Remove these ads by
Signing UpStep 1Motors and Encoders
The GM3 224:1 gearmotor and the GM14 Sanyo 297.1:1 gearmotors have seen the most action so far in our arm assembly. The GM3 (and the GM2, GM8 and GM9) are all similar, use the RM3 DC brushed servo motor and have plastic gears and housing. They all also have an output D-through- shaft that can couple to an encoder shaft. The regular output shaft is also easy to couple to and the motor is pretty easy to mount with two built-in mounting through-holes. They are capable of 50 in*oz of torque, with a kludge clutch rated at 60 in*oz and a weight of 1.31ounces. They cost ~ $6.00 each.
The GM14 is smaller, lighter and has metal gears. This is a very small motor, small enough to universally make people say ?cute? when they see it. It produces ~40 in*oz of torque and weighs .29 ounces. The output shaft has a flatted side, so it is easy to mount to, though there isn?t much shaft axially in general. Not particularly easy to mount but it does have some mounting holes and can be mounted by putting the whole motor in a rectangular recess. They cost ~ $25.00.
Both motors run on ~5VDC and draw current in the range of 100 ma to 600 ma.
I choose the U.S. Digital S4 miniature optical shaft encoder as the proprioceptive feedback device. This encoder is cheap, small, very accurate, comes in a number of resolutions, is easy to mount and can be purchased with a gear bearing shaft so the encoder can handle a substantial radial load. They cost ~ $45.00.
8
comments
Add Comment
Add Comment
