Hydroponics grow kits - Advanced DWC by hydroponicsgrowshop
Revolutionary system combining hydroponics + dwc.
The system presents 4 drippers characteristics of an active hydroponics system that irrigate the plants roots in their pots.
The roots grow out of the pot and they immerse themselves into a constant peroxide nutrient solution.
The system is feed from an immersed pump that is guaranteed to recycle the water plus a powerful two-way air pump with porous stones that perfect the amounts of the peroxide solution and consequently benefits the development of the complete apparatus.
Thanks to the constant dripping, the system requires little maintenance and the plants always receive the correct amount of fertilizer and releases the excess.
The system has is the best quality, performance, time and value. Made of plastic UVA and UVB anti rays (anti algae).
To propagate your seeds go HERE
More info on hydroponics.eu and yaroots.com
Step 1:
Fill the tank with waters and nutrients as indicated on the scheme of your nutrient. An EC meter is very useful.
Step 2:
Place the air pump outside the system with the air stones in the tank.
Step 3:
Follow the manual to assembly of your grow kit with also the irrigation system.
Step 4:
Fill the pots with hydrokorrels and place rockwool cubes previously propagated.
Step 5:
In the growing phase, set the timer on 18 hours of light per day.
Step 6:
Start the system setting the timer for 15 minutes of irrigation every 2-3 hours and 15 minutes of irrigation in the middle of the dark period.
Step 7:
Check the pH values of your grow kit and, if necessary, correct the value with pH- or pH+ corrector.
Step 8:
Check the EC values of your grow kit and, if necessary, correct the value adding nutrients or diluting with water.
Step 9:
Always check the temperature of the nutrient solution. Under 18 degrees and over 26 solution can be damaged and could give some problems to the plants.
Step 10:
Every 15 days change completly the nutrient solution with a deep cleaning of the tank with Atami Ataclean to remove molds, algae and saline deposits.
Step 11:
When you want to induce plnats to flowering change the daylight hours from 18 to 12hrs per day.
Step 12:
At the same variation of the light period give a bloom nutrients according to the irrigation scheme.
Step 13:
Step 14:
Step 15:
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
