Introduction: Humidity,Pressure and Temperature Computation Using BME280 and Photon Interfacing.
Picture of Humidity,Pressure and Temperature Computation Using BME280 and Photon Interfacing.
We come across various projects which require's temperature, pressure and humidity monitoring. Thus we realize that these parameters actually play a vital role in having an estimate of the working efficiency of a system at different atmospheric conditions. Both at the industrial level and personal systems an optimum temperature,humidity and barometric pressure level is requisite for the adequate performance of the system.
This is why we provide a complete tutorial on this sensor, in this tutorial we are going to explain the working of the BME280 humidity, pressure and temperature sensor with particle photon.
Step 1: BME280 Exploration
Picture of  BME280 Exploration
Electronic sector has stepped up their game with the BME280 sensor, an environmental sensor with temperature, barometric pressure and humidity! This sensor is great for all sorts of weather/environmental sensing and can even be used in I2C.
This precision sensor BME280 is the best sensing solution for measuring humidity with ±3% accuracy, barometric pressure with ±1 hPa absolute accuraccy, and temperature with ±1.0°C accuracy. Because pressure changes with altitude, and the pressure measurements are so good, you can also use it as an altimeter with ±1 meter or better accuracy!The temperature sensor has been optimized for the lowest noise and highest resolution and is used for temperature compensation of the pressure sensor and can also be used for estimation of ambient temperature. Measurements with the BME280 can be performed by the user or performed in regular intervals.
Datasheet : Click to preview or download the datasheet of BME280 sensor.
Step 2: Hardware Requirement List
Picture of Hardware Requirement List
We used entirely controleverything Parts because they're easy to use, and something about everything fitting nicely on a centimeter grid really gets us going. You can use whatever you want, but the wiring diagram will assume you're using these parts.
Step 3: Interfacing
Picture of Interfacing
The interfacing section basically explains the wiring connections required between the sensor and the particle photon. Ensuring correct connections is the basic necessity while working on any system for the desired output. So, the requisite connections are as follows:
The BME280 will work over I2C . Here is the example wiring diagram, demonstrating how to wire up each interface of the sensor. Out-of-the-box, the board is configured for an I2C interface, as such we recommend to use this interfacing if you’re otherwise agnostic. All you need is four wires! Only four connections are required Vcc, Gnd, SCL and SDA pins and these are connected with the help of I2C cable. These connections are demonstrated in the pictures above.
Step 4: Temperature, Pressure and Humidity Monitoring Code
Picture of Temperature, Pressure and Humidity Monitoring Code
The clean version of the code that we'll be using to run this is available HERE.
While using the sensor module with the arduino, we include application.h and spark_wiring_i2c.h library. "application.h" and spark_wiring_i2c.h library contains the functions which facilitate the i2c communication between the sensor and the particle.
Click HERE to open the webpage for device monitoring
Upload the code to your board and it should start working! All the data can be obtained on webpage as shown in picture.
Code is provided below:
// Distributed with a free-will license.
// Use it any way you want, profit or free, provided it fits in the licenses of its associated works. // BME280 // This code is designed to work with the BME280_I2CS I2C Mini Module available from ControlEverything.com. #include #include // BME280 I2C address is 0x76(108) #define Addr 0x76 double cTemp = 0, fTemp = 0, pressure = 0, humidity = 0; void setup() { // Set variable Particle.variable("i2cdevice", "BME280"); article.variable("cTemp", cTemp); Particle.variable("fTemp", fTemp); Particle.variable("pressure", pressure); Particle.variable("humidity", humidity); // Initialise I2C communication as MASTER Wire.begin(); // Initialise Serial communication, set baud rate = 9600 Serial.begin(9600); delay(300); } void loop() { unsigned int b1[24]; unsigned int data[8]; int dig_H1 = 0; for(int i = 0; i < 24; i++) { // Start I2C Transmission Wire.beginTransmission(Addr); // Select data register Wire.write((136+i)); // Stop I2C Transmission Wire.endTransmission(); // Request 1 byte of data Wire.requestFrom(Addr, 1); // Read 24 bytes of data if(Wire.available() == 1) { b1[i] = Wire.read(); } } // Convert the data // temp coefficents int dig_T1 = (b1[0] & 0xff) + ((b1[1] & 0xff) * 256); int dig_T2 = b1[2] + (b1[3] * 256); int dig_T3 = b1[4] + (b1[5] * 256); // pressure coefficents int dig_P1 = (b1[6] & 0xff) + ((b1[7] & 0xff ) * 256); int dig_P2 = b1[8] + (b1[9] * 256); int dig_P3 = b1[10] + (b1[11] * 256); int dig_P4 = b1[12] + (b1[13] * 256); int dig_P5 = b1[14] + (b1[15] * 256); int dig_P6 = b1[16] + (b1[17] * 256); int dig_P7 = b1[18] + (b1[19] * 256); int dig_P8 = b1[20] + (b1[21] * 256); int dig_P9 = b1[22] + (b1[23] * 256); for(int i = 0; i < 7; i++) { // Start I2C Transmission