Materials (for two dehydrators):
3 1x6 3/4" 6-foot cedar boards (these are fencing boards in my area - I picked for few knots)
1 sheet of 8-foot galvanized ribbed roofing (is enough for 3 dehydrators)
2 yards of 36" aluminum flashing
2 32" x 32" storm windows (or other similar sized glass)
Matte black spray paint
2 yards of 36" aluminum screen
Staples
Galvanized nails (1 1/2")
1" finishing nails for drying screens
Tools:
Jigsaw with metal-cutting blade
Tin snips
Table saw with rip fence to produce frame elements
Stapler
Remove these ads by
Signing UpStep 1A Simpler List of Materials
Two years after initially publishing this Instructable, I found myself conducting a Saturday build of three smaller dehydrators with three friends of mine. I found 3 windows of the same size at the local Habitat ReStore and worked everything from there. I also wanted to get the three of them done in less than a day, so I went with materials that simplified things.
For each dehydrator:
1 24" x 27 3/4" storm door window
Dehydrator bottom: Aluminum flashing, white on one side, shiny on the other: 24" x 27 3/4" (no need to trim ribs)
Heat sink: Aluminum flashing, black on one side, white on the other: 22" x 26" (no need to paint)
Nylon screening: 24" x 30" (easier to work with than aluminum screening)
3 1" x 6" x 6' cedar boards: one ripped 3 1/2" wide (for top and bottom), one ripped 4" wide (for the sides), one ripped into 1" wide pieces (for tray frames). Once the pieces are cut for the box, rip the remainders into 1" wide pieces.
scrap 2" x 2" (about 4" - 6" long) for heat sink handle
1 1/4" galvanized spiral nails (for making the dehydrator trays)
1/4" staples
8 1 1/2" deck screws (to hold the outside box together)
For this size, the top and bottom were the 27 3/4" sides of the window.
Because the flashing doesn't have ribs, you'll have add "risers" to the long sides of the trays using scraps of the 1" wide pieces. The flashing is much easier to cut than galvanized roofing! We cut the screening oversize for the trays and found the nylon easier to stretch tight than aluminum screening; it was also easier to trim once the top pieces were nailed on.
We completed three dehydrators in 4 hours.
I asked myself however if you checked the temperature? I want to build a solar dryer for herbs and most plants should not be dried over 40 degrees celsius. Any expericence or ideas?
Using this dehydrator in south-eastern Ontario I routinely dry herbs and greens in it. On a day with full sun, a steady breeze from the south, moderate humidity (60 % or less), and air temps higher than 32 deg Celsius, I have had thin leaves begin to brown in the mid-afternoon when I've put them in in the early morning. That's an indication things are too hot. When those conditions occur, I either don't dry or I check things at noon and every couple of hours after that.
This dehydrator is not suitable for a low-humidity, extended high-temp climate (like the desert).
Best wishes!
Also, I didn't see you mention many vegetables that you dehydrate. I imagine that this will work for most, but will it work for carrots, celery, peas?
Check out books on dehydrating from your library or at Amazon. I got one, not so much for the electric dehydrator times, as for recommendations on how to cut up various things and if they should be blanched before drying them.
