How to Write a Library the Easy Way
1,801
42
Posted
Introduction: How to Write a Library the Easy Way
First thing is first I am not a programmer or have a lot of experience programming I am just a beginner. there are a lot of ways of doing things this is my way maybe is the wrong way but it works for me. This is for beginners like my self, if you have any questions about anything just let me know and i will try to help. it is hard for me to explain some things with out going in to detail but ill try my best to answer. with that being said lets get started...
Step 1: The Intro
I have been working in a project that uses a Pt2322 6 channel audio processor that uses i2c protocol, there is only one library written by oddwires and its a bit hard to use. I was having some problems understanding all the functions so I started to study the library and after some research it all made sense, so I decided to write my own blink library .
This library consist of 3 files
*.cpp
*.h
keywords.txt
Step 2: The Header File
the code:
#include "Arduino.h"
class Blinker //we define our class
public: //public declared variables & functions, accessible outside of the class
Blinker (int pin, int duration); //default constructor of Blinker class
void blink (int times); //we define our function
private : //private declared variables & functions, accessible inside the class
int _pin;
int _d;
}; //end of class definition
looking at the above code we can see how we have created a class object named Blinker, and we see our function
blink we have set up are variables public and private. this is our header file or *.h now our.....
Step 3: Our Cpp File
#include "Diylibrary.h" //include our header file
Blinker::Blinker (int pin, int duration) //calling constructor
{ pinMode(pin, OUTPUT); // make pin an output
_pin = pin; //pin
_d = duration / 2; //wait halft of the wanted period
void Blinker::blink(int times) //we define our blink fuction
for (int i = 0; i< times; i++)
digitalWrite(_pin, HIGH);
delay(_d);
digitalWrite(_pin, LOW);
if you look at the code you see that this is our main function first we include our header file in this case "diylibrary.h"
all the lines are well commented so i wont go into much detail. the constructor in this case Blinker assigns all the parameters to the variables. the blink fucntions does all our work for us.
Step 4: Our Keywords File
with out the keywords file nothing from our library would be recognized by the environment and highlighted in color. Each line has the name of the keyword, followed by a tab followed by the kind of keyword. Classes should be KEYWORD1 and are colored orange; functions should be KEYWORD2 and will be brown.
so we add these to our keywords file ans save it as a *.txt
Blinker KEYWORD1
Blink KEYWORD2
Step 5: Using the Library
#include <Diylibrary> // we include our library
int ledPin =11; // green led pin
int ledPin1 = 12; //white led pin
int Duration=500; //our duration
Blinker BlinkWhite (ledPin, Duration); //our new created object will blink pin 11 for the value on our duration variable
Blinker BlinkGreen (ledPin1, Duration); //another new created object will blink pin 12 for value on our duration variable
void setup(){ }
void loop()
BlinkWhite.blink (3); // our class is blink it takes a single argument of the number of times to flash
delay(2000);
BlinkGreen.blink(3); // blink our white led the wait 2 seconds blink our green led and wait 2 seconds repeat (3) times delay(2000);
really simple code we define our pins and the duration. we create two objects BlinkWhite and BlinkGreen we add this to our loop and declare the number of times to flash with only 3 lines of codes we can keep adding more and more leds.
add the library to the arduino library folder and to make it work just connect two leds one on pin 11 and the other one on pin 12 and run the sketch
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
2 Comments
I will update this instructable with more details and definitions of constructors destructors, methods, classes, fucntion etc.. ect.. and will add a new class and Fader fuctions to the library so it is easier to understand and follow.
Nice informational based instructable! Very useful for those that are new to coding concepts.
