, EZ Drummer, Steven Slate Drums (which is the one I have) and more similar programs, The programs just mentioned are far better than any stand alone module due to the variety of sounds that you can get from any drum (some have over 90 velocity layers) making for a very realistic drum experience which mimics the real thing so closely you'll wonder how you played anything else before.
Roland   Almost all Roland modules that you can buy today have MIDI out capability and at least some double zone inputs, more modern modules even have triple zone capabilities and even MP3 inputs to play along with your favorite tracks and some other fancy features that make them more than capable to support any electronic drum kit.
My personal preference is the Alesis I/O because of it's price and capabilities, it doesn't support triple zone but the only part where I would need it is for the ride cymbal.  I am  working on a way to do a triple zone cymbal on a double zone input, I think it has been done by racer52online in YouTube under "DIY Dual Zone Cymbal with Choke.MPG"
I bought a Roland TD-6 that came with a whole bunch of auxiliary electronic percussion equipment included:<br><br>-Alesis D4 module / brain<br>-11 cymbal boom arms w clamps, foams, and washers<br>-10 home made drum pads (metal plates w foam and rubber covering; piezoelectric sensors with RCA outputs<br><br>I just use the TD-6 on its own, so I'm thinking that these items might be of interest to those in this forum. I live in Vancouver, BC, and my email is rob.sedleski@gmail.com.<br><br>If you know of anyone that might be interested, please pass this along.<br><br>Thanks!
I don't personally know any other drummers in the area (middle of nowhere WV)<br>but I recommend that you check the Roland forum,i'm sure there will be plenty of interested people there.
great work! and very simple.
Thanks!, the idea was to maintain the integrity of the drums as much as possible while at the same time making a very functional electronic drum for as little $$ as possible.
Well done Man, well done!. Something similar I do with my alesis DM5 and Sonor acoustic drumset combined with mesh heads. Works perfect for me. <br>Here are you can find some links I used for this project: <br>http://www.edrums.info/ <br>If somebody have some question I will be glad to try to answer <br>Cheers, <br>
About This Instructable
23,538views
44favorites
License:
Bio: I am a musician, but not professional, I have been in many bands over 18 years and have different experiences from them. Being in the ... More »
More by doggyd69b:How to Convert any acoustic drum into an electric drum step by step guide Electronic Bass Drum Concept Electronic Drums Lingo
Add instructable to:
