3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hydoponic garden - Gravity feed
Join Instructables ( Free) and you can view this instructable on one page.
What are hydroponics?
Well quite simply, this is a method of growing plants with out soil, the plants roots are in direct contact with the nutrient solution. (nutrient minerals dissolved in water)
At their essential basic hydroponic systems are just another method by which to grow plants, but unlike the soil out doors, this method allows you to control and maximise the requirements of life in order to maximise end result.
How you maximise the conditions and requirements of the plants (food, pest and disease control) dictates whether you plants are truely organic or not. For the purpose of this instructable (and any thing I have my hands in !) it will be totally organic!
Step 1Outline - My Passive Gravity fed system
This instructable defines a system of hydroponics that is gravity feed, and provided you keep the nutrient tanks full, you only need to monitor plant health, occasionally maintain the system and chomp the end product. It is based in a small glass house, but has been run successfully inside on a window sill and in a conservatory also.
All references to "fig...." refer to the individual photos on below each page(each is labelled in the yellow squares)
In order for a plant to grow ( just like us..) it has 5 basic needs;
a.) Water supply (we supply)
b.) Food supply ( dissolved nutrient solution)
c) Light for photosynthesis ( Mr sun)
d) Temperature management (seasons + extension being in glass house)
e) Gas exchange ( Mrs nature)
.All instructions are based on my materials locally available - you will need to adapt them to yours.
You will need;
- Rectangle section hydroponic tray tube with end caps ( you can get it pre drilled too)
-(or standard guttering with end caps)
-Rubber grommets to suit tubing used 13mm & 4mm
- a grommet, and tap to match the size of pipe you wish to use for the drain pipe( 30cm of pipe) (hardware - irrigation supplies)(the pipe i use being 13mm irrigation hose)
- '''Autopot Smart valve Mk 11''' ( thanks to: Clive who read this instructable and found this far more reasonable supplier of smart valves!)
- 4mm tubing (Bunnings hardware irrigation supplies)
- 4mm tap (Bunnings hardware irrigation supplies or aquarium shop)
- 20 Lt plastic Jerry can
- Materials and construction tools to make a light prove box over Jerry (timber, screws, saw, drill, screwdriver in my case)
- Nutrient concentrate + tap I buy mine in 5 litre containers.(fit with a tap and decant in to one litre bottles for ease of us.)
- Hydroponic tray tube (100 x 75) you can also get tube tray with holes ready cut or standard house gutter.
- Plastic gutter PVC solvent cement
- File
-Hack saw / power saw
- Drill press ( ideal) or power drill
- Drill bits
- Drill saw (or method for drilling out circles of plastic)
- Inner tube band
- Gib board plastic corner lengths
-Cutters
- Self taping screws - four per tray
- Builders long level
- EC meter(Conductivity/TDS)
-Wooden wedges - 30 - 60 degree ( 4x per tray)
- Growing media - expanded clay balls
- Weight (quarter a brick )
44 comments
1-40 of 44next »
Dec 18, 2010. 11:45 PMhotstuff666 says:
wat chemical would i use for capsakin strawberries and tomato please reply asp thanks
May 21, 2011. 12:54 AMhotstuff666 says:
thank you that helped so much
Mar 30, 2011. 3:29 PMBrainchigger1 says:
Is organic fish dirt ( from under the bottom filter ) any where near as good as store bought fertilizer for aquaculture. This is what I was going to use, but I have no idea about the ppm, pH and so on. Interesting, instructional, answered many of my questions.
Mar 31, 2011. 11:32 AMBrainchigger1 says:
All the filtered dirt and Bactria found under the under gravel filter, Very fine and fluffy material.
Feb 18, 2011. 4:11 PMPizzapie500 says:
Where do you get nutrients and expanded clay balls?
Oct 1, 2010. 4:18 AManandsa says:
hi, Some nice information, but can you tell me what chemical you used? i would like to maintain a pH between 5.5 -6.5. i wanna plant lettuce.
