Unfortunately, in my house, the pump that controls the water flow and the thermostats around the house that control the fans are independent of each other. This circuit is an initial attempt to get the fans and water pump to coordinate their activity so that the house can be heated properly. The fans and water pump on the first floor are usually on at the same time since their respective thermostats are right next to each other. The upstairs is a totally different story. If the room is too cold, the fan comes on whether hot water is flowing or not. Since the pump isn't usually on, this means that the fan is just wasting electricity and blowing cold air. For now this circuit simply keeps the fan from coming on in this scenario. In future versions, I hope to add some sort of mechanism for this controller to tell the pump to turn on.
This is work in progress and dangerous because it deals with AC control. If you decide to build this, proceed at your own risk.
Remove these ads by
Signing UpStep 1Controller circuit board
I will repeat the warning that most people use for transformerless power supplies. They are dangerous because they are not isolated from the main. I've included a fuse and a surge protector in the circuit to help mitigate risks. The power supply design is based of several examples on the internet as well as one in a UL approved thermostat that I took apart. I used this type of power supply for space & cost reasons. It needs to be cheap and small enough to fit in the wall next to my heating fans. Proceed at your own risk.
The triac circuit is copied directly from the MOC3031M datasheet. The MOC3031M is an opto-isolator that sits between the microcontroller and the triac controlling the fan.
The microcontroller part of the circuit is a very simple. It monitors the pipe temperature using a 10k thermistor that is connected to an analog input pin. It uses a digital output pin to turn the fan on and off. The microcontroller firmware is very straight forward. It periodically measures the temperature and turns the fan on if the temperature is high enough. If the temperature drops below a certain level the fan is turned off. The code uses hysteresis to prevent the fan from turning on and off rapidly.
comments
Add Comment
Add Comment
