Late this summer, hummingbirds finally began visiting the feeder we'd put up on our back porch. I wanted to try and get some digital shots of them, but couldn't stand there with a camera "in range"--they'd never come.
I needed a remote cable release so I could set the camera up on a tripod, aim it at the hummingbird feeder, and release the shutter from a distance away. Problem is, my camera, like most digital snapshooters, isn't equipped for remote shutter release.
Although an earlier instructible had a great hack for opening up the camera and tapping into its electronics, I didn't want to permanently modify my camera, and wasn't sure I would be able to do the surgery without damaging something.
So after some thought, I designed this simple fixture using low-tech parts readily available for $10 or less that allows you to leave your camera intact, but still allows you to "sneak" up on wildlife, have camera on elevated position, and other remote-shutter release situations.
Step 1: Design the Frame
The Hummingbird Shooter is basically a wooden frame that closely fits the camera body, that allows the piston of an "old fashioned" bulb release to be positioned over the shutter button of the camera.
I originally planned to have some sharp-pointed screws driven in toward the camera, which I planned to lightly tighten to hold the frame in place, but while building the device, thought of a better way. (more about that later)
My camera, a Canon Powershot A75, has no provision for remote releases, only the finger button in the center foreground of the photo below.
The first step was to measure how high and wide the camera was at the end where the shutter button was. Because of the "sculpted" shape of the camera body, there were a lot of humps curves, and other non-linear dimensions to contend with, so I just cut the wood pieces --1 inch wide pieces of 1/2 inch plywood to rough dimensions to start.
I also had to make note of where the various controls, sensors, etc. were located to be sure my frame would not interfere with them.
1-40 of 101Next »
jexter says: Jul 27, 2010. 9:52 PM
Late to this Instructable, but:
A - great job, very useful and well presented, and
B - "CAUTION ! Whenever drilling sheet metal, there is a tendency for the bit to "grab" the sheet metal from your grasp, making a wicked rotary knife that can slice you up pretty good."
This should be include in any Instructable that involves working with sheet-metal. I worked in a sheet metal shop in the summers of my high school years, worked in construction to put myself through college, and have working with sheet metal on various projects ever since. I'm 45, and as comfortable with sheet metal work as a seamstress is with cloth.
Six months ago I was mocking up a 3-axis sled for a camera mound, and ignored these basic facts:
1 - sheet metal edges are really REALLY sharp, and
2 - sheet metal tends to grab the drill bit and spin if not well secured.
I was in a hurry, and "just reaming out a hole a little", so I held the piece in my left hand against a wood backing plate and started to drill. I can't describe how fast that 2" x 1" piece of metal turned into a high-speed blade, slicing into the tip of my left index finger at least 5 or 6 times before I could get my hand out of the way (picture spiral cut ham!) .
The local clinic pulled it all together without any significant tissue loss, but it hurt like a mofo for weeks afterward, and I've lost most feeling in the tip of that finger, which is a lot more of a problem than you might think. And I was very lucky; I could have just as quickly lost that finger.
So keep trying out new ideas, and don't be afraid to try out new tools and materials, but always suit up and clamp down with the worst case scenario in mind. Let's be care out there!
beavercleaver in reply to jexterJul 31, 2011. 9:05 AM
Very good advice, I cut completely through my index finger, with just one eighth inch of the meat left intact, the feeling will return in your damaged digit over time.
lbrewer42 says: Mar 12, 2009. 5:20 AM
Just the other day I was just thinking of needing a cable release for my camera. It was a passing thought and I wondered why digital cameras do not come standard with this feature. I know the mechanism instead of mechanical and some cameras also have remotes. But a couple of slots molded into the case and positioned so you could have a small, clamp-on attachment for a cable release would be a good idea (maybe a selling point also?).
Makescreenname (author) in reply to lbrewer42May 22, 2010. 8:30 AM
I agree.  In fact, I don't see any reason digital cameras couldn't be configured like all the old SLR;s used to be--with a threaded cable release fitting right in the top of the shutter release button.**  Seems like it would only cost them a tiny bit to drill the hole and thread it.  Maybe they want you to upgrade to more expensive cameras that have wireless or other electronbic remote capabilities.  My little Canon supposedly is able to electronically release via the mini USB port, but I don't consider using a laptop or even my little netbook as a camera release accessory very convenient or logical.
**See Tord's comment of April 8.  Apparently Fuji "gets it".
Tord in reply to lbrewer42Apr 8, 2010. 2:37 PM
My Fuji S9000's release button is made for cable release - should work well for things like this!
struckbyanarrow says: Feb 13, 2010. 8:30 PM
i am totally going to make this but i might follow this design they sell online!
Makescreenname (author) in reply to struckbyanarrowMar 25, 2010. 7:12 PM
That's a nice rig.  Wish I 'd seen it sooner.  One problem for me is that I really don't have the metal-working equipment to do the precision work this device seems to require.  Probably could have gleaned a few ideas from it, though.
Thanks for sharing,
Happy Shooting!
struckbyanarrow in reply to MakescreennameMar 25, 2010. 7:54 PM
I collected random metal bits and pieces to build it, and it was fairly simple.
Soupraok says: May 22, 2009. 7:44 PM
what do you type in ebay to find this?
Makescreenname (author) in reply to SoupraokMar 25, 2010. 7:07 PM
Sorry for the delay in responding.  Try searching ebay with something like "air release", or "pneumatic release", "air remote shutter release", "pneumatic shutter release", something with those terms.  Specify the photographic equipment or cameras/equipment categories.
Happy shooting!
