3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hydroponic Food Factory
Step 15Water & Potato bins
Water & Potato bins
The water and potato bins need the exact same modifications, so just do the following twice.
Drill a hole big enough for the hose to squeeze through (you should have some practice in this by now!)
You want the hole as low as possible, so you can drain out as much water as you can.
Hook the metal wire, and silicon seal the joint just like you did for the end caps.
The potato bin will simply drain back into the small reservoir, while the water bin will need to be hooked up to a float valve.
You can either buy a side entry float valve, or even better, just follow my instructable on how to make a very cheap one here: Hydroponics Float Valve
I'll go into more depth on mounting the float valve later
2 comments
Apr 29, 2009. 5:05 PMcementbrains says:
My hobby has been hydroponics for many years..Very nice homebuilt system . Keep up the good work ill be following along with you ...
Apr 23, 2009. 11:19 AMarirang777 says:
I am totally amazed, let me keep reading...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:NathanWilliams
Software engineer, using electronics and micro controllers as a hobby to keep me sane!
