3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hydroponic float system
This is a completely passive hydroponic float system suitable for fast growing crops in cool weather
Step 1Here's a list of what you'll need
a container
a piece of 1.5 to 2" sheet styrofoam cut to fit your container
a 2.5" hole saw
foam cups
Jiffy peat pellets
water
nutrients
seeds
42 comments
1-40 of 42next »
Jan 17, 2008. 5:10 PMgijoes2000 says:
I have an inground spa that I am not using as such and was wondering if I could apply a Hydroponics usage to it? I would like to grow some vegetables but really do not know if it will work by doing it in a spa - I do have a filtration system and blower but no heater. Any advice would be welcome!! Thank You!
Nov 14, 2008. 1:33 AMCeefa says:
Hi gijoes2000, If I had an inground spa that I wasn't using I'd be looking at aquaponics - keep fish in the spa and recycle the fish water through the hydroponics beds to provide the nutrients for the plant growth and at the same time clean and aerate the water for the fish. Google aquaponics and have a look at it. This instructable is awesome and my suggestion is not to steer you away from doing it but rather to open up the possibility to you of a greater use for your redundant spa. Ceefa
Oct 5, 2011. 8:14 AMpellefson says:
I've been looking into Aquaponics also, and that's a great idea!!! You can get free spa's on craigs list all day long if you have the means to pick one up and move it.... hell, you could build a nice landscape of rocks and plants around the spa, fish in the spa, and beds of plants all around it... a perfect circle!!! i love it!!!!!!
Jul 15, 2008. 11:34 AMVicinSea says:
I have seen this system used in a child's wading pool($6.00 at WalMart). I don't see any reason your spa wouldn't work except you will need to run it on low pressure with no filters. That would keep the fluid nicely aerated. I imagine that just running the pumps would be fairly cheap. In the winter you could run the heat too, at the lowest level. Tomatoes, especially would love that. Eggplants and peppers would also.
Wading Pools
Jul 23, 2010. 7:21 AMAhmos says:
very nice
Jun 14, 2009. 9:59 AMGeronima B Angeles says:
I wonder why containers used in simple hydroponic system are always plastics and not transparent glass. Can I possible used transparent glass for me to view the growth of the roots?
Sep 17, 2009. 12:41 PMlcotta says:
Yep, roots don't like light, and also lots of nice, warm, and nutrients-filled tap water, if exposed to light, is the perfect algae growing medium.
Jun 15, 2009. 7:44 PMja.dzado says:
From the reading I have done I have found that plant roots do not like the light and the plant will not be healthy if the roots are subjected to lots of light.
Jun 15, 2009. 9:34 AMSelcSilverhand says:
From what I understand most people use solid containers vs transparent ones because it hinders algae growth. The algae needs sunlight to grow and if you have a solid colored container it keeps the light out. You could use a transparent container if you had a way to cover it up when you aren't looking at the roots. If you used an old fish tank for example, just find some black paper and tape it up on all sides. Then pull the front sheet off when you want to look at it.
May 11, 2008. 9:06 PMwilson.joe says:
using miracle grow or peters 20-20-20.. you ever really look at the contents in miracle grow? a nice trace of arsenic for openers. besides miracle grow by itself wouldn't grow crap without the nutrients its missing that soil already has. I would prefer to use something like Iguana Juice from my local hydroponic store, its all organic and contains everything that is required for healthy plants without the toxins in miracle-grow that appear to be a something concocted by someone wanting to dispose of nuclear waste without building up a landfill, spread it around the world why not.. Im sorry If one is going to go all out green they need to remove miracle grow from their diet.. especially if one is what they eat.. .Great system by the way..
Jun 15, 2009. 7:47 PMja.dzado says:
lol. arsenic is nuclear waste. lol.
Mar 31, 2009. 3:55 PMwilson.joe says:
those peat pellets for perfect size of 2 inch net cups... and it might be a hybrid system but by the looks of things it works quiet well..
Mar 20, 2008. 9:48 AMxfirexstarzx says:
Out of curiosity, what is the epsom salt for? is it to prevent root rot? This is an awesome instructable! I tried this and the lettuce is about 8" tall already. I also planted tomatos, and cucumbers. The tomato plants are about 5" tall and the cucumber plants are about 4" tall. I grew mine indoors so far because it is snowing out right now. Thanks!
Oct 27, 2008. 10:08 AM008 says:
I'm curious as to how these plants will be able to keep themselves from toppling over when the tomatoes start growing. Would you have to build a cage around your container to tie the tomato plant to?
Oct 29, 2008. 2:01 PMxfirexstarzx says:
I intended to put them seperately in pots after they got large enough, but they slowed down growing when they got to about a foot tall, so I eventually planted them outside. The cucumbers were also planted outside, then died of the blight that is going through my area. The lettuce turned out awesome and the tomatos took off after being planted outside. Thanks!
Aug 16, 2008. 10:35 AMcowscankill says:
:D :D :D :D :D i just made one! its soo cool! ill post pics if it works! :D :D :D :D :D
Jul 11, 2008. 9:42 AMIkilledKenny says:
use liquid earth.
Oct 24, 2006. 5:42 AMths says:
Hydroponic mean no dirt, only rock (aquarium rock) and water (well + nutriment)
Apr 24, 2008. 9:01 AMjeffconnelly says:
I agree with ths (and this)
Mar 22, 2008. 7:50 PMfeelgoodlost says:
http://www.uark.edu/~mrevans/4703/index.html
if anyone is interested heres a very basic course on growing plants in a greenhouse, its at least a great help with alot of general terminology
Aug 13, 2007. 9:16 AMRed_Icculus says:
The addition of an air pump would accelerate growth compared to a passive system.
Jun 13, 2007. 2:29 PMcapra_mcg says:
I am very interested in hydroponics on a scale that would feed my family. Can think of many problems having to do with plants whose root systems are much smaller than then visible parts of plants. Weight imbalances for things like tomatoes or any plants that have large/heavy fruits. I have tried germinating in a soil-less environment with great results. I used two pieces of interfacing (sewing material that keeps collars stiff) and placed the seeds between the layers. Then I supported the layers on a piece of styro but allowed the edges to hang down below the styro. The styro is placed in a seed-starting tray with about a 1/2 of water. A dome lid is placed over it and the whole thing set in the sun. The interfacing wicks up the water as needed to keep the seeds moist, and the dome seals the moist/warm air needed for quick germination. Once the seeds have sprouted and have a true set of leaves, you can cut the interfacing and place the whole thing into soil or whatever medium you chose to grow in. It was fun and satified my need to 'know if it could be done'. You can find stuff to do similar germination on the net, BUT it is way expensive (10 germination pods for $8 + s/h). I got a piece of 45" x 36" interfacing for $1 at Wal-Mart. I love the savings and the results. FYI - searching net sites for 'Canabus' and 'hydroponic' will usually give you lots of interesting things to try. Great tips too. Saw a tip about rinsing plants prior to harvest to remove excess salts. They flushed the nutrient solution to just plain water a day or two (I think) prior to harvest. Sounds like what I need for my lettuce which seems to always have an overly salty taste (I use reclaimed water which has some chemical that burns certain plants). Maybe because I spray the lettuce from above (grown in soil right now), it absorbs too much of this chemical. Maybe using hydroponics would eliminate the problem if I water from the roots and then flush prior to harvest. Any comments would be welcome.
Jun 25, 2007. 8:20 PMmonkeyweather says:
You might try using water from your fish tank if you have one. Save doing all that mizing of formulas. Let the roots go into the water. When you want to refresh the water, dump what's "used" into the garden, and clean your fish tank again. Plants love fish wastes, and they'll actually clean the water nicely enough that your fish can tolerate that same water again. Saw one example on the web of plants growing right OVER the fish tank to save a step.
Apr 19, 2007. 7:14 AMaperkins01096 says:
Thanks for the instructable! Trying it out myself with "Vitamin Greens" from Johnny's Select Seeds. Four days and now there's growth. One tip if anyone's cups are floating too low: take a second cup, cut off 1/4" from the bottom to make a "sleeve". Set the original cup into that, then drop it back in place. Propped mine up to the proper level (I was using a close approximation to a hole saw to cut my styro: an almost proper sized tin can, "opened" sideways to make a cutting edge). Pics on my site at gardenhacker.com.
Mar 3, 2007. 1:46 PMmarcward86 says:
so, do you set it outside in the sun, or near a window? and what sorts of plants can you grow?
Dec 6, 2006. 3:36 AMchefmichel says:
Very nice hybrid setup. What do you grow in London in the winter ?? I like your octaeder template. I use recycled modified yoghurt containers in my hydro setup.
Dec 6, 2006. 8:50 AMchefmichel says:
Nowbody is purfect
Oct 16, 2006. 5:44 PMJunkernaut says:
Simple and effecitive. Brilliant!
Oct 10, 2006. 10:38 PMtrebuchet03 says:
very nice... technically using peat removes the hydroponic name from it... but meh, who cares what "they" say? What will you be growing? That looks perfect for baby lettuce :D A -- this is one of my favorite growing methods. You can also used recycled plastic cups from a local college party... Just wash out those red beer cups :P
Oct 14, 2006. 12:14 PMzachninme says:
I still don't think that this is real hydroponics. I think it is sorta an hybrid system.
Oct 12, 2006. 1:49 PMSpeidumb says:
Ah... a purley passive system... I like purls... :D
Oct 11, 2006. 8:31 AMsavvy9999 says:
Nice job. That hole-cutting exercise is just screaming for a hot-wire setup. One question-- do you leave the big foam tray (with all of the little peat/seed cups) floating in the container 24x7 for as long as you're growing, or what?
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
