How To Make Money - As a Teen
Step 10Fix Computers
Fix Computers
Now, there is lots of money to be made in computers. Fixing them accounts for a lot of that. The geek squad charges around $100 a hour to fix your computer.
I can show you a little troubleshooting you can do to fix most viruses.
First, if the computer is frozen but you can move the mouse, press ctrl + alt + delete. that will open the task manager. Just use that to shut down the computer. That should fix it.
If it has a virus, just run a virus scanner. You can find free ones on the internet (make sure they're legit). The only problem you may have is that it takes one of those things around 4 hours to do its job. But still, they work.
For everything else, you can always try searching instructables for one on computers.
Now just make sure in the poster you add "If I can't fix it, you don't have to pay me". It's only fair. I mean, how would you like it if some kid came into your house, tried to fix your computer, failed and then asked for his pay?
DSman195276
Rishnai's additions:
If the computer is frozen and you can't move the mouse, ctrl+alt+delete will still work. Then get around using the arrow keys and tab to move around. Shift+tab moves backwards. alt+f4 closes the active window. Alt+tab cycles through available windows. Someitmes you need to hit enter to select something. Other times it's the spacebar. the esc (escape) key will often take you back all the way to the start of something. Pressing the backspace (not "delete") key will take you back one. Ctrl+z is undo, although many times this is unavailable. Ctrl+y is redo, in case you go a little too far with your undoing.
If the computer is completely frozen, hit the power button on the front of the case. On older computers it is an actual switch, but on new ones it is just a "suggestion." If the power button doesn't work, reach around the back of the case and unplug the huge wire. Plug it back in, and on the bootup you will see what's called a BIOS screen. Hit esc or one of the function keys (there are usually directions), and you'll be able to putt around and try to fix something big. Generally you want to "boot in safe mode," then go about the rest of your troubleshooting. Again, this is if it's a big issue.
CD drives can burn out, parts can break, and for any number of reasons, they can get stuck. There is a small hole in the front of each one. In event of catastrophic failure, if you need to get a CD out, straighten out a paperclip and stick it in the hole. Feel for a clasp by gently pushing until something clicks. The drive will come open, and you can get the disc.
If someone's internet commection won't work (and they have dial tone and have paid their bill), unplug the power to their modem for a full minute. Plug it back in and let it get done waking up. Try the internet again. It'll probably work. If tey're still on dialup, they might be trying to dial a bad number. Open the browser login window, right click, properties, and select a different number. Other times the window itself will have a dropdown list of numbers. Look around. Try a different number till it works.
To defrag a hard drive, make sure the person knows that the computer will be unusable for several hours. Files load much faster on a defragged drive. It'll take possibly over a day, depending on how big the drive is, how fast the processor is, and how much RAM they have. Go to "My Computer," right click "Drive C:" (that's the primary hard drive), go to the "tools" tab, and hit "defrag." Now wait. Turn off their screen to save power. When their computer stops clicking (old ones) or the whirring stops and/or the light on the front stops blinking like mad, it's probably done. Tell them that when that hapens, turn the screen on. If it says "finished defragging," close that window. If it's still working, just turn the screen back off and wait. If it prompts them about something that they're not sure of, tell them to call you.
Gjdj3's additions:
Don't limit yourself to just fixing computers. You can also offer to customize computers. You can set up a dual boot, install Linux, or make their XP look like OS X. There are a lot of great instructables to show you how to do these.
If you can't get to the BIOS screen, odds are it's because your computer's key get you there is not the escape key. Most of the time it will tell you at the bottom of the starting screen. If not you can just google the name of the computer to find what key it is.
One important tool for anyone wanting to fix computers is the bootable Linux Sytem Rescue CD. Download it here...
http://www.sysresccd.org/Main_Page
Once you get the CD I would advise keeping it with you on all jobs. It has great tools for fixing your system like GParted and other tools of the sort. To get it to boot, just go to the BIOS screen and set CD to the top of the boot order.
Finally, I would keep a bootable USB Stick or CD with Linux on it in case they've messed up their OS and it won't start.
20 comments
Feb 27, 2009. 8:05 AMmasterpj says:
Agreed with muthbusterma
ICT basic stuff isn't hard to understand but experience is required.
and can't be learned quick!!!!
Remove this part because indeed it could give terrible results.
And the basic ways of repairing are alwayst the worst in result because advanced can repair, retrieve more and increases the PC or notebook's lifespan.
Don't make money with something you dont have experience in.
Leave this part to experts.
