3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hybrid solar panel (photovoltaic and thermal)
Some time ago I bought some PV cells (6"x3", from rebeccayi0904 on ebay, very nice seller!) with intention of building a PV panel (after reading a plaethora of instructables on solar panels here!).  While testing the individual cells out there in the sun I noticed that they got quite hot.  I then realized that PV panels convert to electricity only about 12% of the solar power that gets to them.  What about the rest?  It becomes heat (about 88%).  I figured that perhaps in the same surface one can harness both the electricity and the thermal energy of the panel....
Step 1Overall panel characteristics, items, etc.
I am not going to repeat all the details on how to build a solar panel, there are plenty of other instructables for this (search tool is your friend!).  I will give some basics, though... and then focus more on the "hybrid" nature of my panel (PV + thermal).
General characteristics:
- about 0.5 m^2 area, at a maximum of 1 kW/m^2 of irradiation and 12% efficiency this should produce UP TO 60 W of electrical power.  (at the same time this means that about 440 W of thermal power could potentially be harnessed!).
Materials:
- 36 cells, 3"x6".   Cost:  about $150 from rebeccayi0904 (ebay, nice seller!) for 80 cells (used 36 for this panel).
- aluminum backplate (26"x32", can't remember thickness):  about $10 in a sheetmetal store.
- small roll of Begquist sil-pad 400, cost about $50 from ebay (can't remember seller)
- glass front cover, about $15 at the hardware store
- aluminum rails for borders, about $12 at the hardware store
- about 25 feet of 1/4" copper pipe, about $20 at the hardware store
- some 2-3 tubs of silicone caulk
- aluminum flux paste from McMaster-Carr (about $30, but you can buy a smaller quantity, I only used about 1/20 of the tub)
- solder
- a 12 V water pump, search on ebay "12 V pump laser & cpu cooling", cost about $10.
Caution: Aluminum Flux Paste is a very nasty material.  It contains fluoride and if handled improperly it can cause serious harm to you.  Read all instructions and the material safety data sheet (MSDS), and if you are not 100% confident that you can work safely, do not.
127 comments
1-40 of 127next »
Jun 2, 2011. 1:01 PMjdarrington says:
I recently had an commercial energy audit done in my home and one of the things they mentioned was looking into getting a solar panel or two to reduce my use of natural gas. I've been looking into it and I run into a problem, one that is evident in the photo above. Solar panels aren't very aesthetically pleasing. Is there anything that can be done to improve the aesthetics of solar panels?
Aug 3, 2011. 8:15 PMmcarrell says:
Can you tell me what exactly is "dis"-pleasing about them? I really wish you could describe in detail what it is you object to about them because a local h.o.a. forbid its members to install them for the same reason (yet water panels, not PV were OK.. why?)...If we could understand this phobia of the looks of PV panels, maybe we could do something to make it less objectionable to those who find it revolting....
If it's the color, there isn't much that can be done about that without infringing on the panel's efficiency... They must admit all the blue light they can which means red to match roof tiles or green to match trees is out of the question. But purple or cyan might be possible..... :)
What's interesting is that the removal of heat from the thermal section should actually help act as an active cooler for the PV section, BOOSTing its efficiency!
Dec 31, 2011. 2:22 PMsnotty says:
Environmental apocalypse is pretty ugly too.
Sometimes I wonder if we hesitate to be sustainable because changing our ways would mean we've doing something wrong. If we kill for oil in Iraq, perhaps subconsciously we must believe this was the correct thing to do; otherwise we would be accessory to murder. And that's an uncomfortable conclusion where cognitive dissonance kicks in. Thus we choose coal and nuclear over wind and solar. Which is ugly? Which is pretty?
Just a theory.
Oct 7, 2011. 12:26 AMsolaralternatives says:
However, if you paint the copper black you shouldn't have that problem, plus you'll have the added benefit of even more efficient heat transfer.
Dec 13, 2011. 8:29 PMservant74 says:
Did you figure how much additional electricity you get from the PV with the 'cooled' vs 'not cooled' use?
Cooling the PV is supposed to allow them to be more efficient.
Thanks ... Jack
Dec 1, 2011. 9:52 AMdrbill says:
When the water heats up are the tubes on the back of the voltaic section hot as well?
If they are hot then where is the cooling advantage?
I just don't see it.
May 14, 2010. 12:11 PMpatenaude says:
 It seems like mixing copper and aluminium is going to cause corrosion problems... probably on the aluminum. I would also assume that the aluminum backplane is electrically connected to one leg or the other of the cell, meaning you might be shorting all the cells together, wouldn't you?
May 14, 2010. 12:13 PMpatenaude says:
Oops, I just spotted the sil-pad... so that's taken care of, but I'm still concerned about corrosion.
Aug 28, 2011. 10:04 AMsolaralternatives says:
Why not use stainless steel scrap sheets? Better heat transmission capability. Even though greater weight, can be thinner as its a much stronger material.
Oct 6, 2011. 3:13 PMwww.microbike.ie says:
aluminium or even better copper are much better heat conductors than SS..
Oct 7, 2011. 12:22 AMsolaralternatives says:
Oct 6, 2011. 11:48 PMsolaralternatives says:
In even slightly damp conditions, copper is very prone to corrosion, so aluminum or stainless is preferable.
Sep 3, 2010. 11:42 PMshastalore says:
Great idea!
I've always noticed that those solar panels really heated up in the sun, but never considered harnessing that extra heat to produce hot water. Wow! It'll be fun to see how this bright idea develops and spreads.
One tip: With my trusty little HotPot solar cooker, I could sometimes force through 3 gallons of ambient temperature water, to boiling, on a given day. But the real challenge was keeping that hard-earned water hot.
And those commonly used stainless steel vacuum bottles just can't hold their heat for more than a couple of hours. You see, the neck of a stainless steel vacuum bottle is a serious design/materials flaw that allows heat to escape.
But glass-lined vacuum bottles, although fragile, can really hold their heat. For example, a typical 3 liter pump action airport pot, full of boiling hot water, will still be:
   - Scalding hot 24 hours later.
   - Hot 48 hours later.
   - Warm 72 hours later.
And several 3-liter glass-lined vacuum easy-to-use airport pots can be conveniently distributed to the kitchen, dining room, bathroom, and easily loaned out to a neighbor.
As boiling hot water has to usually be mixed with equal amounts of cold tap water, in most tasks, a 3-liter vacuum bottle goes a long way:  My wife washed and rinsed a large batch of dishes using only one 3-liter vacuum bottle of hot water -and the windows of the kitchen completely fogged up. That is testimony to the tremendous amount of energy stored in those bottles. And even unused warm water can be dumped back into the solar cooker, taking only half the time to bring back to boiling.
Aug 11, 2011. 1:09 AMbuddhawhisper says:
I'm fairly new at all this...no...I'm really new. Just one question. what is a 3 liter pump action airport pot and where do I find one? thanks.
Nov 26, 2010. 3:55 PMGreat Wight Ninja says:
Rather than trying to store the water, what my High School electronics teacher did with his solar heating panel was that he heated a reservoir, which was also sourced by his house's water heater. The solar heat reduced his water heater usage by doing a sizable part of the heating and was supplemented by the other heater when there was high use to keep the reservoir hot.
As an adaptation to your HotPot, you could try "recharging" you're already hot water since it would get up to temp faster than tap water. If you already have warm water from before, you shouldn't need as much newly heated water. Mixing leftover and tap would also speed up the heating process.
One draw back is that you then have to keep track of when the reheated water reaches the desired temperature to switch to the next batch.
Jun 27, 2011. 10:22 PMmikesnyd says:
You are right with the right solder you cna acomplish this but i think you would have been more successful with brazing the copper pipe to aluminum. Faster less fumes and no flux needed. Check this instructable out. http://www.instructables.com/id/Quick-and-easy-brazing-aluminum-copper-and-nonfer/
I really like your ideas so far. Nice instructable.
