Step 10Cap the ends
You only want to glue in one half of the cap pair at a time, as the hose will push outwards and pop the cap off otherwise.
Line the caps up so the drain hose is at the bottom, and the other end goes to the top of the next pipe.
This way, when the water flows, it will splash around more, dissolving more oxygen into the water, which is important for the plant's roots.
The blue stuff I'm using is a plumber's cement.
A friend gave it to me, it is about a decade out of date, but we aren't doing anything too important here, so it does the job just fine.
You want to paint it on liberally on both the pipe, and the inside of the end cap.
Push the end cap on, and make sure you have the hose lined up right, hold the end cap firm for about 5 minutes while it sets.
You need to give it a day to fully dry properly before you complete the other join.
comment
Add Comment
NathanWilliams (author)
says:
Add Comment
