3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make and Install Hungarian Shelves
Step 4Hold vertical sticks on the wall
Use the strong screw in the middle of the stick.
Check verticality with a bubble level.
Fix the other 3 screws in every stick.
5 comments
Nov 18, 2011. 6:14 PMmikola.tibor says:
Hali! tuti polc! Ezt meg is barkácsolom :) köszi
Apr 6, 2010. 3:34 PMjvercilo says:
Hi. I know this guide has been here for some time, but I've just found it. And I have a doubt about step 4: do you fix all the screws in the mortices? I ask this because in step 5 theres a drawing of a screw above the mortice. So, which one is right?
Thanks a lot for the guide, I'll try to build one of these as soon as I move to my new apartment!
Oct 27, 2010. 10:17 AMGoedjn says:
If you put the screws into the mortices, you can use shorter screws, and
the screwheads are hidden by the shelves. If you put the screws above and below, you pretty much eliminate any chance of the weight on the shelf
splitting the risers.
May 12, 2010. 5:58 PMVictor Neuberg says:
If you're still wanting to do this, I screwed mine directly into the mortices.  Just make sure you have a long enough bit to get inside the mortice.  And I pre-drilled the holes in the mortice and used wide head screws so it doesn't stress the wood so bad.  Good luck!  It's really fun!
Apr 11, 2010. 3:04 PMjvercilo says:
Juliofo, thanks a lot for the reponse. I'll sure post some photos, but unfortunately it'll take a while until I actually get the chance to build it. Cheers!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:juliofo
I try to be a happy man
