3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hydroponic Food Factory
Step 21Update 2 - Nutrients
Some comments below made me realise I was a bit lacking on the nutrients section, so I thought I should clear some things up.
Hydroponics needs special nutrients, normal fertilisers won't work.
In dirt, there are a lot of microbes, that break down things such as manure to produce the elements plants need.
In hydroponics though, there are no microbes, so we need to give the plants the elements they need directly, no middlemen (or is that middle-microbes?).
Hydroponics nutrients can come in different mixes for different stages of plant growth.
If you really want to get into hydroponics seriously, you will eventually use different mixes for the veggative and flowering stages. These will be more fine tuned to what your plants need, but they need more attention to detail, so you switch them at the right times for best results.
Personally I just want this as a hobby, not a full time job, so I am going for a general all round mix, which will give good results, but probably not the absolute best results.
Make sure you flush your reservoir as per the previous step.
Now mix your nutrients as per the instructions.
My box gives instructions for 100 litres, but I only wanted to fill my 20 litre bucket (not the 60 litre tank).
So, I divided the instructions by 5, and then mixed it into a 2 litre bottle (it was easier to shake!)
After it is well mixed up, pour it into your reservoir and then top it up with fresh water.
Turn your pump back on and your plants will be happy :)
4 comments
Aug 18, 2009. 10:23 PMkingyun says:
Great instructable! I was inspired and I even went and gathered the parts today. After four hours of toiling around diligently, I've finished one 4 inch diameter tube capable of holding four 16oz plastic cups. I didnt use garden hose however, as I found something similiar and cheaper. Its transparent though, so I dont know if this will effect the plant growth.
Also while shopping for the parts at home depot, I found multiple water test kits. Heres the link to one of them. http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10051&catalogId=10053&N=5yc1vZ1xh3&R=100176532
Apr 30, 2009. 7:30 PMalways2bfaithful says:
This is the first article I've ever really read on Hydroponics, so this is probably a stupid question. Why can't you drink the water? Is it unsafe? I myself have no desire to do such, but I do have pets who aren't as discriminating. Also, I thought I saw a comment on here that said something about fish. I'm assuming they were talking about using water from a fish tank in a hydroponic system as opposed to using the commercial nutrients you've shown here. Or were they suggesting using the two hand in hand? Could fish actually live in the water you mixed? One last thing. I loved your tutorial. It was very informative and well put together. I was hooked to the end, and am very pleased to see that you even included updates in your plants progress. Thanks so much for sharing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:NathanWilliams
Software engineer, using electronics and micro controllers as a hobby to keep me sane!
