How to Make and Install Hungarian Shelves
 by juliofo
Featured
First time I saw these shelves was in Budapest, at a friends apartment. I was told they had been designed by a physicist. That's why I think they are safe. The ones in the photos have been up for more than a year now.
Step 1: The model 240 cm by 240 cm
This is just one model. You can personalize the design to fit your needs.
Step 2: The materials
For the model showed in Step1 the materials are:
4 sticks of pine of 240 cm by 5 cm by 6 cm (5 is front; 6 is deep) (photo1)
6 selves of DM of 240 cm by 22 cm by 3 cm (photo2)
4 wall metal peg screws to hold large weigths (one for each stick) (photo3)
12 regular wall plastic peg screws to hold medium weigths (three for each stick) (photo4)
Step 3: Cut off mortices on sticks and shelves
The whole set is assembled like pieces in a puzzle without glue or screws.
In the sticks make a mortice for every shelf.
In the shelves make a mortice for every stick.
In our case this means 6 mortices in each stick and 4 mortices in each shelf.
As a rule, in sticks make a mortice 2/3 deep of the side of the stick and in shelves make a mortice 1/3 deep of the side of the stick. (In the example this means 4 cm in sticks and 2 cm in shelves because the side of the stick is 6 cm).
Step 4: Hold vertical sticks on the wall
Use the strong screw in the middle of the stick.
Check verticality with a bubble level.
Fix the other 3 screws in every stick.
Step 5: Finishing
Once all the sticks are on the wall, assemble the shelves and VOILA! you have it done.
BUT THERE IS STILL ONE MORE THING...
PLEASE DO NOT MISS THIS DETAIL WHETHER YOU THINK IS IMPORTANT OR NOT!
The last thing to do is to insert wedges of wood under all the shelves and in every stick untill all the shelves are ortogonal (=perpendicular) (=90 degres) to the sticks.
Step 6: Another example
This is another one we made for a "used things" shop in our city.
It is 15 meters wide and 2,5 meters high with vertical sticks every 0,5 meters.
It was made with all kind of particles boards we had around.
As it can be seen in the photo it has no mortices in the selves --just in the vertical sticks-- and it works too.
1-40 of 269Next »
hottie_mchottson says: Feb 23, 2012. 8:17 AM
My super shelves are complete!! :-)
juliofo (author) in reply to hottie_mchottsonJun 1, 2012. 8:25 AM
Wonderful work!!!
Thank you so much for posting the pictures!!!
Spread the word.
Firstaccount in reply to hottie_mchottsonMay 24, 2012. 8:14 PM
Can you take a close up of the corner where they meet
hottie_mchottson in reply to FirstaccountMay 29, 2012. 6:03 AM
I will take some close ups when I get a chance but there really isn't much to see in the corner. The problem I ran into early in the project was that there wasn't a stud to screw into on the left side in the corner. So I just used the verticals you see to keep it even. The left side shelves extend all the way to the wall but aren't attached to anything there. The right side shelves just butt up to the left side shelves but also aren't attached to anything there either. I thought about doing a 45 degree cut at the corner but then you can't slide the shelves into grooves.
hottie_mchottson in reply to hottie_mchottsonMay 30, 2012. 7:58 AM
ok here are some more pics of the supershelves somewhat filled in with lots of nick nacks. I put the 6 foot ladder in to show some perspective as to how big they are since the previous picture just didn't seem to do justice to the actual size. Very boring corner shot included as promised. Also a close up of the beveled verticals for your viewing pleasure. Also I didn't do the little wedges on the bottom as stated in the instructable. I just cut them to exact size and then had to readjust some. Some were still pretty tight but nothing a good mallet couldn't handle. Ps. the house is for sale, shelves included lol
2012-05-29_23-53-36_473.jpg2012-05-29_23-52-07_418.jpg2012-05-29_23-51-40_827.jpg2012-05-29_23-51-14_531.jpg2012-05-29_23-50-24_730.jpg
Firstaccount in reply to hottie_mchottsonMay 31, 2012. 12:52 PM
Thanks!
mjursic in reply to hottie_mchottsonMar 31, 2012. 1:22 PM
These shelves are F%^&*ING awesome!!!!! I'm totally stealing this design for my difficult living room, which will become my difficult library.
juliofo (author) in reply to hottie_mchottsonFeb 23, 2012. 9:41 AM
Congratulations!!!
Very nice work.
Very nice picture.
Very nice comment.
