Human Body Induction Alarm Based on Arduino With Arduino UNO, Infrared Sensor Module,Buzzer Module
Published
Introduction: Human Body Induction Alarm Based on Arduino With Arduino UNO, Infrared Sensor Module,Buzzer Module
About: www.ICStation.com is a top store of electronic, which specializes in all kinds of IC products, such IC accessories, Module, Robots, Development Board, Transistor, Capacitor and so on. We're located in She...
ICStation team of research and development department have made this project about the human body induction alarm .It uses DC5V voltage to work. When someone is appearing in the inducing area of infrared sensor and the whole system will use both sound and light to alarm. The inducing distance is 7m.And it is a simple and cheap alarm which is suitable for a protection against burglars to home, office, warehouse and laboratory.
Features of human body induction alarm :
1.When the hardware initializes, the buzzer will sound and the LED lights will flicker.The whole process keeps for 3-5 seconds
2.If there is no one appearing in the inducing area of infrared sensor, the buzzer will not sound and the LED light will not flicker.
3.If there is someone appearing in the inducing area of infrared sensor, the buzzer will sound and the LED light will flicker.The alarm of both sound and light will keep for 5 seconds.
4.If there is someone appearing in the inducing area of infrared sensor and remain still, the alarm will stop after 5 seconds of sound and light alarm.And only when the human body is moving during the inducing area of infrared sensor and then will trigger the alarm again.
Code for reference:
www.icstation.com/images/Code/Human_Body_Induction.zip
Step 1: Components List
Step 2: Hardware Schematic Diagram
Step 3: Hardware Making Tutorials
Connect +5 power and GND to bread board. The red jumper wire uses as power line and black jumper wire use as ground wire.
Step 4: Put the Highlight LED Emitting Diode and Pin Header on the Bread Board
Step 5: Connect 2 PCS 3P Dupont Line to the Buzzer Module and Human Infrared Sensor Module
Step 6: Connect the Buzzer Module and Human Infrared Sensor Module to the Bread Board
Step 7: Connect the The Signal End
Connect the the signal end of highlight LED emitting diode, buzzer module and human infrared sensor module to the Arduino board
Step 8: Connect the Power End and Ground Wire End
Connect the power end and ground wire end of the components to the positive and negative pole of bread board
Step 9: The Video to Show the Effect
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    6 Discussions
    hi.i am a beginner. and for my project i need to detect only human.can i do that with pir sensor?Will pir detect any moving object too? If yes,then is there any to detect only human?
    Gohith
    1 year ago
    Error occurred while uploading code
    hi.. i know nothing about this circuit things but much interested to this idea.. can we just simply add more sensor and buzzer to this?
    Hi
    I want to turn on and turn off
    my LED table study lamp by moving my hand over a sensor. Hand over tuns
    on the light and hand over again to turn off the lamp. A very simple light switch actually. A simple one and as small as possible!!
    Do I need a infrared sensor and a
    flip flap?
    What do you suggest?
