Hydropower from Reuse
 by masynmachien
Featured
Last fall we were staying at a holiday cottage generating its own electricity from a water wheel. We reproduced that in a little workshop with the kids, powering a LED with a miniature water wheel.
We made several attempts, a number of which worked, but those based on a stepper motors from a discarded printer proved to be the fastest an easiest to make. Furthermore, apart from some glue it was completely built out of discarded parts, thus combining the demonstration of renewable energy with reuse.
We had a great time building and playing. Check out the video to see the result in action:
Step 1: Reusing parts and materials
Reused:
a small stepper motor as found in a printer
2 discarded CD-ROMs
a foam tray
some long stick (I used a piece of 20mm diameter  PVC tube from demolition)
a LED
one or two tie-wraps
a small piece of scrap paper
Non-reused: The only non-reused part is the hot melt glue (I recommend the low temp type, especially when working with kids).
Tools: scissors, screwdriver to disassemble the printer (not shown), cutting pliers or desoldering tools for (optional, not shown).
Stepper motors make very easy generators, as they produce relatively high voltages (I’m talking 5V range) at low rpm. Small DC motors (toy motors) need high rpm and still produce only a low voltage (1V range). Stepper motors do not need gears and/or electronics to power a LED (compare it to my junior wind turbine). I was worried about blowing up the LED at first, but that did not happen. The current generated being pulsating very probably contributes to that.
I doe not bother to waterproof anything (motor or electronics). Repeated use for several minutes, on several occasions, showed no need for that.
If found two stepper motors in an old Lexmark inkjet printer for which first the ink heads were no longer available and which later did not survive more than a couple of refills of the last ink head. I guess most inkjet printers will have two stepper motors, one for moving the paper and one for moving the head. The way to disassemble the printer will differ for each model. As in this case the printer should be a discarded one and there is no need to put it back together, you can’t do much wrong by simply unscrewing al screws you can find until you can free the stepper motors. Just keep the pinion gear and the connector they come with on the motors. To give you an idea on what to disassemble, you can go looking for an exploded view of your printer, like this one.
With a bit of luck the LED can also be found in the discarded printer. With even more luck you can find some discarded electronics with a LED standing tall on a printed circuit board, with most of its legs still intact, instead of mounted flush on the board. This makes it easier to remove from the print (leave the legs as long as possible) and easier to connect to the stepper motor by simply inserting it in the plug. As alternative you either us a new LED or desolder one and solder it to the stepper motor leads (I guess it is hard to tell if the ecological impact smaller for using a new led or for (de)soldering).
To keep within the spirit, you can also reuse tie-wraps: when you cut them loose carefully near the “ratchet”, you end up with a shorter, but still usable tie wrap.
Now to start building, see the next step.
tcase6 says: May 18, 2013. 11:27 AM
actually, ive never thought of it until now, but, if someone were to work this into their downspouts on their house, and depending on the size of generator possible,, may be extra electric on top of other systems like solar and such,,, if someone was brave enough to make numerous models and redesign a downspout to use these, could put them in a row creating even more... or even just something with enough power to charge your cell phone while on camping trips...." if you get service unlike we do "....
mosquemouse says: Apr 13, 2013. 3:47 AM
I will be doing this project soon. Just a question, though. I browsed online for "stepper motors" & I came across motors like this, so I just want to make sure if this would be right?
http://www.adafruit.com/products/858#Learn
masynmachien (author) in reply to mosquemouseApr 14, 2013. 1:15 AM
Actually, that one isn't very suitable. The reduction means it needs a high torque to drive it (at low rpm). That could be used with a larger water wheel, but then I found out the output shaft quickly starts to slip in its gear, and the forces are no longer transferred to the actual stepper motor.
You can hack it, but then the actual stepper motor needs very high rpm. I managed to use one in a wind turbine by adding my own gears to the hacked stepper motor, but it became complicated and fragile build.
As far as I know. The cheapest you can buy and that do the trick https://www.sparkfun.com/products/10551
But it does need quite high rpm and therefor a fast water stream. Under a tap it just about works with good water pressure, full open and about half a meter below the tap.
The steppers stripped from printers actually work a lot better.
I've recently had good results with these geared DC motors powering a LED in a wind turbine: http://www.kelvin.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=280513
It should work in a water turbine too. You will need to protect the motor from water, as in contrast to many other motors, these ones break down after having water inside.
succes!
camdog7d says: May 3, 2012. 7:55 PM
I have led underglow on my skate board and I thought I could power it by putting the printer motor by attaching it to my wheel so when I go the wheel will spin which will make the power light up the LEDs.
marcintosh in reply to camdog7dAug 2, 2012. 6:13 AM
Dremel used to make a small mag powered light that went on the business end of the drill and would light up the work area. You could modify that to power your lights plus it's really tiny and wouldn't present any balance, drag, or size issues.
