Step 5Making the cut
This will give you a safe area to cut in.
Get a piece of tape, and run it along the pipe, making a straight line.
It doesn't need to be perfect, but you will need the cups to line up for the most part.
Now, move the template along this line, making a mark in the two holes.
When you move to the second spot, line the first hole up with the mark left by the template.
Do this the whole way along.
When you are done, remove the tape, and go back and draw in the circles.
I used a black CD marker, but anything that will draw on PVC pipes will do.
Now, get your drill bit ready!
Drill small holes to mark out the circle.
The closer they are, they easier the next step is.
Now push your drill bit, slowly from hole to hole, just connect the dots until the middle drops out.
The result is a bit rough, but put a cup in, and figure out what needs cleaning up.
Get your dremmel tool, with a grinding head and clean up the hole until the cup fits as you wanted it too.
This is messy, don't breath in while you do it, protect your eyes, and expect to look a bit like a snowman by the end of it all!
Do this for all your pipe.
My two strawberry pipes, I did 10 cups in each.
The other two, I wanted more spacing (for the lettuce for example), so I put only 3 cups in, equally spaced.
5
comments
Add Comment
jeff-o
says:
NathanWilliams (author)
says:
Add Comment