Apr 13, 2011. 8:59 AMbahi says:
This instructable shows the potential of solar based energy sources.
I wonder why there is no comercial product available using your dual
concept.
I tried to find something on the web, and this could interest you
http://www.websesame.co.uk/wp8.pdf
It's the DESIGN OF A DUAL FLOW PHOTOVOLTAIC/THERMAL COMBI PANEL.
Mar 27, 2011. 7:53 AMMechanic2011 says:
You won't know for sure how a particular panel will perform until you build it and test it like this instructable shows .
By the way great instructable !!
IF a person had the regular type of flat plate solar collection system already then it is possible that the lower level heat coming from this type of panel could be used to preheat the coolant going to the flat plate collectors providing you built enough of these to get the coolant flow rates that you need for 2 arrays plumbed in series.
Run it through this type pf panel first then to the flat plate collectors.
You could even use the same pumps and not have to add any.
I just wonder though if a person would need more pump volume (i.e. a multiple speed pump) on a really good solar collection day to increase the flow a bit so as not to overheat any of the panels?
I guess I'll find out when I build it.
As long as the home built panels are to be used for things off-grid then there won't be any legal issues with certifications on the photovoltaic panels hooked to the power grid.
Mar 27, 2011. 7:39 AMMechanic2011 says:
Wow this is a great instructable !!
Thank you for posting it .
I have been looking for for one like this .
I want to build from scratch a whole array of these types of panels.
If you have a good thermal conversion/extraction from this panel , you might be able to get around 800 BTU per day/square foot of collector.
I have one question the though , wouldn't it be better to use 3/8" copper tubing ?
From 1/4" to 3/8" tubing would increase your flow of coolant 2.25 times.
I realize the coolant will have to flow through it slowly to pick up the heat but if I have a whole bunch of these on an array together then the flow becomes an issue.
What do you think ?
Feb 4, 2011. 3:41 PMFoxtrot70 says:
Love the Instructable, a friend of mine is overhauling the tracking system on his photovoltaics I suggested this Instructable to him. With the back panels as you show the tubing, better heat transfer can be accomplished by brazing the tubing to the aluminum. Another method of heat transfer would be to use a series of aluminum angles brased to the back side, this would give more surface area for air to pass and improve cooling.
Jan 23, 2011. 12:26 PMMacOSJoey says:
Great instructable! One idea: Run the pipes inside of the panel instead of behind it. I know you don't really have a lot of room on this panel, but if you made more room and had the pipes run alongside the cells (assuming you don't have any leaks), you should be fine and have hotter water.
May 13, 2010. 8:27 AMdimovi says:
I don't know how useful that heat is, however the solar panel is going to be more efficient the colder it runs. So, you should see if the heat you remove from the panel improves your efficiency enough to justify a water pump.
Dec 2, 2010. 4:50 PMdevonfletch says:
Of course, if you put the storage tank HIGHER than the top of the absorption system it will self-circulate, ( simple convection) and automatically stop circulation when the sun goes down, and the collector is the coldest part...this leaves the opportunity to harvest the hot water (take a shower). No need to process the power/energy any further. Hot water is a pretty expensive commodity, energy-intensive (carbon-polluting!) and it's by far the best way to harvest solar energy. Twin-walled polycarbonate roofing is a much larger and more durable example of the soft real-estate sign material. It should only be sealed using a neutral-curing silicone. I used Polyurethane (Sika-Flex) on a project, and it caused bad cracking of the Polycarbonate. Also, I'd check possible leaching of nasties from the polycarbonate, and any other plastics in the system.
Using a convection circulation, you would need to use considerably larger pipes.
Nov 27, 2010. 11:58 AMbethehammer says:
With sizeable enough system you could also recirculate it through an under floor network of tubing to provide radiant heat as well as just warm water for consuming.
Nov 27, 2010. 11:49 AMbethehammer says:
nice... solar power and heat exchanger... the water is not only heated but carries heat away from the solar cells, theoretically making them more efficient. this is a great start however you may want to put more "loops" of copper... perhaps using fittings rather than bending, or utilizing the pre-moulded panels used for solar water systems..