I'm not flaming but GET REAL PLZ!
and as i read this *laughter* this is the most worthless ICT explaination ive ever seen (not that i need it )(sorry no offense, but i just can't stand this sorry)
Oct 22, 2009. 8:56 PMdarkNiGHTS0 says:
"On older computers it is an actual switch, but on new ones it is just a "suggestion.""
Whoever wrote that doesn't really know anything about computers... press and hold for 8 seconds and it turns off.  That's basic computing knowledge.
May 24, 2010. 1:31 PMPikminRed says:
Or, you could just flip the power switch on the back of the computer, next to where everything is plugged in.. The problem is if you don't give the computer time to turn off, you can lose data or damage your hard drive (the magnet "needle" will erase some of the data)
Jun 29, 2010. 9:20 PMIan01 says:
In a power failure modern hard drives will use the rotational energy of the spinning platters to write the data left in the cache. This cache is usually 16 or 32 MB, though, so it might not be able to write the whole file.
Mar 13, 2010. 6:51 PMhbjngf says:
one more suggestion would be to purchase a POST card to help diagnose hardware issues
Sep 21, 2009. 10:58 PMEl Mano says:
Try and find AVG antivirus.
Jul 19, 2009. 7:40 AMsoinc16 says:
Maybe we should first practice it on a old,useless computer that somebody probably abandoned. Then,learn how to use a BIOS screen.That way,we don't end up paying them for a new computer. =)
Aug 20, 2009. 5:23 AMmhippo says:
Learning to fix anything has to start by learning how it's built. Dissection is a good way to learn, and for that you want one that's already dead. Once you can pull it apart and put it back together get a crappy old one that still sorta works so you can see if you put it together properly, and then you're ready to tentatively approach working ones.
Jun 20, 2009. 10:26 PMgobitz says:
I have seen a few people that thought they could fix someones computer problems thinking that it was gonna be easy.
The result?
I have to spend hours cleaning up the mess (more money for me though).
Leave this to the experts!
Dec 23, 2008. 7:13 PMmythbusterma says:
PLEASE dont go advising normal people to go into computer repair, alot of times the result is cataclysmic. Especially someone who doesnt know what their doing mucking in the BIOS. Just leave this to someone who knows their s*** (no offense)
Dec 24, 2008. 3:20 AM=SMART= says:
most of this stuff is basic problems, probably the most advanced is the hard drive defragging
Dec 24, 2008. 4:32 PMmythbusterma says:
umm NO the most advanced is messing with the BIOS
Dec 25, 2008. 6:13 AM=SMART= says:
well if you aren't really that experienced i doubt you would know enough to actually know what BIOS is, but as you said its not a good idea to mess with it
Dec 30, 2008. 12:42 PMsiman880 says:
if you are going to mess with the bios the only thing u should be doing with it is updating it
Dec 30, 2008. 5:48 PMmythbusterma says:
even thats dangerous if you dont know what youre doing
Jan 16, 2009. 5:30 PMA good name says:
(removed by author or community request)
Jan 16, 2009. 5:31 PMA good name says:
However the other stuff is basic, though it would be more effective to offer defragment as an added bonus to say, fixing an internet connection.
Jan 19, 2009. 4:45 PMA good name says:
Oi, why was my post removed?
Jan 19, 2009. 8:33 PMmythbusterma says:
idk it wasnt bad, i didnt flag it
Jan 18, 2009. 5:44 PMmythbusterma says:
or you could just teach them how to defrag it themselfs, which is what i do
Feb 22, 2009. 3:03 PMGamer917 says:
i am 13 and i have taken apart and rebuilt my laptop 4 times, I could probably make alot of $$$ fixing computers
Feb 23, 2009. 9:23 AMmythbusterma says:
im also 13 but ive only taken apart my laptop once ;) i havent needed to take it apart more but ive also taken apart my freinds, which is practicly identical. saved myself $80 when i opened mine
Feb 23, 2009. 2:16 PMGamer917 says:
I can tell that your like me , you like Mythbusters
Jun 25, 2009. 9:02 PMethiapath says:
if you know how to build a computer i think fixing\selling computers is a good idea. ha i like mythbusters too and am also 13. man macbook pro here i come!!!
Dec 27, 2008. 4:53 PMmythbusterma says:
well thats my point you tell them how to get there and then tell them to mess around in there on SOMEONE ELSES computer (no offense)
Dec 27, 2008. 4:52 PMmythbusterma says:
yes well thats my point, you tell them how to get there and then tell them to mess around there .....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:=SMART=
I make lots of different instructables, I make stuff i need or want, then show you ! ............................................See my profile for further awesomeness :) ..............................
more »
