Huawei E220 External Antenna +7db
6,449
18
Posted in TechnologyUsb
Introduction: Huawei E220 External Antenna +7db
A quick and easy hack to boost the signal on a E220 modem.
Parts required:
Huawei E220 modem. Warrenty will be voided ;)
Soldering Iron
Wire Strippers
Female SMA RF connector
7db omnidirectional magnetic base antenna with 3m cable (or what suits your price range). Mine was 200 Bucks. ($20)
     1: Remove the SIM tray and  faceplate covering the signal LED with a small screwdriver. (Plastic is better as not to scuff)
     2: Remove the Torx  screw just next to the LED and carefully unclip the cover.
     3: Once opened, remove the clear plastic standard antenna. Opposite to the USB port.
     4: Strip and solder the SMA cable to the pins where we removed the plastic antenna.
     5: Heat up a screwdriver with the same width as the tail, then melt a space for the cable to sit outside the housing.
     6: Put it all back together, test, then superglue.
I have kept the tail short so i can travel with the modded antenna.
Happy Hacking :)
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
