How your home network works by thegeeke
Lately I have been getting a lot of requests to help people with connection problems on their home networks.  Because of this, I have decided to write an instructable on how to troubleshoot your home network issues.  Before you can troubleshoot your network, it's a good idea to understand how it works.  This instructable is designed to teach you how your home network works.
Step 1: What each of your devices do
In a home network, you will generally have at least one of the following devices:
A modem
A router (wireless or wired)
A network switch
Many times when you have a wireless router supplied by your ISP (internet service provider), it has the modem built in.  You can see two routers and a switch in the pictures.
Here is the basics of what each device does:
The modem is the device that sends all of your data to your ISP so that you can communicate on the internet.
The router "routes" between different networks.  In the home setup, there will generally be the outside network and your home network (inside network).  In addition to routing traffic between two networks, your router will generally have NAT (network address translation) and a firewall.  NAT is used to save public IP addresses (all of your home IP addresses are condensed into one public IP address supplied by your ISP).  It also provides some level of security.  Your firewall decides what traffic can get into your home network.
The switch allows you to expand your wired network by giving you more ethernet ports that you can use.  It switches which ports are communicating at one time at a very high speed.
I will not get into how each of these work, as it took me about 1.5 years of very intensive learning to understand networks in the way I do today.
thegeeke (author) says: Sep 14, 2012. 4:34 PM
If you liked this instructable, please be sure and vote for it in the Fix it and Improve it contest, as well as the Hurricane Lasers Contest.
The voting link for the Hurricane Lasers Contest is at the top, and here is a link to the Fix It and Improve It contest:
http://www.instructables.com/contest/fixit2012/?show=ENTRIES&sort=RECENT&limit=18&offset=18
darman12 says: Sep 14, 2012. 8:11 PM
I voted for your instructable ;)
thegeeke (author) says: Sep 15, 2012. 5:37 AM
Thanks!
darman12 says: Sep 15, 2012. 7:49 AM
Oh, resubmit your other networking Instructable to my group, I accidentally denied it D:
darman12 says: Sep 13, 2012. 8:41 PM
Just as a suggestion, you should explain what an IP address is.
darman12 says: Sep 13, 2012. 8:43 PM
Oh nevermind, I found it :P
thegeeke (author) says: Sep 14, 2012. 6:20 AM
HaHa, you gave me a heart attack for a minute... I thought for sure that I explained that! ;)
Sorry I freaked you out, haha.
thegeeke (author) says: Sep 15, 2012. 5:36 AM
No problem... I need a little excitement now and then. :)
amandaghassaei says: Sep 13, 2012. 4:18 PM
thanks for these network instructables, lots of good info.
thegeeke (author) says: Sep 13, 2012. 7:15 PM
You're welcome, and thank you! :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
