Step 8Two days of real testing (May/5 and May/6)
Photo 1: First day of real testing (May/5). Half of the panel is powering some 12 V halogen lamps. Connecting 1 lamp this half panel was providing 9.3 V at 1.47 A (power = 14 W), connecting 2 lamps the voltage dropped to 7.9 V at 2.69 A (power = 21 W). Extrapolating to the whole panel this would be at least 42 W of electrical power (not too bad for doing this experiment at 4:30 pm, considering that the theoretical maximum for this panel is 60 W, assuming 1 kW/m^2 solar power and 12% efficiency of the PV system). The other half of the PV panel powers the water pum, which makes water circulate between the panel and the cooler. There was 3 kg of water in the system.
Photo 2 and Photo 3: Results from May/5. Given water's heat capacity [4.2 kJ/(C kg)], one can conclude that the thermal power transferred was about 200 W maximum (again not bad considering that the panel received at most 500 W of solar light!). Note that I am neglecting possible other possible heat transfers (cooler, etc). See the second day of experiments below. The max. temperature reached was 52 C (126 F). Quite hot to the touch!
Photo 4 and Photo 5: Results from May/6. Second day of experimentation. Again I used 3 kg of water in the cooler. Note that at the 94 minute I turned off the water pump and the water started to cool off (at an energy loss rate of ~ 56 W). See the next picture. I estimated that in the "more stable" region of temperature rise the thermal power was about 210 W. This day the solar flux was similar, notice that the electrical power for 2 lamps was almost the same as the previous day. Also notice that connecting 3 lamps in parallel reduces the net electrical power: this is an important factor when designing a complete PV system, you need to optimize the IV operational point! In the plot, the very high rate of temperature rise in the first few minutes is probably an artifact of having used cold water rather (BTW: the air temperature was about 24 C). At the 94 minute I turned off the water pump and the water started to cool off (at an energy loss rate of ~ 56 W). Notice that as happened before the maximum temperature was about 52 C (126 F).
By the way great instructable !!
IF a person had the regular type of flat plate solar collection system already then it is possible that the lower level heat coming from this type of panel could be used to preheat the coolant going to the flat plate collectors providing you built enough of these to get the coolant flow rates that you need for 2 arrays plumbed in series.
Run it through this type pf panel first then to the flat plate collectors.
You could even use the same pumps and not have to add any.
I just wonder though if a person would need more pump volume (i.e. a multiple speed pump) on a really good solar collection day to increase the flow a bit so as not to overheat any of the panels?
I guess I'll find out when I build it.
As long as the home built panels are to be used for things off-grid then there won't be any legal issues with certifications on the photovoltaic panels hooked to the power grid.
1) I used the thinner pipes because they were easier to bend and cheaper (I had already spent much more than I had planned, note: it is possible to use a cheaper insulator than the sil-pad if you are careful enough even tar paper will do). For this size panel I think that the 1/4" tubing is sufficient (I think it is hard to believe one will be able to collect more than 50% of the sun light). If anything, I would have liked to use a thicker aluminum backplate (wasn't patient enough to wait for one, and this is the thickest I could source locally). Another thing would be to place the pipes closer together.
2) For larger panels you may want to have larger water flow to avoid the chance of it heating too much (at which point your heat capture would drop drastically). If you have several panels, I would probably connect the pipes in parallel rather than series, again because once the water becomes too hot your heat capture will be reduced.
3) Please check my comment on "May 14, 2010. 7:31 PM" about aluminum extruded panels. I think these are used for the side walls of 18-wheeler trucks and maybe are not too expensive if you can source them (I couldn't). This will be the best option (no soldering, best water flow, best thermal connection, probably quite good rigidity).
4) Also, please check my comment on "Nov 14, 2010. 3:01 PM" about aluminum and copper brazing without flux. I bought some of these products on ebay and they work great (and no nasty fumes, or at least not that I could tell). Note that you do need to get the materials quite hot for this technique to work (hotter than tin soldering).
5) Please give me an update (even better, post an instructable and put the link here) when you build your system!!!
Using a convection circulation, you would need to use considerably larger pipes.
When current is applied one side gets and one side gets cold to change the hot and cold side just swap the polarity.
Here is the neat part. If heat or cold is applied they will generate current.
So since you are already capturing the heat and have a system setup to flow electricity why not tie the peltiers back to the inverter?
excellent craftsmanship.
i would very much like to see if there is a difference with and without the pump on say 30 gal of water
Well, it would take some time (with this 0.5 m^2 panel) to get 30 gal up to 52 C (several hours). If you think about it, it is not so bad. In 1 day you get enough hot water for a shower. Alternatively, one should get a bigger panel!
Someone correct me if I'm wrong.
