3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to wire a shed for electricity
I found myself in need to move my noisy woodworking to my back yard to avoid waking up my lady who works night shift. I decided to wire my shed and after some homework and the help of the Instructables community I started my project. Before we start I assume that you know how to wire the different fixtures.
First you will need:
Step 1The right conduit
The right conduit
The right conduit to use is a liquidtight conduit approved for use underground or outside installations. It is a metal conduit covered by resistant plastic. You should find out if there is a code regarding buried electrical lines. My conduit will be buried between 18" and 24". You do not need to worry about frost lines because you are dealing with electricity and not pipes carrying water.
I bought 50 feet of conduit, more than the distance between my house and my shed. The conduit will be connected to a switch box in my basement and to a junction box inside my shed.
You will need an electrician's fish tape to pull the wire inside the conduit. If you find difficult to pull the wire there is a clear lubricant that you can use to make the job easier. Make sure that the lubricant dries before you connect the wire to the main box.
39 comments
May 14, 2012. 7:05 AMRetanotech says:
what about shop vac and parachute to pull string through burried pipe or unburried pipe to then pull wire?
Feb 17, 2012. 7:02 AMevad says:
I'd think about adding a ground fault interrupter type outlet...
Oct 16, 2011. 12:42 PMtinker234 says:
excuse me could i somehow make a quick removable system for this
Oct 23, 2011. 1:14 PMtinker234 says:
well i was thinking of using telescopic rods that would run from my home to the shed
Aug 29, 2010. 5:08 AMlemonie says:
Useful I like it. However, I notice the NM-B cable says "INDOOR" on the pack, and is intended for normally dry conditions - you are confident that it will last in the ground?
L
Aug 29, 2010. 9:33 AMaltontoth says:
Although technically you shouldn't be running a multiconductor cable like that through a conduit (dissipating heat is harder for a cable in pipe), the outdoor rated cable is typically intended for direct burial (to full voltage yard lights, for example). When I did a friend's shed, we used PVC pipe ($8-10 per stick), and bought the wire (3 separate conductors, not as a cable). Also picked up a yard plug this way (put a PVC elbow into a bucket with a small post, poured concrete, planted it in the ground). Cheers
Jun 24, 2011. 8:01 PM2 stroke says:
sorry a little late but i use the grey electrical conduit made of pvc it is made by scepter and is approved for out door use and my wire inside does not get hot it is fine but liquid tight is better and easier to install if you are wiring under ground like you did my uncle is a electrician so im sure he did a good job :P
Jan 24, 2011. 6:46 PM2 stroke says:
i run indoor cable 12/3 romex through a conduit to outside my house from my garage breaker panel where i do my welding its about 12ft of a run for the cable through PVC conduit and i use a small 120 volt welder with full 20 amp draw i think you should be fine for wood working, liquid tight under ground u should be fine :P
Aug 31, 2010. 2:50 PMnagehmai says:
Its technically against code to run regular indoor sheathed 12/2 Romex inside an underground conduit. The reasoning behind this is, as altontoth mentions, is due to heat dissipation issues. You can, however, run unsheathed wires inside the conduit instead. Since you're just powering a shed, you're not likely to burn anything up with what you've done though. Another, and probably cheaper alternative for anybody else looking to do this, is just to drop direct-bury NMWU Romex into your trench and forget about the conduit. This is what I used to run power to my chicken coop.
Aug 31, 2010. 3:19 AMaltontoth says:
PVC is used in ground level slabs in commercial all the time. The point I'm trying to make is that you're not supposed to pull a multi-conductor line voltage cable through any sort of conduit (PVC, EMT, and liquid-tight). That's actually in both the CEC and the NEC (as far as I'm aware...at least the Canadian Electrical Code). Though to be perfectly honest, if it's just a shed, it doesn't really matter HOW it's done, as long as it's not an installation for someone else, and you're the one who's happy with it and it's safe.