Thanks a lot
hottie_mchottson in reply to hottie_mchottsonFeb 23, 2012. 8:23 AM
The verticals are 2x4's screwed directly into the studs. The horizontals are 1x8's and are not screwed in to anything. They are stained with General Finish brand water based stains Espresso (vertical) and Rosewood (horizontal) though they sort of just look black in the photo. Total cost ~$120 because I used the premium pine 1x8's. All in all a very easy project and lots of positive feedback from friends.
mjursic says: Mar 31, 2012. 1:22 PM
Great instructable! Love it! Going to make it!
AppalachiaAngel says: Mar 31, 2012. 12:37 PM
I am trying to design shelves that will be wall to wall and floor to ceiling because I am a grafter and have limited space in my bedroom, these look like an awesome idea, but I am such a clutz that I am afraid that I would end up knocking one of these shelves out....
TashaDax says: Dec 27, 2011. 2:35 AM
Holy mother of Tesla! This is awesome and beautiful and I love it to bits! I have a question though (since I'm too lazy to look through the previous comments):
Would this hold up on drywall?
wastubbs in reply to TashaDaxJan 22, 2012. 7:47 AM
It would be far more secure if you affix it to the stud and not just the drywall. If you're going into the drywall alone, the amount of weight will depend on the surface area of where the shelf pulls on the drywall. So if you use something called a Hollow Wall Anchor (http://www.johsoncn.com/hollow_wall_anchor.htm) instead of plastic wedge anchors, you're going to be MUCH better off.
juliofo (author) in reply to TashaDaxDec 27, 2011. 10:42 AM
Hi, Hi,
Yes and Yes.
There are solutions at the comments for drywalls.
Basically it consists in making to fit any (at least one) stick of the shelves with a stud of the wall.
Good luck (and post photos of your result).
agent_orage says: Feb 1, 2010. 1:26 PM
Thank you SO MUCH! for sharing this! This has to be the simplest, and by nature, most elegant shelving designs in history. :)
hottie_mchottson in reply to agent_orageJan 4, 2012. 1:28 PM
Freaking awesome! I'm totally doing these in my living room
clbarko in reply to agent_orageDec 12, 2011. 1:52 PM
Do you have plans for this awesome shelving? I have a room that this would
work perfectly in.
daemonkrog in reply to agent_orageOct 17, 2011. 7:15 PM
Wow, awesome job on that corner! That looks incredible!
agent_orage in reply to agent_orageOct 30, 2010. 11:28 AM
Hallway Closet. Removed the ancient sliding doors and built a similar version of the book case. On the 24" run on the left, instead of running a third vertical support, i used some of the 1 1/2" trim under neath to support the ends. As with the other shelf project, all i used was a drill, miter saw and a router. To make the mortise cuts in the vertical supports, i make multiple cuts halfway down into the 2x4 with the saw between my marks for the shelves. It doesn't produce a squared off notch, but the imperfections are well hidden by the shelves themselves. I always ensure i leave enough of a gap to get the wedges in well. A little DAP and paint, and short of an over critical eye, the impression is usually ..well impressive. Thanks gain Juliofo!
juliofo (author) in reply to agent_orageOct 30, 2010. 12:24 PM
Wonderful!!! Again. But don jet crazy with it, otherwise yogur people aré gong to hate me.
agent_orage in reply to juliofoNov 1, 2010. 10:10 AM
Well Juliofo, given the ikea shelves i put up in the bedroom closet have begun falling off the wall.... i have a couple more places to implement this design. ;)
janetcunningham4 in reply to agent_orageJul 4, 2010. 3:28 AM
I like the way the the shelf was designed here in this photo. I love the finished product when books are up there and the lights too, nice! This will be a great idea too for children's room so that they would have an organized room and encourage them to look and read books when they are bored playing. Great idea here.
agent_orage in reply to janetcunningham4Jul 13, 2010. 10:47 AM
Thanks :) I used 2x4's with 12"x3/4" MDF for the shelves. I trimmed the front edge of the shelves with some 1.5" flat molding to square up the look. Also i did not mortice the shelves, which provides a 3/4" gap at the back which makes hiding wiring really simple. :) Props again to Juliofo for this awesome post.
DIYerNeil in reply to agent_orageJul 13, 2010. 8:41 PM
You idea is really great and I would like these kinds of shelves installed inside my daughter's room, for her things to be more organized. In the living room, definitely. Oh and yes, how could I forget the small office I have at home. Thank you!
juliofo (author) in reply to agent_orageFeb 2, 2010. 3:33 AM
Wonderful!
Thanks for posting the photos.
jpollard3 says: Dec 27, 2011. 11:46 PM
This is what I've built. As a first woodworking project in my life, it was bloody time consuming. I've never worked with wood or a jigsaw. Heck, I do not have a work table! Cutting was interesting to say the least. Two sawhorses, 2 snapped planks, some blood, lots of sweat and paint and I was done!
