GoodCleanCrazy
Find two photos of faces in similar poses. Mine are below. Guy#1 and Guy#2.
Gaussian blur one image with a 10-20 pixel radius. (Photoshop 6 and Gimp command: Filter>Blur>Gaussian Blur) This filter spreads around the pixel data in the image. The resulting blurry image lacks clarity, but it is full of color and life. It is the foundation of the image. This is basically the "low spatial frequencies" of that image.
High Pass the second image with a slightly smaller radius than you used for the Gaussian blur.
(Photoshop 6 command: Filter>Other>High Pass)
(Gimp command: Duplicate the layer. Top Layer: Filters>Blur>Gaussian Blur. Layer>Colors>Invert. Change the opacity to 50%. Layer>Merge Down.)
The "high pass" image lacks color and life, but has clarity. It is the fine details of the image, and it feels flat without a foundation. This is basically only the "high spatial frequencies" of the same image.
Remove these ads by
Signing UpStep 1Mix and Match
Take the "high frequency" image and set it to "Overlay" mode in a layer above the "low frequency" image.
You now have a hybrid image! Congratulations! What can you do with a hybrid image?
From several feet away, you can only discern the low frequencies of an image. The high frequencies become apparent as you approach the image. Thus you could hide one image in another from distant prying eyes.
It seems to work best to combine images with similar features (faces work great). The mind's perceptions of low and high frequencies and our parafovial sensitivity to low frequency information explains why the Mona Lisa appears to be smiling when you look slightly away from her.
More examples and explanations can be found here.
4
comments
Add Comment
royalestel (author)
says:
Add Comment
