The hydrogen gas cutter uses only water and electricity to create an extremely hot flame that can be used for welding and cutting. i came up with the idea when my dad showed me a hydrogen gas generator that people commonly use for increasing there cars mileage. i though, why no put a braising tip on the end of a pipe connected to the gas chamber to create a flame.
***disclaimer***
i will take no responsibility for what you do with this invention, it can be dangerous if used incorrectly or irresponsibly
(i always wanted to do a disclaimer )
Step 1: What you need
firstly, to build it this is what you
a fluid tight container (i made mine out of perspex)
if making a perspex container then a grinder or cutter of some sort
a power source (i used a car battery 12v 20amp hours, u could use a power supply, but straight 240/110v is to dangerous)
stainless/galvenised steel sheet
wires
a vice (can be useful)
rubber hose/tube (i used 6mm)
copper tube (a little shorter than a hand) or braising head
hot glue gun (and glue of course)
spacers bout 1-2 mm (u can use washer, o-rings, wat ever)
silicon glue
soldering iron & solder
drill
2 bolts/ thick screws
peach container, jam jar ect
conductive leads
matches
baking soda
water
now your ready to build!
sdfgeoff says: Feb 1, 2013. 8:11 PM
Sealed it with solder! Doesn't the solder re-melt when you use it?
Chocolate Moose says: Jul 18, 2012. 9:01 AM
Great intstructable
I've seen hho/ hydrogen torches for sale and most of them offer something to put in the bubbler water to make the flame visible. Would you suggest doing the same with this set up? Would adding powdered metal (copper, magnesium, iron etc...) Be beneficial?
makincoolstuff (author) in reply to Chocolate MooseAug 17, 2012. 8:56 PM
i havent heard of people trying to make the flame visible but i guess you could try bubbling it through salty water or mineral turpentine. i have heard of people bubbling through acetone though, something to do with increasing weld quality
gabdab says: Aug 3, 2012. 6:22 AM
What thickness can it weld ?
Blo0dZsTa says: Dec 19, 2011. 3:04 AM
was wondering do you use this yourself?? and this looks really kool lol you taught me how to make hydrogen 0.0.....
tyeo098 says: Apr 18, 2011. 10:56 AM
Show us some pics of it lit up!
makincoolstuff (author) in reply to tyeo098Jul 10, 2011. 3:22 AM
it is in the main pic
killbox says: Apr 28, 2011. 9:45 PM
Hydrogen wont collect much, its so light it goes right to the roof, and small enough molecule it will get out and head for space.
rickharris says: Apr 18, 2011. 6:36 AM
How much hydrogen are you producing?
How are you separating the hydrogen and oxygen that is generated?
You may want/need to uprate your flash back arrestor.
HHO is very explosive and even the small amount in your bubbler could give you a nasty surprise.
If someone wanted to repeat this you would have to give a lot more detail about your project. Ideally show it at work.
And finally the idea has been around for a long time and is commercially exploited.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
