3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hybrid solar panel (photovoltaic and thermal)
Step 3Gluing the PV cells
Gluing the PV cells
The aluminum needs to be covered by some electrical insulator (I used Begquist sil-pad 400, cost about $50) because the backside of the PV cells is one of the elctrodes. Sil-pad is a decent thermal conductor too, but I presume that tar-paper would have worked OK too and would be much cheaper! The PV cells are 15 cm x 7.5 cm, and this pane will use 36 cells. I bought the cells on ebay from rebeccayi0904 (nice!) at $150 for 76 cells (used ~1/2 of those for this panel). The cells need to be connected in series (how are your soldering skills?) and then I glued them to the sil-pad using silicone caulk. BE CAREFUL: the PV cells are only 0.20 mm thick and break if you look at them too hard!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:carlos1w