Nov 18, 2010. 2:01 PMvontzy says:
Carlos1w, there is another Instructable entitled "Solar-Thermal-Water-Heater-For-Less-Than-Five-Dollars" that might offer a less expensive way to collect the Heat from your PV array. Instead of getting the heat from the Sun the $5 Collector could absorb the heat from the PV array. The Copper Pipe alone, in your parts list, is $20. Love your instructable and hope merging the two ideas coulds save some bucks.
Oct 13, 2010. 11:49 AMSkyriam says:
Great idea and concept, congratulations!! One question: How exactly do you harness the heat of the water? You could also use peltier plates, although they are quite expensive for large builds like this. Thanks!
May 13, 2010. 10:04 AMevad says:
While I know aluminum is cheaper than copper sheet,  you might end up (after a number of years?) with the aluminum being eaten away by being in contact with the copper.  On the galvanic scale, copper is up near the top, one of the most  "noble" metals.  Aluminum is way low on the scale, (ignoble?) down below steel.  With condensation as an electrolite, or even humidity, a potential (voltage) is set up between the two metals, and eventually, the aluminum will begin to disappear via galvanic corrosion- basically, all three make a (weak) battery.
I'd be curious to know if there is a voltage present:  put your voltmeter on the millivolt DC scale, one probe on the copper and one on the aluminum, and see what voltage you get out.
Jun 16, 2010. 8:45 AMtrebuchet03 says:
Late to reply, I know.... Galvanic corrosion will occur even in the uV (microvolt) range... BUT, in practice, you needn't be worried. Something else will likely fail first ;) A pertinent example of dissimilar metal contact is the cheaply made mini fridge... If you were to take one apart (which I DO NOT recommend - you must destroy it due to the assembly process used) - you'll find copper tubing being used as the condenser in contact with the sheet metal (low grade steel) enclosure. Now if you were using a steel bolt in an aluminum fixture that needed to be taken apart frequently - then yes, it's something to consider ;)
May 14, 2010. 9:49 PMevad says:
I'd say it's not happening...  As I said, you need three elements- the two dissimilar metals, and an electrolite like rain, or humidity.  I  should  qualify my statement by saying it would be more prone to happening if the unit was constantly outside. But, you seem to have it covered up pretty good.
I live near the ocean, and have a steel boat trailer... About 6 years ago, I repainted it,.  I used some stainless steel hardware here and there, and where the screw heads touch the steel, the steel is rusting around the head- not bad, but, I will replace them with steel this summer.
And I forgot to say- Nice project!
Jun 16, 2010. 8:40 AMkmpres says:
Interesting project, and well documented. Your attention to detail is just what I need to help me decide if I want to go ahead with a similar project. I have often thought of combining heat and PV in the same panel but have been discouraged by the fragility of the cells. The last thing I would want to have to do is to take down the panels from my roof (a very difficult task in my case) because of a leak or rain water got in and corrupted or shorted the cells. The panels should be rigid enough to eliminate the effects of thermal expansion and parts degradation and sealed enough to prevent water infestation. Commercial solar panels are usually maintenance free for 20 years or more but they're still too inefficient (12% isn't breaking any records these days) and still too expensive, so, I will wait for the efficiency to approach the cells used on satellites (about 35%) and the prices to drop. Also, .2mm is indeed thin, about the thinness of two sheets of printer paper. A good substrate is imperative for such a panel to last 20 years or more. You've a good start. I look forward to reading about improvements to your design.
May 22, 2010. 11:19 PMdanbenedix says:
 Why not take the heat you are moving and run it across some peltier (thermoelectric) coolers.  These are the modules used in those iceless coolers.  This is my recollection of how they work.
When current is applied one side gets and one side gets cold to change the hot and cold side just swap the polarity.
Here is the neat part.  If heat or cold is applied they will generate current.
So since you are already capturing the heat and have a system setup to flow electricity why not tie the peltiers back to the inverter?
1-40 of 127next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:carlos1w
