Step 6The first time...
You'll no doubt be nervy as hell and worrying about doing something wrong, that's natural...
To help with all of this and to have an enjoyable first time where things don't go horribly wrong...
So to start with make it somewhere you're both comfortable, like one of your houses, nowhere stupid like a library, have protection wherever it's likely to be and for a start never push it, letting it happen is a much less damaging experience for the less ready partner...
If it's her first time (regardless of being yours or not) then consider these things...
You shouldn't be jumping straight in. Foreplay is essential, otherwise you'll be tense and not ready." Foreplay allows your body to prepare itself and loosen up a little. Also the guy should honestly torture you a bit, teasing and whatnot, not to get you all horny and crazy but to get you wet, so it hurts less. (Because if it's the first time it will hurt but a bit, but foreplay will help a little with the enjoyment factor as well as lessen the hurt, a lot of which is down to the guy to help with.)
Guys: You play a very important part in a girls first time, being the Do-ER you have the most control over how all this goes so you should take it easy and go slow, most of it about getting in without her ripping chunks out of your shoulders in pain... Take it slow and push gently, at first barely thrust at all and very slowly build up, don't move suddenly just go slow, if it hurts for her too much move back a bit until it's not as bad, don't jump right out or jerk back, it'll hurt more...
Another thing to note...
Don't go into your first time thinking you're going to be some super performing porn star sex god. More often than not, the first time is quick and mostly a learning experience. (All the more reason to have a lot of foreplay beforehand!) Just go with the flow and don't worry too much about the way you're performing. The first time is not the last time you'll do this - you'll get better with time!
Add Comment