It took a while to get the vertical wood pieces attached to the wall then some more time to get the horizontals to fit in again. I can't believe how sturdy it is!
I can't even fit a piece of paper into my joints. I had to use a hammer and a lot of brute force to get the horizontals fitting the verticals, so I had to skip that step. The thing is going nowhere!
juliofo (author) in reply to jpollard3Dec 28, 2011. 2:53 AM
Bravo!
Wonderful work.
I like much your low table solution for the shelve at the bottom. Is it on wheels?
jpollard3 in reply to juliofoDec 28, 2011. 3:13 AM
Nope, no wheels. Everything is bolted to the wall. The only difference I made is to use 2400 x 76 x 50 mm for the vertical and 2400 x 300 x 22 mm for the horizontal, so all the shelves are quite deep, but that makes it look less crowded in my opinion.
triumphman says: Dec 27, 2011. 2:35 PM
a dovetail joint would be nice , but not easily applied to the shelves.
triumphman says: Dec 27, 2011. 2:30 PM
Are the wedges thin triangular pieces of wood? The whole thing stands without screwing the shelves to the sticks? And heavy books don't collapse it? Wow!
mikola.tibor says: Nov 18, 2011. 6:14 PM
Hali! tuti polc! Ezt meg is barkácsolom :) köszi
juliofo (author) in reply to mikola.tiborNov 19, 2011. 9:01 AM
Thank to you for your comment but post pictures of your set up whenever possible.
noeleonoel says: Dec 3, 2005. 3:47 AM
Wouldn't it make more sense to drill and screw from the back of the vertical rails through each mortice? This may even eliminate the need to wedge. Would make it harder to install though as you would have to lift the shelf weight as well as the vertical rails when attaching it to the wall. Also would require that the to wall screws be visible.
juliofo (author) in reply to noeleonoelOct 29, 2011. 1:47 AM
Hi noeleonoel,
I am sorry but it is not a good idea. The whole desing is based on structural simplicity. And puting screws to hold the selves to the sticks would destroy this simplicity. Furthermore, mortices + wedges is much much stronger than screws.
Hatredman in reply to noeleonoelOct 28, 2011. 3:18 PM
If you are installing it in a narrow corridor (my house is small, the only space I have for a library is the corridor leading to the kitchen) you can't assemble the whole thing first and then hang it on the wall.
But yes, eliminating the need to wedge would be desirable. Wedging is rocket science for a clumsy dude like me.
juliofo (author) in reply to HatredmanOct 29, 2011. 2:05 AM
Hi Hatredman,
Unfortunately the desing does not allow to eliminate the need of mortices (which is the most dificult part of this construction). And the wedges are there because of the mortices. In a platonic world wedges wouldn't be needed at all because mortices and surfaces would be perfect (a.k.a platonic). Wedges are introduced because we all are human and then imperfect (as our constructions are), and wedges is a very efficient way (after Archimedes) of filling up gaps; (as when we put a folded paper under a table leg).
On the other hand I do not give credit to your statement of not being able to deal with wedges because "wedges are the solution to us, the clumsy ones".
Try again and post photos, please.
leander37 says: Oct 13, 2011. 8:01 PM
Built these in living room and kitchen. 2x3 CVG Fir uprights and 2x12 #2 Pine cut down to 11" for shelves. 3" wood screws in dado and 4" wood screws 1/2 way between each shelf. Heavy duty anchors at top of bigger shelf because it extends past stud into truss area...
Thanks for a great inspiration, this is a great design... You can see the %$#y IKEA shelf that I was replacing on the left - what an improvement!
So many dado cuts on my table saw and the balde got dull... on 2nd to last cut, it snagged and banged me hard in the chest. Watch out because dado cuts are like cutting 100s of boards, so replace the blade if it seems dull!
juliofo (author) in reply to leander37Oct 14, 2011. 1:12 AM
great job!
Thanks so much for the pictures and info.
mattolsend says: Sep 25, 2011. 3:48 PM
I used this design to build 2 bookshelves this month. One at my apartment, the other at a friends place. Both came out great. I used toggle wall anchors to hold the shelves to the drywall. I used a handsaw and chisel to make the mortices. Dimensions are aprox. 8' X 4' X 1'. Thanks for posting this instructable!
juliofo (author) in reply to mattolsendSep 26, 2011. 12:10 AM
Thank you! for sharing your experience. Wonderfull mount, wonderfull photos.
1-40 of 269Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