Wire.beginTransmission(Addr); // Select data register Wire.write((225+i)); // Stop I2C Transmission Wire.endTransmission(); // Request 1 byte of data Wire.requestFrom(Addr, 1); // Read 7 bytes of data if(Wire.available() == 1) { b1[i] = Wire.read(); } } // Convert the data // humidity coefficents int dig_H2 = b1[0] + (b1[1] * 256); int dig_H3 = b1[2] & 0xFF ; int dig_H4 = (b1[3] * 16) + (b1[4] & 0xF); int dig_H5 = (b1[4] / 16) + (b1[5] * 16); int dig_H6 = b1[6]; // Start I2C Transmission Wire.beginTransmission(Addr); // Select data register Wire.write(161); // Stop I2C Transmission Wire.endTransmission(); // Request 1 byte of data Wire.requestFrom(Addr, 1); // Read 1 byte of data if(Wire.available() == 1) { dig_H1 = Wire.read(); } // Start I2C Transmission Wire.beginTransmission(Addr); // Select control humidity register Wire.write(0xF2); // Humidity over sampling rate = 1 Wire.write(0x01); // Stop I2C Transmission Wire.endTransmission(); // Start I2C Transmission Wire.beginTransmission(Addr); // Select control measurement register Wire.write(0xF4); // Normal mode, temp and pressure over sampling rate = 1 Wire.write(0x27); // Stop I2C Transmission Wire.endTransmission(); // Start I2C Transmission Wire.beginTransmission(Addr); // Select config register Wire.write(0xF5); // Stand_by time = 1000ms Wire.write(0xA0); // Stop I2C Transmission Wire.endTransmission(); for(int i = 0; i < 8; i++) { // Start I2C Transmission Wire.beginTransmission(Addr); // Select data register Wire.write((247+i)); // Stop I2C Transmission Wire.endTransmission(); // Request 1 byte of data Wire.requestFrom(Addr, 1); // Read 8 bytes of data if(Wire.available() == 1) { data[i] = Wire.read(); } } // Convert pressure and temperature data to 19-bits long adc_p = (((long)(data[0] & 0xFF) * 65536) + ((long)(data[1] & 0xFF) * 256) + (long)(data[2] & 0xF0)) / 16; long adc_t = (((long)(data[3] & 0xFF) * 65536) + ((long)(data[4] & 0xFF) * 256) + (long)(data[5] & 0xF0)) / 16; // Convert the humidity data long adc_h = ((long)(data[6] & 0xFF) * 256 + (long)(data[7] & 0xFF)); // Temperature offset calculations double var1 = (((double)adc_t) / 16384.0 - ((double)dig_T1) / 1024.0) * ((double)dig_T2); double var2 = ((((double)adc_t) / 131072.0 - ((double)dig_T1) / 8192.0) * (((double)adc_t)/131072.0 - ((double)dig_T1)/8192.0)) * ((double)dig_T3); double t_fine = (long)(var1 + var2); double cTemp = (var1 + var2) / 5120.0; double fTemp = cTemp * 1.8 + 32; // Pressure offset calculations var1 = ((double)t_fine / 2.0) - 64000.0; var2 = var1 * var1 * ((double)dig_P6) / 32768.0; var2 = var2 + var1 * ((double)dig_P5) * 2.0; var2 = (var2 / 4.0) + (((double)dig_P4) * 65536.0); var1 = (((double) dig_P3) * var1 * var1 / 524288.0 + ((double) dig_P2) * var1) / 524288.0; var1 = (1.0 + var1 / 32768.0) * ((double)dig_P1); double p = 1048576.0 - (double)adc_p; p = (p - (var2 / 4096.0)) * 6250.0 / var1; var1 = ((double) dig_P9) * p * p / 2147483648.0; var2 = p * ((double) dig_P8) / 32768.0; double pressure = (p + (var1 + var2 + ((double)dig_P7)) / 16.0) / 100 ; // Humidity offset calculations double var_H = (((double)t_fine) - 76800.0); var_H = (adc_h - (dig_H4 * 64.0 + dig_H5 / 16384.0 * var_H)) * (dig_H2 / 65536.0 * (1.0 + dig_H6 / 67108864.0 * var_H * (1.0 + dig_H3 / 67108864.0 * var_H))); double humidity = var_H * (1.0 - dig_H1 * var_H / 524288.0); if(humidity > 100.0) { humidity = 100.0; } else if(humidity < 0.0) { humidity = 0.0; } // Output data to dashboard Particle.publish("Temperature in Celsius : ", String(cTemp)); Particle.publish("Temperature in Fahrenheit : ", String(fTemp)); Particle.publish("Pressure : ", String(pressure)); Particle.publish("Relative Humidity : ", String(humidity)); delay(1000); }
Step 5: Applications:
Picture of  Applications:
BME280 temperature, pressure and relative humidity sensor has various industrial applications like temperature monitoring, computer peripheral thermal protection, pressure monitoring in industry. We have also employed this sensor into weather station applications as well as greenhouse monitoring system.
Other applications may inculde:
  1. Context awareness, e.g. skin detection, room change detection.
  2. Fitness monitoring / well-being - Warning regarding dryness or high temperatures.
  3. Measurement of volume and air flow.
  4. Home automation control.
  5. Control heating, ventilation, air conditioning (HVAC).
  6. Internet of things.
  7. GPS enhancement (e.g. time-to-first-fix improvement, dead reckoning, slope detection).
  8. Indoor navigation (change of floor detection, elevator detection).
  9. Outdoor navigation, leisure and sports applications.
  10. Weather forecast.
  11. Vertical velocity indication (rise/sink speed)..
Step 6: Video Tutorial
Watch our video tutorial to go through all the steps in interfacing and completing the project.
Stay tuned for other sensor's interfacing and working blog's.
About This Instructable
838views
4favorites
Bio: We are a group of makers. We work in IoT, IOS app, android app, embedded design, sensor design, raspberry pi, arduino, beaglebone, particle electron, particle ... More »
More by Dcube Tech Ventures:Home Automation with Raspberry Pi using Relay boardMotion Control with Raspberry Pi and LIS3DHTR, 3-Axis Accelerometer, using Python3-Axis Accelerometer, ADXL345 with Raspberry Pi using Python
Add instructable to:
