loading
Step 5: Wiring the shed
After I determined the best location for the junction box, I built a panel where I could keep everything together: the junction box, the electrical outlets and the light switches.
I drilled pocket joints in two pieces of 2 x 4 and screwed them to the supporting studs. Then I screwed a 3/4 inch board on the 2 x 4 's.
<p>Thanks for the help but is it legal.</p>
<p>this did not tell me how to wire a shed no help at all </p>
If you don't believe to be skilled enough to work with electricity then by all means hire an expert.<br>
<p>We are renting shed and want to run electric for an AC. No one will be living on the property will it be OK to skip the conduit? It will only be hooked up temporary for 1-2 months max.</p>
<p>You can use direct burial electrical cable.</p>
I Got a small hunting shed its 12x40 I want to wire it to beable to live in for a week or two at a time. Of course I can't afford a electrician. So I have to tackle it by myself Lord help lol. Want I want to know is can and how would I wire from a generator which would act as the house I'm hopeing. Any help would be great thx.
Check this Instructable for ideas:<br><br>http://www.instructables.com/id/Easy-Generator-to-Home-Hook-Up/
what about shop vac and parachute to pull string through burried pipe or unburried pipe to then pull wire?
Have you tried it?
Tombooya Reply<br>I Got a small hunting shed its 12x40 I want to wire it to beable to live in for a week or two at a time. Of course I can't afford a electrician. So I have to tackle it by myself Lord help lol. Want I want to know is can and how would I wire from a generator which would act as the house I'm hopeing. Any help would be great thx.
<p>Yup - won't pull past an obstacle any better than wire/tape BUT it pulls faster if there is none. I did 350' in two runs and decided to try the vacuum. A little 'plastic bag' with the 'seal' part pulled off and 'tied' in half and a vacuum, mighty quick!</p>
Using a vacuum and a small chunk of plastic is actually QUITE common for long pipe runs in the electrical industry, though I've never tried it on flex, so it may or may not work.
<p>Good I'ble well set out thanks</p>
You should never run jacketed wire through a conduit. You should buy the spools of individual conductors, and use those. <br> <br>Part of a wire's rating (how much current it can carry) is it's ability to give up heat. If you put insulated wire into a conduit, it becomes like a little oven trapping the heat that the current creates. <br> <br>If you MUST use jacketed wire, you should de-rate the wire. So, a 12 gauge wire that would normally be rated for 20 amps, would instead have a 15 amp circuit breaker. <br> <br>Be safe.
hi i could do with your help would i be ok wiring frima double plug socket in house to shed .i got two little sheds out back joined to each other first one i want one double plug socket one switch one celling light. next i want to drill through to second shed have two double plug sockets one switch one celling light i all ready have one of the double wired in from house i can use it for chop saw light eg; i wont be uesing every thing together but need to know if one double plug from house be enough irishalan ta
Your setup should work. Make sure that the wire or extension cord that you plan to use is approved for outdoor use.
Hello, thanks for this writeup. I'm looking to do something similar for my shed. I'm thinking 2 overhead lightbulbs with switch, a very small window like a/c unit in the summer,and small space heater in winter, and a couple other outlets for skillsaw, etc. Its about a 75 foot run, so I'm almost thinking 10 gauge, 20amp. Maybe 30 amp breaker? I'm curious about your wiring to your mainbox. Do you have this line with a new single breaker box and also a breaker in your mainbox? so a double breaker?
The small box that you see is only a switch to turn the electric off at the shed whenever I am on vacation or if I am performing an electrical upgrade in the shed. I am not an electrician and I am not sure about the power requirement for your a/c and heater. You could post a question in the Question and Answers forum to find out the breaker amperage rating needed.
I'd think about adding a ground fault interrupter type outlet...
Thank you for the suggestion. I also thought about it, since most of my woodworking is done outside the shed.
excuse me could i somehow make a quick removable system for this
If you have an idea, please share with us!
well i was thinking of using telescopic rods that would run from my home to the shed
<br> Useful I like it. However, I notice the NM-B cable says &quot;INDOOR&quot; on the pack, and is intended for normally dry conditions - you are confident that it will last in the ground?<br> <br> L<br>
Although technically you shouldn't be running a multiconductor cable like that through a conduit (dissipating heat is harder for a cable in pipe), the outdoor rated cable is typically intended for direct burial (to full voltage yard lights, for example). When I did a friend's shed, we used PVC pipe ($8-10 per stick), and bought the wire (3 separate conductors, not as a cable). Also picked up a yard plug this way (put a PVC elbow into a bucket with a small post, poured concrete, planted it in the ground). Cheers
If a wire gets too hot it means that the wrong wire is used. Liquid tight conduit is approved to be used outside or buried. PVC is commonly used but I would not recommend it because it is not designed with weatherproofing in mind. If you rather use PVC, wouldn't you run with the same overheating problem like you claimed?