Aug 31, 2010. 3:34 AMaltontoth says:
Hm. And of course, when I go to look up the specific rule numbers. I can't find it. I know that it was quite clearly drilled into our heads through three years of electrical training that if a line voltage multi-conductor cable is going through a raceway, it's for a limited distance only, to protect against mechanical damage. But, lacking the actual page number etc, I'll rescind my point regarding conduit.
Aug 29, 2010. 12:17 PMlemonie says:
It's down to the conduit I guess. Waterproof should do it.
L
Feb 5, 2011. 5:26 PMvincent7520 says:
Yes it's a real mess and it is also an example of the american contrast : the american are the only people on earth who can send men to the moon or on mars, but I never saw a domestic electric installation which was not a mess like that …
In europe regulations are so stringent that no handyman would accept to leave an appliance in such a mess : he would be held responsible and the insurance would not cover it ! …
how funny : same techniques vs different countries / culture => different benchmarks !…
Oct 3, 2010. 5:24 PMHycro says:
Man, I would have broke out the hammer, safety glasses, and face shield and broken the rock...but, that's just me...
Oct 6, 2010. 7:52 AMbeehard44 says:
i would just make a huge fire pit with the rock as a centerpiece and have a BBQ party using a huge fire pit and pouring severely cold water over the rock.
Done.
Oct 4, 2010. 9:17 AMgeo_caver says:
I am surprise that you did not use PVC pipe as a conduit for the wires as a security against potential animal gnawing or even accidental cut off by simple root removing process or gardening.
Aug 29, 2010. 7:16 AMNachoMahma says:
.  I see two huge problems.
  1. There is no ground! You need to use 12/2 with ground cable.
  2. It looks like the conduit runs downhill toward your box in the first picture of step 6. This will allow water to intrude and it will flow straight to your electrical box. Move the box up a few inches. Make sure the conduit starts uphill as soon as it enters the basement to minimize water leaking in.
Sep 4, 2010. 6:37 PMdave566 says:
Im pretty sure I see a green ground screw in there for bonding the box to ground. Nice work most people ever look that.
Aug 29, 2010. 7:54 AMNachoMahma says:
> The wire does have ground
. Sorry about that. I think I need new glasses.
Aug 29, 2010. 10:30 AMdhandel1 says:
Your land lady is fine with you running cable? are you a licensed electrician? If not, I don't think you should be giving advice to people (especially those who have never worked with cable before). I work in the real estate industry, and I know an accident waiting to happen when I seen it. IMHO call a professional when it comes to electrical and gas... is saving money really worth the very possible risk of fire?
Sep 4, 2010. 6:35 PMdave566 says:
To work on someone else's house you do need to be licensed even if it's something as simple as replacing a light. Only if you own the house can you technically do electrical work. Just use common sense and know when a project is over your head.
Sep 4, 2010. 6:25 PMdave566 says:
Even though the conduit is labeled as liquid tight National Electric code recognizes that anything buried underground must use wire rated for wet locations. 12ga UF cable works OK. I like THWN wire in rigid pipe or PVC pipe. Also electrical code limits the length of flexible conduit to 6ft runs, that is from termination to termination. My best advice would be to dig up the flex, lay down 3/4" PVC conduit and fish tape 3 strands of 10ga THWN and 3 strands of 12 ga (shared ground) then you can run 120v shop stuff and you have the capability of a 240v welder circuit.
Aug 29, 2010. 12:07 PMOroka says:
I bought this house with a shed on the side. The previous owner just ran a line off the porch light! I really need to get a proper line like the one in your ibble run to the shed.
Aug 29, 2010. 12:13 AMharry599 says:
when i powered my shed, we used arourmoured cabe because my dad does a lot of garndening and if he but a spade through it, were stuffed, but he shouldnt be able to, unless he used a chainsaw
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:blkhawk
The best moments usually occur when a person's body or mind is stretched to its limits in a voluntary effort to accomplish something difficult and worthwhile. (Mihaly Csikszentmihalyi)
