3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hybrid solar panel (photovoltaic and thermal)
Step 6Testing water pump and pipes
Photo 1: Testing the water system. Note that pump (12 V, bought on ebay for ~ $10) is powered by one half of the solar panel (generating ~ 9 V).  The plastic pipes were recycled from an old medical condition!
Photo 2: Water is circulating! This day was cloudy and 1/2 of the PV panel was only generating 4 V (should be over 9 V on a sunny day!).
Photo 3: cool guy in the "mirror" :-)
Photo 4: water circulates between the panel and a small cooler, will do some calorimetry later to check the thermal output of the system. (not enough sunlight this day...)
3 comments
Nov 27, 2010. 11:49 AMbethehammer says:
nice... solar power and heat exchanger... the water is not only heated but carries heat away from the solar cells, theoretically making them more efficient. this is a great start however you may want to put more "loops" of copper... perhaps using fittings rather than bending, or utilizing the pre-moulded panels used for solar water systems..
May 13, 2010. 9:29 PMden316a says:
why not just raise the water tank above the panel add a angle and allow convention currents to move the water and allow reheating  to a usable temp
May 8, 2010. 10:00 PMtweeterorhs says:
I do not understand exactly what the output of the thermal portion is. Hot water? If not what and where did you link the two systems (PV and thermal) to produce energy?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:carlos1w