sorry a little late but i use the grey electrical conduit made of pvc it is made by scepter and is approved for out door use and my wire inside does not get hot it is fine but liquid tight is better and easier to install if you are wiring under ground like you did my uncle is a electrician so im sure he did a good job :P
i run indoor cable 12/3 romex through a conduit to outside my house from my garage breaker panel where i do my welding its about 12ft of a run for the cable through PVC conduit and i use a small 120 volt welder with full 20 amp draw i think you should be fine for wood working, liquid tight under ground u should be fine :P
PVC is used in ground level slabs in commercial all the time. The point I'm trying to make is that you're not supposed to pull a multi-conductor line voltage cable through any sort of conduit (PVC, EMT, and liquid-tight). That's actually in both the CEC and the NEC (as far as I'm aware...at least the Canadian Electrical Code). Though to be perfectly honest, if it's just a shed, it doesn't really matter HOW it's done, as long as it's not an installation for someone else, and you're the one who's happy with it and it's safe.
Hm. And of course, when I go to look up the specific rule numbers. I can't find it. I know that it was quite clearly drilled into our heads through three years of electrical training that if a line voltage multi-conductor cable is going through a raceway, it's for a limited distance only, to protect against mechanical damage. But, lacking the actual page number etc, I'll rescind my point regarding conduit.
Thank you. I thought that I was doing everything right. (Proverbs 9:8-9) &quot;Give a reproof to a wise person and he will love you. &nbsp;Give to a wise person and he will become still wiser. Impart knowledge to someone righteous and he will increase in learning&quot;
Its technically against code to run regular indoor sheathed 12/2 Romex inside an underground conduit. The reasoning behind this is, as altontoth mentions, is due to heat dissipation issues. You can, however, run unsheathed wires inside the conduit instead. Since you're just powering a shed, you're not likely to burn anything up with what you've done though. Another, and probably cheaper alternative for anybody else looking to do this, is just to drop direct-bury NMWU Romex into your trench and forget about the conduit. This is what I used to run power to my chicken coop.
I thought about running the direct-bury cable but I thought that the wire needed some type of protection. Thank you for the suggestion.
The liquid tight conduit is weatherproof and waterproof. Its purpose is to protect the wire inside but to be on a safer side I could also use cable designed for underground or outside applications.
<br> It's down to the conduit I guess. Waterproof should do it.<br> <br> L<br>
Yes it's a real mess and it is also an example of the american contrast : the american are the only people on earth who can send men to the moon or on mars, but I never saw a domestic electric installation which was not a mess like that &hellip;&nbsp;<br>In europe regulations are so stringent that no handyman would accept to leave an appliance in such a mess : he would be held responsible and the insurance would not cover it ! &hellip;&nbsp;<br><br>how funny : same techniques vs different countries / culture =&gt; different benchmarks !&hellip; <br>
Man, I would have broke out the hammer, safety glasses, and face shield and broken the rock...but, that's just me...
i would just make a huge fire pit with the rock as a centerpiece and have a BBQ party using a huge fire pit and pouring severely cold water over the rock.<br>Done.
I am surprise that you did not use PVC pipe as a conduit for the wires as a security against potential animal gnawing or even accidental cut off by simple root removing process or gardening.
I used liquid tight conduit but I might as well used a direct burial cable. It is against electrical codes to use a conduit with sheathed cable inside.
.&nbsp; I see two huge problems. <ol> <li> There is no ground! You need to use <a href="http://www.google.com/search?q=12%2F2+with+ground" rel="nofollow">12/2 with ground</a> cable. <li> It looks like the conduit runs downhill toward your box in the first picture of step 6. This will allow water to intrude and it will flow straight to your electrical box. Move the box up a few inches. Make sure the conduit starts uphill as soon as it enters the basement to minimize water leaking in. </ol>
The wire does have ground and once the conduit goes in the shed the conduit goes up and it is connected to a junction box.
Im pretty sure I see a green ground screw in there for bonding the box to ground. Nice work most people ever look that.
About This Instructable
578,510views
303favorites
License:
Bio: "Inaction breeds doubt and fear. Action breeds confidence and courage. If you want to conquer fear, do not sit home and think about it. Go ... More »
More by blkhawk:Mist machine Como conectar dos telefonos para comunicarse dentro del hogar Wood burners
Add instructable to:
