Hydroponic Window Farm
6,351
72
6
Posted
Introduction: Hydroponic Window Farm
This is my latest version for an 8 plants airlift hydroponic window farm system. after many trials this system is an upgrade for the V3 airlift system that can be found on windowfarm.org and the Israeli window farm version.
The main difference in this window farm is the new way of cutting the bottles which eliminates the need of hard cone drilling at the bottom of the bottle and also eliminates the need for a swinging suspension system!!!
Step 1: Get the Stuff...
once you get all the tools and materials right, building this window farm will be a piece of cake:
2 X outlet air pump 3.5 W or stronger
4 X one way air valve
19 feet - 7/4 mm black PVC irrigation pipe (0.27 in)
2 X two way irrigation connector
2 X T irrigation connector
spray paint
one hole puncher
15 zip ties
2 shelf brackets
8 plastic pots (3.5 inch)
0.264 gal/ 2 liter - hydroponic media turf or clay pallets.
irrigation hole puncher (optional)
drill
utility knife,
paint mask
you can see all the stuff in the following you tube
Step 2: Build Your Window Farm
important notes after you've seen the tutorial
before you begin, make a test with one bottle and one pot just to make sure they fit right (i am using Schweppes bottles with 3.5 inch pots). you want the pot to sit tightly in the middle of the cut growing bottle. we want to leave some space for root development...
if you have allot of sun i recommend painting the bottles in a darker
color because the white paint always allows some light in. f
Step 3: Where to Hang It?
even the best window farm in the world won't grow in the dark...make sure you hang it in a sunny window or sun facing wall on your balcony. and if you have a greenhouse...you'll be amazed
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    5 Comments
    Hi,
    I have tried to build it however the 'one way air valve' coming out of the bottle will pass air if i blow in ok, but will not pass water out, so basicly water not going out from the bottle because of this,
    any idea way?
    (i use blue air valve like in your video clip)
    Hi! Have you ever gotten an answer to this question? I'm worried about the same thing ...
    Hey Barkan, nice design. I'm giving this approach a go. I was wondering if you had a template you could post for the actual cut of the bottles? Hoping I can print out the template, do the cut out, then use the cut out for tracing on the bottles.
