Hpi Savage Roto-start One-way Bearing Fix
1,602
11
6
Posted
Introduction: Hpi Savage Roto-start One-way Bearing Fix
seized one-way bearing ? this fix will help save you money and get your savage back in action again .
Step 1: Items Needed
tools needed :
2mm,2.5mm and 3mm hex drivers /allen keys
treadlocker
pliers
heatgun
freezer
1/2" and 6mm sockets
and a hpi savage monster truck .
parts needed :
one way bearing (part no. HF0612) with a simple ebay search you should be able to get ten for ten bucks .
Step 2: Get to the Bearing .
first we need to get the engine out . to do this remove the throttle linkage off the carburetor , simply twist and it will pop off the ball stud. next remove the fuel tank which is held in place by two R clips .disconnect the fuel lines from carburetor and tuned pipe . then loosen set screw holding the tuned pipe .
Step 3: Flip It
flip your savage over . using a 3mm hex driver/allen key remove the four screws from the engine mount . unflip your savage and the engine should be able to pull right out .
Step 4: Remove the Pull or Rotostart
using a 2mm hexdriver remove the three screw holding the rotostart / pullstart to engine ,pull to remove exposing the one way bearing .slide bearing off to remove .
Step 5: Pressing Bearing Out of Nut .
place bearing in 1/2" socket. (note : use a 1/2 inch drive socket for this ) next using a socket withe the same or slightly smaller outside diameter as the bearing(i used a 6mm). press the bearing out of the holding nut using vice .
Step 6: Pressing New Bearing in .
place new bearing in freezer for ten or so minutes. hold holding nut in pliers, gently warm with heat gun . now remove cold bearing from freezer and press together .using pliers so as not to burn your fingers.
Step 7: Rebuild
rebuild your savage . follow steps in reverse order .
tips :
1 : remember that one way bearings are just that so if you put it in backwards it wont start, to test once rotostart backplate is on turn over engine . if it doesn't turn over ,flip the bearing 180 degrees.
2 :dont forget to mesh the clutch and spur gear with a piece of paper so it doesn't bind .
3: use treadlocker on any screws the go in to metal.
Step 8: Go Race
fuel up and go race .
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    6 Comments
    you know the easyst fix is just get a full one way bearing
    they are dirt cheap
    also it is healthyer for your engine to replace the roto for a pull starter
    (sorry for my grammar i am not native english)
    to buy the hpi part cost around $20 but to a new bearing to press in is only $1 . not sure how you figure this is cheaper . also pull and rotostarts both work the same way only rotostarts dont snap cords .
    any old 6 sided one way bearing would fit
    http://www.ebay.com/itm/12mm-Hex-One-Way-Bearing-Pull-Start-6mm-Shaft-RC-Parts-For-HPI-Savage-/291956303369?hash=item43f9f3a609:g:BSkAAOSwiDFYO~cN
    like this one
    i didnt mean to be harsh and stuff
    i was just wondering
    hi . thanks for the link. $3 for one in a holder is a better price but $1 and a bit of time to press a new bearing in is more fun and cheaper. ( could be my Scottish ancestors coming out in me )
    me as a stingy dutch guy should also want the cheapest
    but lazy as i am i take the easyest route
    nice instructable though