Crucio in reply to SoupraokSep 13, 2009. 11:06 PM
I'd like to know the search terms too, please.
Phil B in reply to SoupraokJun 1, 2009. 8:31 PM
I bought one of these in a camera store a couple of decades ago. It would be a squeeze bulb (pneumatic) remote shutter release, or some variation of that phrase.
guy90 says: Mar 25, 2010. 4:13 AM
Great upload, due to my lack of electrical skills' this rig seems simpler for me (Y)
flammel says: Nov 26, 2009. 11:57 AM
 Flash won't help at the distances you'll be shooting. You should use a faster shutter speed.
lilpepsikraker says: Nov 12, 2009. 9:23 AM
On the A75, I would use the 1/2000 shutter speed with the lowest f/ number (widest aperature). You don't need much in focus in that setup more than 5 feet or so, I'm guessing, so set it to manual focus too.
I personally never use flash outside unless I'm using it a fill flash, which is rarely.
The 4th Doctor says: Oct 25, 2009. 4:37 PM
just two changes would yield you much better pictures,use manual focus to lock onto the bird feeder, and set the shutterspeed as high it can go while still having a decently bright picture (maybe set up some kind of lighting or use flash)
you should be able to freeze the birds beating wing with something around 1/1000 of a second
cynical_chemical says: Jul 1, 2009. 3:50 PM
Check out my hummingbirds, there are pics up of them on my 'ible
http://www.instructables.com/id/Create-A-Color-Accented-Photo-In-Photoshop/
Coolboyme says: Jun 19, 2009. 9:45 PM
superb
woodgeek says: Jun 6, 2009. 3:48 PM
air cable shutter release will get a lot of hits.
conceptualstratagem says: Dec 19, 2007. 12:00 PM
Well I've almost completed my jerry rig, though it turned out to be some thing completely different than yours. I'm not interested in hummingbirds or nature photography, but knew this project was full of other potential uses. I've redesigned your bracket and added some features. The camera be set into the rig to prevent unwanted light from entering the lens. This rig will eventually hang from a custom crane attached to my work bench. Both of the cameras this works with have plastic tripod mounts, I suggest not to put any stress on these with a construction bracket, instead just sink a screw head bolt into the wood and use that as the tripod mount. Though this rig is still under completion, I thought its documentation might clear up some of the criticisms concerning its intended purpose. This works with Canon PowershotA75 and Nikon coolpix2100. I'm working on adding a power supply port because these cameras eat batteries. So far this has only taken me a day or so to make. Thanks Makescreenname I'm looking forward to reading your next instructable.
MizzMouse in reply to conceptualstratagemJun 2, 2009. 10:32 AM
wow, great modifications. Way to innovate!
mweston says: Jun 1, 2009. 7:53 PM
Just a tip - before you go to wait to snap a picture, focus on the metal pole or feeder part - press the button down half way, but don't take the shot. Right now it looks like its focusing on the leaves and not the bird, this should yield a better result and then you won't have to worry about the camera going out of focus when you squeeze the bulb.
zjharva says: Nov 21, 2008. 5:45 PM
Hey this is a great instructable! At first when i looked at it i though "how can you shoot a hummingbird?" and "what kind of a sick, cruel person would shoot a hummingbird?" and then i realized it was pictures! :D
DELETED_dannydutton says: Jun 25, 2007. 1:06 PM
(removed by author or community request)
girrrrrrr2 in reply to DELETED_dannyduttonJun 28, 2007. 3:53 PM
but how much meat would you get???
BastardMan in reply to girrrrrrr2Aug 9, 2007. 9:25 PM
Enough meat.
girrrrrrr2 in reply to BastardManAug 10, 2007. 12:51 AM
it would mostluy be tough... see the speed of the wings...
maker12 in reply to girrrrrrr2Feb 1, 2008. 3:35 PM
damm!
girrrrrrr2 in reply to maker12Oct 9, 2008. 7:52 PM
BRIDGE!!!
Bartboy says: Jun 14, 2008. 8:33 AM
The frame could be knex
Sandisk1duo in reply to BartboySep 28, 2008. 11:32 AM
pretty much ANYTHING can by made out of K'nex
thoraxe says: Mar 12, 2008. 5:46 PM
TREE HUGGER!
zpersichetti in reply to thoraxeJun 16, 2008. 3:11 PM
i hug trees a lot they smell good..........sumtimes i wonder if i deserve 2 be burned in a large drum of oil though
thoraxe in reply to zpersichettiJun 16, 2008. 4:03 PM
well we're saving them from being in a landfill until they rot to death. They get to fuel our forges, grills, and guns.
zpersichetti in reply to thoraxeJun 16, 2008. 5:36 PM
lol exactly
wolf555hound in reply to zpersichettiSep 9, 2008. 6:05 PM
hehehehe dont forget our furnaces to stay warm while we look at out bear heads form the guns =]
=SMART= says: Jun 18, 2008. 3:01 AM
wow very good!
halomaster117 says: Jun 6, 2008. 8:21 AM
i had a big red flower on a table and sat very still for 10 min. and i got to hold the humming bird in my hand
Keith-Kid says: Jun 4, 2008. 3:41 PM
I love it! I've been looking for something like this!
Doveman says: Jun 2, 2008. 10:29 AM
I should try this. Hummers swarm our house by the hundreds, serously. We have up about 20 feeders. Its so cool, I like to stand really still at a feeder and see a hummer really up close. We also like to sit near one, and hold a stick or a fishing rod out, hoping that a hummer will take the time to rest on the end. Its awsome!
1-40 of 101Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