Sep 10, 2009. 11:14 PMreitaka18 says:
Hi; Just another question. I got some smart valves sent up to me from the manufacturer; but they didn't have any covers. Do the covers come with them? or do you have to buy them separately? Can the smartvalves work ok without the covers? Thanks
Sep 8, 2009. 4:15 AMreitaka18 says:
Hi; Thanks for the great instructible. I was wondering what do you do with the drain tube; ie how often do you have to drain it. Thanks
Jun 14, 2009. 4:32 PMranger24 says:
If you go to this site www.buyhydroponicsupplies.com you can buy the smart valve for $20.
Sep 19, 2008. 9:30 PMjovation says:
Hydroponic has its advantages - but if you're looking for taste, plants grown in fertile soil in season, with the right amounts of compost or humus, are superior. Even potted plants with this mix (if you don't have a garden) will give you better results in this respect.
Oct 6, 2008. 7:37 PMfiremosca says:
I totally agree. Since I work in the green industry I've been privy to different growing techniques and from personal experience NOTHING tastes better than a fruit/veggie that has been grown in contact with the Earth...
Sep 21, 2008. 9:06 AMjovation says:
As I said - hydroponics has its advantages. The fact that you live in an urban area does not necessarily mean you can't set aside some room for potted plants (in the same way you do for a hydroponic system) - the question is always priorities. And yes, I have tasted hydroponic vegetables that have been grown in mixtures such as you demonstrate - I have not found them to be as good as same grown in fertile soil. But perhaps I will yet encounter an excellent hydroponic grower that will persuade me otherwise. Taste is a subjective matter, anyway, and will always be something to argue about... Thanks for the instructable!
Sep 23, 2008. 7:58 PMstatic says:
LOL "taste", is a subjective matter I agree. In regards to hydroponically grown vegetables, have any blind taste comparisons ever been conducted? That should take the subjectivity out of the issue.
Sep 14, 2008. 7:30 AMdigital0129 says:
Hey, very nice Instructable. When you start the flow of water, how thick is the stream of water? Also, do you find that the plants have a hard time being transported from soil into a water environment?
Sep 14, 2008. 4:53 PMdigital0129 says:
Sorry I wasn't clear. I was asking about the water level in the bottom of the gutter.
Sep 20, 2008. 1:12 AMCeefa says:
Hi Agatornz, I enjoyed your instructable. Well done. I have been growing in hydroponics for some time but never heard of the smart valve. Your instructable makes me want to experiment with them. It make the whole job so easy. I am in Christchurch NZ and from your name I guess you're in NZ too. Do you still have to buy the valves from Aussie or are they available in NZ. If so how much are they and where can they be purchased.
Sep 19, 2008. 4:45 PMMikePri37 says:
ok no offense but itsnt the point of a hydroponic garden to grow using containers and watter not soil or clay
Sep 18, 2008. 4:38 PMReade says:
Hey, this is a very detailed Instructable and it is clear you put a lot of work into the article but it could use some revisions to make it more accessible. For example, there are many parenthetical remarks; some of which that interrupt the flow of the sentence and I had to read that paragraph several times to get it. e.g.: "The key thing about this valve that makes it so darn annoying (wish I could think of a way to do the same thing) as I have to buy them from overseas currently)" Also, you have your own step sequence that contradicts Instructables numbering sequence (step 3Water Supply - step one) Finally, you could make some of the images clearer (not the one of your hand injury, thank you very much!)
Sep 14, 2008. 11:02 AMSteveGerber says:
MAJOR TYPO: Your title has a misspelling: Hydoponic should be Hydroponic (Feel free to delete this comment after correcting.)
Sep 12, 2008. 6:26 PMchalky says:
WOW! this is more like the HYDROPONIC BIBLE:) im just getting into this and i find this 'ible' priceless so thanks. ps/what did your strawbs taste like?
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:agatornz