It's just a quick thought.
M
Stefanyk says: Jun 3, 2012. 10:43 AM
hi, i'm grateful to have found this site, i have a little project (for fun) but i don't have any skills on purpose.
i want to create a self powered "shishi odoshi" (a sort of japanese fountain).
by recirculating the same water with a recirculation pump powered by a hydraulic mill.
i made a gif to explain it: http://img3.imageshack.us/img3/5840/shishiodoshi4resize450.gif
my question is:how do I connect a mill to a circulation pump?
and more generally: how energy (in this case mechanical) can be canalized and used?
here i want ask if my project is possible, cause i don't know if such little turbine or with so little amount of water a recirculation pump can be powered.
thanks in advance
masynmachien (author) in reply to StefanykJun 3, 2012. 12:58 PM
Hi,
Do I understand correctly you plan to drive the "hydraulic mill" with only the water pumped up? That can not work, as it would be perpetuum mobile.
Stefanyk in reply to masynmachienJun 3, 2012. 10:17 PM
thanks for response.
mmm so i missed a little detail :P
then it's impossible to do it perpetual but for me it would be good in a finished perspective too, if it can go on for a few minutes or hours, it's ok.
what's the main problem? to what point the energy fails?
can work if I add water from time to time in the bottom tub?
or accumulating energy in some way: manually turning the turbine might accumulate energy, for example in a rechargeable battery then leaving it play for a few time.
can you explain better or reply to my questions?
masynmachien (author) in reply to StefanykJun 8, 2012. 1:49 AM
The bottom line is you will always loose energy at different steps and you can not win energy from nothing.
Adding water at the bottom makes no sense, as this brings no energy in the system. Adding water to the top could work. There are systems that use the energy of a large water flow to pump up a smaller amount of water to a higher altitude.
Obviously, powering the pump with a charged battery will have it run for som time, and you could recuperate a part of the energy with the turbine. Feeding this energy back to the battery or the pump would however need some decent control. My guess the energy gained would be rather limited.
I would suggest using an off-the shelf solar powered pump.
poofrabbit says: Apr 26, 2012. 5:48 PM
Hey congratulations on winning Scoochmaroo Challenge: Reuse!!!
masynmachien (author) in reply to poofrabbitApr 27, 2012. 10:57 AM
Thanks!
Lotusfalls says: Apr 27, 2012. 6:46 AM
Awesome instructable! Comprehensive, self-explanatory, and highly upgradable!
masynmachien (author) in reply to LotusfallsApr 27, 2012. 10:57 AM
Thanks!
Kasm279 says: Apr 26, 2012. 3:32 PM
How dare you destroy that poor windows 2000 CD, what did it ever do to you?
Anyway, cool instructable and a neat idea for old CDs, it's given me some ideas on making a siren...
ehudwill says: Apr 22, 2012. 5:49 PM
Great project. I will have to try this one with my kids this summer.
masynmachien (author) in reply to ehudwillApr 26, 2012. 10:33 AM
Thanks! keep me posted on your success.
skelley4 says: Apr 26, 2012. 7:18 AM
I am going to make one..thanks for sharing
masynmachien (author) in reply to skelley4Apr 26, 2012. 10:32 AM
Great! I'm curious to see your result.
yeschiro says: Apr 26, 2012. 7:07 AM
Great instructable! If you could get this to have application in recharging electronics wile camping near a stream (cell phone, tablet, ipod, gps). That would be cool.
masynmachien (author) in reply to yeschiroApr 26, 2012. 10:32 AM
Thanks!
The stepper motor should be able to give enough power to charge such devices when using all coils and a rectifier. The wheel will probably need some upgrading.
Dave_DC2 says: Apr 26, 2012. 9:00 AM
You could also add angled vanes on the front, to become a wind turbine...! Great project, well done.
masynmachien (author) in reply to Dave_DC2Apr 26, 2012. 10:23 AM
Thanks!
A win turbine is actually how I started out :-)
see: http://www.instructables.com/id/Junior-Wind-Turbine/
rimar2000 says: Apr 21, 2012. 3:07 PM
Good project!
You could have more effectiveness gluing the vanes at an angle.
masynmachien (author) in reply to rimar2000Apr 22, 2012. 12:55 AM
Thanks!
In this case I wanted to keep it as simple as possible and have it work in both directions of rotation.
By adding the measurement of voltage and current it would make a good start to experiment on what works best.
How you hold it in the stream is also an important factor. Actually, when holding it with the "edge" only in the water flow, my guess is straight vanes aren't bad. For that kind of use the vanes could be made more narrow (run less deep towards the center), but of course it should remain strong enough.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
