3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Pan For Gold
Step 3Digging the Paydirt
Digging the Paydirt
Once you've found your perfect stream, you need to find a place to pan and places to dig. They almost certainly won't be terribly close to each other (remember about the exercise I mentioned?). A good place to pan is an area of the stream where the water is deep enough to completely submerge your pan, and has enough water flow to keep the water clear so you can see what you are doing. If the current is too strong though, you will find it difficult to work the pan.
Where to dig? Gold is heavy. It is a lot heavier than most of the other rocks and minerals in the stream. It takes a lot of force from the moving water to keep gold suspended in the water and move it along the stream bed. So anywhere the water slows down is where the heaviest stuff suspended in the water is most likely to settle out. The inside of bends is one place. Water flowing down a stream moves slower on the inside of a bend and faster on the outside. So heavy material is more likely to settle out on the inside of bends. Also, anything that disrupts the flow of the stream, like a big rock, will create eddies behind it where heavy material will settle out. Dig behind and under big rocks. Also, any cracks or crevasses in the rocks are likely to catch gold. Gold will fall into the cracks but be too heavy for the current to wash it out again. Gold, being so heavy, tends to always sink as low as it can in the stream bed. So digging down in the stream bed to solid and impervious bedrock is often a good way to find the gold. Just keep these thoughts in mind as you hit the stream.
More info on gold prospecting can be found on my web site at http://www.mdpub.com
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
265
Author:mdavis19
