3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hybrid solar panel (photovoltaic and thermal)
Step 2Building the heat exchange system
Photo 1: Soldering 1/4" (~0.5 cm) flexible copper pipe to the Aluminum backplate. The backplate is about 0.80 m x 0.65 m. I used about 7 m of pipe. Make sure you use the proper tool to bend the pipe to avoid pinching it off! The Al. plate cost about $10. The pipe about $20.
Photo 2: I thought it was impossible to solder to aluminum. Incorrect! You need the right FLUX. I bought this from McMaster-Carr for about $30. Notes: 1) buy a smaller pot, this was way more than I needed. 2) Be careful, this stuff is nasty: it has Fl and breathing its vapors or touching is NOT recommended!
Photo 3: Here my friend Martin is soldering the pipe and plate. Note that we worked outside, there was a good breeze and we used some protection!
Photo 4: End-result: will not win a soldering contest but was not bad for our first time soldering aluminum...
Photo 5:
Close-up of the solder job...  Could be better, eh?
4 comments
Jun 27, 2011. 10:22 PMmikesnyd says:
You are right with the right solder you cna acomplish this but i think you would have been more successful with brazing the copper pipe to aluminum. Faster less fumes and no flux needed. Check this instructable out. http://www.instructables.com/id/Quick-and-easy-brazing-aluminum-copper-and-nonfer/
I really like your ideas so far. Nice instructable.
May 14, 2010. 8:13 AMefootprint says:
Is it possible to just get an old coil from the back of an old refrigerator and use it?
May 14, 2010. 8:52 AMgrimgroper says:
 possibly... but dont release the refrigerant gass!!!
May 13, 2010. 6:34 AMShiftlock says:
Perhaps you should have traced the pipe's shape onto the Al sheet, brushed the flux onto the path, then pre-melted the solder along the path.  Then you could have tinned the entire copper pipe and simply joined them together with the heat of a propane torch.  I think that would have created a continuous contact point, and made it a lot neater.  It probably would have been quicker and easier than soldering a bunch of contact points as well.
May 13, 2010. 6:14 AMchrwei says:
what about using a thermal epoxy instead?  might cost more, but it would be a lot easier to control and cover the full contact point of the pipe to the sheet
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:carlos1w
