Hydrogen Peroxide Backyard Experiment
1,714
9
Published
Introduction: Hydrogen Peroxide Backyard Experiment
Step 1: Supplies
Whatever you want to mix with hydrogen peroxide I use the following:
1. Household surface cleaning spray
2. Spray sunscreen
3. Antibacterial hand soap
4. Water
Essentials:
1. Hydrogen peroxide
2. Four clean bowls for mixing
3. Dirty Brick or stone outside
4. Gloves
5. You should probably wear a mask because the vapors may be toxic
Step 2: Mixing
1. Put the substances you are going to mix with the hydrogen peroxide In the separate bowls
2. Pour the hydrogen peroxide in with them
Step 3: See the Fizz
Pour the mixtures onto the stone one at a time and in between pouring on the mixtures rinse well with water to have accurate results
The mixtures will fizz and you can see which one fizzes the most
Step 4: Take It to the Next Level
You can play the ratios of hydrogen to the other substances and you can try more substances
Another experiment you could conduct with hydrogen peroxide is using different objects to see which one got bleached the most
Step 5: Follow Me, Like, and Check Out My YouTube Channel EmiSkate
Bye and thanks for viewing!!:)
Comment on which one fizzed the most and tell me if there is anything wrong
:) :) :) :D
    • Stick It! Contest
      Stick It! Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    2 Comments
